Support Your #1 Forum
Buy BritBike's staff a coffeeStill here since 1996.. Click here to buy BritBike staff a coffee.
33 registered members (Alan_nc), 309 guests, and 247 spiders.
Fumi, brennan devine, sivaraj, LarryL, chickin
10613 Registered Users
franko 121
koan58 81
Mori55 72
reverb 64
NickL 60
831,727 mail-order LSR
Topics67,840
Posts672,060
Members10,613
Rating: 3
? on A65 Exhaust Rocker Removal #731915
04/15/18 1:12 am
04/15/18 1:12 am
Oklahoma
Tracey Spear Offline OP
Oklahoma
How does one remove the exhaust rocker to get at the head bolts when the exhaust valve is compressed and the engine won't turn.
The manual instructs to loosen the valve adjusters until the rockers are free and drive out the shaft.
I'm a little concerned about driving out the shaft while under pressure from the valve spring.
Advise please, and thank you.
Re: ? on A65 Exhaust Rocker Removal [Re: Tracey Spear] #731917
04/15/18 1:28 am
04/15/18 1:28 am
I'd take the valve adjusters completely out, to minimize any pressure on the arm. You're working on an unnaturally frozen engine, so standard procedure won't work. You'll just need to minimize any potential damage ....
Once you've loosened up the valve adjusters, I'd gently tap the shaft out with a brass drift. First I make a note as to what order the spring and flat washers are in in relation to the rocker arms, though .... !
You should have to pass a drug test to receive a welfare check... because I had to pass one to earn it for you.
Re: ? on A65 Exhaust Rocker Removal [Re: NickL] #731946
04/15/18 12:25 pm
04/15/18 12:25 pm
Originally Posted by NickL
Undo the tappet adjusters then using a large open ended spanner on the rocker arm open the valve sufficiently to pop the pushrod out.
OR just undo the barrel base nuts and move the barrel up enough to remove the pushrods.
Both good ideas. Have to be careful where you "pry" the rocker arm, but a little mechanical sympathy will help.
Barrel's got to come off anyway ... unbolting will work unless it's the crank that's seized and not the pistons! Hope that's not the case ...
Re: ? on A65 Exhaust Rocker Removal [Re: Tracey Spear] #731986
04/15/18 7:57 pm
04/15/18 7:57 pm
Oklahoma
Oklahoma
Lever the rocker to release the pushrod. So simple it evaded me. Thanks Nick
If I can get all the honeydo's done, maybe I can pull the head this evening.
Re: ? on A65 Exhaust Rocker Removal [Re: Tracey Spear] #731987
04/15/18 7:59 pm
04/15/18 7:59 pm
Mark Z Offline
Mark Z  Offline
Also, if the whole engine is being torn down anyway, you could remove the inner timing cover and pull out the idler pinion; then the camshaft can be turned independently from the crank.
Re: ? on A65 Exhaust Rocker Removal [Re: Lannis] #732028
04/16/18 3:19 am
04/16/18 3:19 am
Oklahoma
Oklahoma
The head came off with no issues. Pistons were rusted into the bore. I shimmed up the barrels and beat the pistons out. Big hammer wouldn't cut it, had to dig out really big hammer. Head and barrels off, pretty good week end. Heading for clutch and primary.
Thank you for the good advice.
