The Bonneville Shop
triton thrasher
triton thrasher
26 registered members (Alan_nc), 264 guests, and 450 spiders.
SuzyTice, Steve Funke, JD8, John Rowley, Zoot
10531 Registered Users
franko 96
Lannis 81
NickL 66
789,359 mail-order LSR
Topics69,252
Posts674,577
Members10,531
Revised Starter Location #731766
04/13/18 4:49 am
04/13/18 4:49 am
ca, us
DMadigan Offline OP
DMadigan  Offline OP
ca, us
Since I have to make clutch housings to adapt the starter for the R3 and T150 I decided to move the starter location. The starter motor and solenoid have been swapped so the motor is closer to the cylinders. This leaves more room for the carbs so the bowls do not have to be changed to the drainless type. Also, the clearance to the gearbox web is increased so the cases no longer have to be modified to mount the starter.
This is the new adapter:
Note the case ground off for the T160 clutch housing Lucas starter clearance:
Re: Revised Starter Location [Re: DMadigan] #731821
04/13/18 7:32 pm
04/13/18 7:32 pm
Ottawa, Canada
gREgg-K Offline
gREgg-K  Offline
Ottawa, Canada
Nice work as always, Dave!
magneto@spyder-it.com
Re: Revised Starter Location [Re: DMadigan] #731973
04/15/18 5:41 pm
04/15/18 5:41 pm
Central Ohio
PFribley Offline
PFribley  Offline
Central Ohio
That is a work of art!!! Do you sell the fuel rail???
Re: Revised Starter Location [Re: DMadigan] #731980
04/15/18 7:07 pm
04/15/18 7:07 pm
ca, us
DMadigan Offline OP
DMadigan  Offline OP
ca, us
Thanks. The fuel rail is one item in my parts catalog.
Re: Revised Starter Location [Re: DMadigan] #732030
04/16/18 3:48 am
04/16/18 3:48 am
Central Ohio
PFribley Offline
PFribley  Offline
Central Ohio
How can I order a pair of them?????
Re: Revised Starter Location [Re: DMadigan] #732053
04/16/18 1:31 pm
04/16/18 1:31 pm
ca, us
DMadigan Offline OP
DMadigan  Offline OP
ca, us
PM for a parts and price sheet.
Re: Revised Starter Location [Re: DMadigan] #735848
05/19/18 8:25 pm
05/19/18 8:25 pm
ca, us
DMadigan Offline OP
DMadigan  Offline OP
ca, us
Here is the prototype off the mill:
The rear breather stub hole has to be bored. The slight goldish tint in the starter adapter is because this one is magnesium. I did not have a large enough piece of aluminum laying around. Both pieces will be in aluminum.
The shop has to clean up the tool paths but there will still be some machining marks. One possibility is to have them sand blasted so it looks more like the casting. Going over it with a rubber wheel would eliminate the machine marks but leave it with a satin surface.
The carbs drains are close but at least not touching the solenoid. A nylon tie wrap around the backbone and centre carb gantry stub would keep the carbs from sagging. A rigid mount between the gantry and head would eliminate the problem also. It would also eliminate any air leaks from all those connections.
At least this starter installation does not require shaving the T150 gearbox flange as the T160 starter and housing did.
I decided to make ring gears since these are also in short or non-existant supply.
