The Bonneville Shop
john toghill
john toghill
chatham kent UK
11 registered members (bsawood), 185 guests, and 376 spiders.
10528 Registered Users
franko 90
NickL 66
785,052 mail-order LSR
Topics69,219
Posts674,257
Members10,528
Rating: 3
Amal Concentric Carb Insulating Spacer? #734388
05/07/18 1:13 pm
05/07/18 1:13 pm
Florida
BillD47 Offline OP
BillD47  Offline OP
Florida
I am putting "thin" insulating spacers between the carbs and head on my '65 Spitfire. Since these are hard spacers, should there be paper gaskets on both sides of each insulator?
Good day!
Re: Amal Concentric Carb Insulating Spacer? [Re: BillD47] #734418
05/07/18 7:08 pm
05/07/18 7:08 pm
John Healy Offline
John Healy  Offline
The factory used the "O" ring for a seal on the carburetor side and a paper gasket on the engine side.
Re: Amal Concentric Carb Insulating Spacer? [Re: BillD47] #734489
05/08/18 12:09 pm
05/08/18 12:09 pm
Florida
BillD47 Offline OP
BillD47  Offline OP
Florida
Thank you.
Re: Amal Concentric Carb Insulating Spacer? [Re: BillD47] #734506
05/08/18 3:16 pm
05/08/18 3:16 pm
Lancaster, California
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
Curious to know... what size (thickness) spacers are you using?
Re: Amal Concentric Carb Insulating Spacer? [Re: C.B.S] #734628
05/09/18 2:41 pm
05/09/18 2:41 pm
V
VicCyclone Offline
VicCyclone  Offline
V
They are not really spacers, they are heat insulation washers. The originals were made from TUFNOL a hard laminated fabric/resin material made by the TUFNOL company who are still in business in their original factory in Wellhead Lane Perry Barr Birmingham. More or less directly opposite the site of the AMAL factory in Holford Road. TUFNOL is a similar material to Paxolin which was used to make Lucas magneto gears
VicCyclone
1965 A50 Cyclone Clubman
1966 Victor GP
1967 Victor Special
1968 Victor Special
1968 A65L
2009 HD FXDC
Re: Amal Concentric Carb Insulating Spacer? [Re: C.B.S] #734654
05/09/18 6:49 pm
05/09/18 6:49 pm
West Yorkshire
West Yorkshire
Same here. Many on the market are too thin, from memory the originals were about 3/16 thick, Ive seen some
About 1/8 which is too thin. That said, I wouldn’t use anything less than 10mm spacers on mine, on a hot day in heavy traffic anything much thinner causes running problems from the fuel boiling in the bowls.
Re: Amal Concentric Carb Insulating Spacer? [Re: BillD47] #734670
05/09/18 10:08 pm
05/09/18 10:08 pm
Florida
BillD47 Offline OP
BillD47  Offline OP
Florida
I have purchased the thin insulators, but after your comments I may be buying a thick set as well. Thanks again for the insight.
Re: Amal Concentric Carb Insulating Spacer? [Re: BillD47] #734695
05/10/18 4:24 am
05/10/18 4:24 am
Brisbane, Australia
BrizzoBrit Offline
BrizzoBrit  Offline
Brisbane, Australia
Yes, I'd reiterate what Alan says. I had issues with the fuel vaporising in the float bowls here in Brisbane summers. I now use 3/4" thick ones. Air filters only just squeeze in with concentrics. Might not work for monoblocs.
ray
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
& too many projects!
Re: Amal Concentric Carb Insulating Spacer? [Re: BillD47] #734724
05/10/18 12:03 pm
05/10/18 12:03 pm
BSA_WM20 Offline
BSA_WM20  Offline
Apparently the same material is used for heavy industrial fuse boxes.
So find some one who makes them and see if you can get off cuts.
Re: Amal Concentric Carb Insulating Spacer? [Re: BillD47] #734759
05/10/18 5:35 pm
05/10/18 5:35 pm
Stuart Offline
Stuart  Offline
Hi Bill,
Originally Posted by BSA_WM20
Apparently the same material is used for heavy industrial fuse boxes.find some one who makes them and see if you can get off cuts.
Surrey Cycles certainly used to have them in several thicknesses - worth an e-mail to check? https://surreycycles.com/contact-us/
Re: Amal Concentric Carb Insulating Spacer? [Re: BillD47] #735135
05/13/18 3:56 pm
05/13/18 3:56 pm
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
Re: Amal Concentric Carb Insulating Spacer? [Re: BillD47] #735201
05/14/18 4:13 am
05/14/18 4:13 am
Aus
NickL Offline
NickL  Offline
Aus
The Triumph carb mounting idea with the bigger sectional O-ring is also a viable alternative.
Th larger ring keeps the two flanges separated so very little heat is transferred. Care must be taken
so as not to over tighten the carbs though. The o rings are available from triumph stockists and may
be used either on their own or with the standard thin insulating spacer. I employ this method on my t'bolt
for the same reasons and have very little room for extended spacers.
The material described for use within electrical switchboards is commonly known as 'Paxolin' or 'Type-X'
It commonly comes in thicknesses from 3- 25mm or so.
Bring in the 'Comfy Chair'
Re: Amal Concentric Carb Insulating Spacer? [Re: BillD47] #735405
05/15/18 3:30 pm
05/15/18 3:30 pm
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
I had some issues with my A65L carbs getting hot. I went with the thickest phenolic spacer then I used the thinnest 5/16" X 24 nuts to grab onto the studs. Fixed my problems..
Re: Amal Concentric Carb Insulating Spacer? [Re: BillD47] #735509
05/16/18 7:19 am
05/16/18 7:19 am
West Yorkshire
West Yorkshire
Could use longer studs
