Andy Lorenz
Andy Lorenz
Stafford, UK
Support Your #1 Forum
Buy BritBike's staff a coffeeStill here since 1996.. Click here to buy BritBike staff a coffee.
89 registered members (998John), 557 guests, and 775 spiders.
sivaraj, LarryL, chickin, Hill Easterwood, Stanier8F
10611 Registered Users
franko 123
Mori55 77
koan58 71
NickL 68
reverb 65
830,383 mail-order LSR
Topics67,819
Posts671,852
Members10,611
elephant foot swivel adjusters. #731126
04/06/18 3:31 pm
04/06/18 3:31 pm
Bakersfield CA
Tony Cornett_dup1 Offline OP
Bakersfield CA
Has anyone used the 911 Porsche swivel feet valve adjusters on an BSA a-65? If so did you have to cut them down? Pictures if you have them.
Thanks T.C.
Re: elephant foot swivel adjusters. [Re: Tony Cornett_dup1] #731145
04/06/18 5:48 pm
04/06/18 5:48 pm
Kristiansund. Norway
Arnstein Offline
Arnstein  Offline
https://www.dropbox.com/s/fnhpjihea4664y2/P1000653.JPG?dl=0
Picture of the VW (Porsche?) ones I´m using in my Spitfire (bought from Rainer Traupel +49 4532260227). I cut them shorter and cut a slot in the end for adjustment with a screwdriver and also use aluminium nuts. The pushrods will of course also have to be shortened a little. I have had them in my engine for nearly 40 000km.. works excellent and no more pitting in the valve end. With the alu nut the weight is approx the same as the BSA ones and the cut off on the pushrod.
Arnstein
BSA Spitfire MK3.800cc
Honda CB450T -71
Laverda RGS 1130cc -85
Ducati 1098 -08
Re: elephant foot swivel adjusters. [Re: Tony Cornett_dup1] #731151
04/06/18 6:33 pm
04/06/18 6:33 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
I have used them but as Arnstein said you have to shorten the pushrods. You also need to rethread the rockers for the 8x1mm thread. I now make EF adjusters in the 5/16-24 thread for triples but they can be used on twins also. Minimum clearance from valve tip to rocker is 0.4". Before shortening the pushrods, check the geometry to see if the valve stem should be shortened.
Triple adjusting screw shown for reference.
Re: elephant foot swivel adjusters. [Re: DMadigan] #731285
04/07/18 10:26 pm
04/07/18 10:26 pm
Arnstein Offline
Arnstein  Offline
https://www.dropbox.com/s/h1l9njyivcyz1cl/P1000654.JPG?dl=0
I shortened the pushrods ca 3mm ( they differ a bit from new and so does the rockers ) and that will make the measurement from under the rocker to under the swivel approx 8.5mm ( holding the swivel square to the underside of the rocker ) when adjusted valve clearance ca 0.25mm exhaust.. the wear pattern under the EF showing evenly across.
DMadigan I do´nt understand what´s meanth measuring the minimum 0.4" (10mm) clearance, is this measured similar to my 8.5mm?
Arnstein
Honda CB450T -71
Ducati 1098 -08
Re: elephant foot swivel adjusters. [Re: Tony Cornett_dup1] #731300
04/08/18 1:08 am
04/08/18 1:08 am
Bakersfield CA
Bakersfield CA
Why not bevel the bottom of the rockers so the swivels will work and you will not have to shorten the push rods only the elephant foot stems? You will lose a few threads but I think you will be ok.
This method has been used by the xs650 group.
Re: elephant foot swivel adjusters. [Re: Tony Cornett_dup1] #731320
04/08/18 10:01 am
04/08/18 10:01 am
Arnstein Offline
Arnstein  Offline
Might be that this will loose too much material / threads using the VW ones which has a long unthreaded part of the stem. The Nice Madigan ones will probably be better.
Arnstein
Honda CB450T -71
Ducati 1098 -08
Re: elephant foot swivel adjusters. [Re: Tony Cornett_dup1] #731334
04/08/18 2:04 pm
04/08/18 2:04 pm
Hampshire, England
DoubleDiamond Offline
Hampshire, England
The A65 uses 5/16" x 26 tpi adjusters - they are BSCy - British Standard Cycle. Do you make these David?
Triumph: '87 T140; '72 T150v
Re: elephant foot swivel adjusters. [Re: Tony Cornett_dup1] #731344
04/08/18 3:11 pm
04/08/18 3:11 pm
Bakersfield CA
Bakersfield CA
D-squared I just run an eight mm tap through the rockers works fine for my Porsche adjusters.
Re: elephant foot swivel adjusters. [Re: Tony Cornett_dup1] #731355
04/08/18 5:15 pm
04/08/18 5:15 pm
Hampshire, England
Hampshire, England
Hi Tony. Yes, I did that on both Triples. Trouble is that the rockers are pretty hard and often it needs more than one 8x1 HSS tap to do all 6!
OK maybe 25.4tpi is closer to 26tpi than 24tpi, but it does mean that there is no going back.
Re: elephant foot swivel adjusters. [Re: DoubleDiamond] #731412
04/09/18 12:28 am
04/09/18 12:28 am
Bowral NSW Australia
John Goodwin Online content
John Goodwin  Online Content
One of the go fast changes made to the T150 and T160's was to get rid of the swivel style tappet adjusters and go with Elephant Foot "Norman Hyde" solid tappet adjusters.
I'm puzzled why you'd go this way and not use these which are much lighter and an improvement on the stock adjusters. No need to mess with pushrods, no messing with the rocker arm threads. Seems to be excessive overkill using those swivel types to me unless you are expecting to be doing massive mileage!
https://www.classicbritishspares.com/collections/bsa-engine/products/mushroom-tappet-adjusters
Re: elephant foot swivel adjusters. [Re: Tony Cornett_dup1] #731434
04/09/18 12:38 pm
04/09/18 12:38 pm
Mark Parker Online content
Mark Parker  Online Content
I use the mushroom adjusters in my A65 they work well. I use lash caps on the valves. Because I have alloy cyls and C/molly pushrods I have to set it with zero clearance cold, and even then when the thing is hot the clearance probably gets a bit big, so the caps get hammered. The std adjusters dug holes in the caps but the mushroom heads do not. The swivel foot type look good.
Re: elephant foot swivel adjusters. [Re: Tony Cornett_dup1] #731466
04/09/18 5:59 pm
04/09/18 5:59 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
I only have the 5/16"-24 which work on the triples and T140. I do not know if the T120 changed over to UNF on the rockers.
8x1mm is closer to the 5/16-26 TPI and need very little material removed to fit the A65. The Porsche adjusters are somewhat expensive ~$35 each.
The reason for changing to EF adjusters over the others is a sphere has a single point contact which is why lash caps are needed with them. The EF adjusters have a ball/socket which has less wear and spreads the load over the top of the valve stem. The T160 adjusters are similar but with a smaller flat on the valve. When the T160 adjuster is loaded and slides across the valve, the edge of the flat will dig in more then the larger EF foot. Same effect as when lapping a flat part and drawing it back and forth rather than a circular motion.
Re: elephant foot swivel adjusters. [Re: DMadigan] #731773
04/13/18 9:22 am
04/13/18 9:22 am
UK - Bucks
Steve Wilson Offline
UK - Bucks
Hi. You're making these? How much for a set?
Thanx
SJW
Re: elephant foot swivel adjusters. [Re: Tony Cornett_dup1] #731828
04/13/18 9:53 pm
04/13/18 9:53 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
Steve, PM for a price list. Thanks.
