The Bonneville Shop
T140EBrian
T140EBrian
Georgia
13 registered members (barry2), 191 guests, and 431 spiders.
10528 Registered Users
franko 90
NickL 66
785,074 mail-order LSR
Topics69,219
Posts674,259
Members10,528
A65 oil consuption #734353
05/07/18 4:09 am
05/07/18 4:09 am
Maryborough Q.L.D.
mdodds Offline OP
mdodds  Offline OP
Maryborough Q.L.D.
Hello all. My A65 uses about 70mm every 100 miles. No smoking, plugs normal, plenty of power. Is this normal ?It`s done this from re-build till now{10,000 miles}Cast iron rings.
Re: A65 oil consuption [Re: mdodds] #734359
05/07/18 6:19 am
05/07/18 6:19 am
triton thrasher Offline
What’s that in pints, fluid ounces cubic centimetres or millilitres?
Re: A65 oil consuption [Re: mdodds] #734361
05/07/18 6:52 am
05/07/18 6:52 am
Maryborough Q.L.D.
mdodds Offline OP
mdodds  Offline OP
Maryborough Q.L.D.
millitres mate.
Re: A65 oil consuption [Re: mdodds] #734362
05/07/18 6:59 am
05/07/18 6:59 am
Maryborough Q.L.D.
mdodds Offline OP
mdodds  Offline OP
Maryborough Q.L.D.
About half a tea cup i suppose!
Re: A65 oil consuption [Re: mdodds] #734363
05/07/18 7:35 am
05/07/18 7:35 am
Aus
NickL Offline
NickL  Offline
Aus
That's not excessive. I ride my one pretty hard and it uses a pint or so in 1000 miles.
I know the pistons were a little corroded and /worn when i built it though, i suppose i should have replaced them but thought i'd get away with just rings.
It doesn't smoke, just burns a drop especially if used to 6k a fair bit.
Bring in the 'Comfy Chair'
Re: A65 oil consuption [Re: mdodds] #734366
05/07/18 8:04 am
05/07/18 8:04 am
I think that’s a pint (imperial) in 800 miles.
Not a problem.
Re: A65 oil consuption [Re: mdodds] #734368
05/07/18 8:14 am
05/07/18 8:14 am
Aus
NickL Offline
NickL  Offline
Aus
Ask anyone with a 'vinnie'................................
Re: A65 oil consuption [Re: mdodds] #734430
05/07/18 9:54 pm
05/07/18 9:54 pm
Auckland NZ
Ignoramus Offline
Ignoramus  Offline
Auckland NZ
oil use kind of depends on how much is being burned AND how much of it is leaking, but 70ml in 100 miles doesnt sound excessive.
my A65 doesnt leak much and uses around 500ml in 1000 or so miles .
Re: A65 oil consuption [Re: mdodds] #734449
05/08/18 1:38 am
05/08/18 1:38 am
Magnolia, TX
htown Offline
htown  Offline
Magnolia, TX
When do you check your oil? If it's before a ride it could be your bike is seeping a little oil into the sump and then what you add goes out the tank vent after the engine is started. Best practice is to check oil when hot right after a ride. That way there isn't any loss to the sump.
I've found my oil levels stay more consistent even with the hot oil check if I shoot to have the level about a 1/3 pint low on the dipstick. Seems like when I try to keep it completely full I'm always adding oil but when I leave just a little lower it tends to stay there.
1978 Bonneville T140E
1974 Trident
1970 BSA Thunderbolt
1971 Norton Commando
1973 Norton Commando
1974 Norton Commando
2004 XL 1200R Sportster
Re: A65 oil consuption [Re: mdodds] #734659
05/09/18 7:07 pm
05/09/18 7:07 pm
West Yorkshire
West Yorkshire
Mine uses a bit when I push it hard, touring at 70 it doesn’t use a drop.... so I’ve put it down to it being blown out of the cam breather, I did have an additional breather which I have now blanked off as a temp to test my theory of oil being pumped out. But none ever past the rings etc.... either that or the inline filter is restricting the return flow and over pumping to the head. All I know is the oil return on my mates OIF is better than Monday tick over. His permernatly runs through a filter and oil cooler. Mine has a thermostat inline with the cooler (because when cold the oil would blow past a pipe on the return..... since reverted to 10:40 oil so will see again.
Re: A65 oil consuption [Re: mdodds] #734681
05/10/18 12:57 am
05/10/18 12:57 am
Illinois
Spitfire Ken Offline
Illinois
IF YOU BROKE IT IN USING SYTHETIC OIL THERE IS A CHANCE THE RINGS NEVER SEATED PROPERLY.
The Devil is in the details.
1967 BSA A65 West Coast Hornet (under rstoration)
2001 Kawasaki W650
Re: A65 oil consuption [Re: Spitfire Ken] #734705
05/10/18 7:49 am
05/10/18 7:49 am
West Yorkshire
West Yorkshire
Where did that assumption come from?
Re: A65 oil consuption [Re: Allan Gill] #734718
05/10/18 11:16 am
05/10/18 11:16 am
Illinois
Illinois
IT IS NOT AN ASSUMPTION, SOME MANUFACTURERS RUN AN ENGINE ON REGULAR OIL PRIOR TO DELIVERY THEN CHANGE IT TO SYNTHETIC FOR DELIVERY.
http://www.enginebuildermag.com/2014/10/break-in-oils-and-assembly-lube-needs/
2001 Kawasaki W650
Re: A65 oil consuption [Re: Allan Gill] #734725
05/10/18 12:07 pm
05/10/18 12:07 pm
It would be better practice to have the filter in line before the T-off to the rockers.
Re: A65 oil consuption [Re: triton thrasher] #734927
05/11/18 10:30 pm
05/11/18 10:30 pm
Aus
NickL Offline
NickL  Offline
Aus
+1. Why put scavenged dirty oil from the sump back into the engine?
Re: A65 oil consuption [Re: NickL] #735375
05/15/18 12:13 pm
05/15/18 12:13 pm
West Yorkshire
West Yorkshire
Any chance we can switch from capitals? it's seen as shouting...
I agree with this last statement, a mineral based oil should be used for breaking in, but this is linked with modern vehicles (where a mineral based break in oil would be used) our old heaps still specify mineral SAE 40 or 20/50 oil (depending on year it was made) sytnthetic oil is still new by those standards... Very few people would switch to synthetic oils... and those that would usually have a very good knowlege of engines anyway and you would hope would run a mineral oil until the engine has run in.
The question about assumption is because it hasnt been told what oil was used in the engine from first build. until we know.... that part is assumed.
Oh I agree, but like many others its one of the jobs I have yet to get around to and like many others I fitted a filter into what was available at the time. Maybe the next time I repipe the bikes oil lines this will get done laughing
Re: A65 oil consuption [Re: mdodds] #735501
05/16/18 5:21 am
05/16/18 5:21 am
Aus
NickL Offline
NickL  Offline
Aus
https://www.eBay.com.au/itm/5-16-X-3-16-X-5-16-8mm-5mm-8mm-Tee-3-Way-Hose-Barb-Brass-Fitting-Fuel-Reducer/222686642978?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2648
