The Bonneville Shop
T140EBrian
T140EBrian
Georgia
13 registered members (Bougor), 196 guests, and 418 spiders.
10528 Registered Users
franko 90
NickL 66
785,074 mail-order LSR
Topics69,219
Posts674,259
Members10,528
Rating: 4
Hornet pipes, late type clutch (A65) #730287
03/29/18 3:45 pm
03/29/18 3:45 pm
Norway
Manx Offline OP
Manx  Offline OP
Norway
Has anyone fit hornet pipes in conjunction with the later type cluch cover.
I mocked up my top end today to fettle room for a panckake filter and I see that the clutch cable is touching the pipe.
I could maybe fit a spring over the cable outer but maybee someone has a smarter solution?
1966 Rickman Metisse (a65)
1957 B33
1959 lambretta li 150
1960 lambretta li150
Re: Hornet pipes, late type clutch (A65) [Re: Manx] #730314
03/29/18 9:25 pm
03/29/18 9:25 pm
Au
markoz Offline
markoz  Offline
Au
I have no answer for you, but the shorter srm barrels do make fitting pipes a bit more difficult.
Re: Hornet pipes, late type clutch (A65) [Re: Manx] #730316
03/29/18 9:45 pm
03/29/18 9:45 pm
Farnham, Surrey, UK
gunner Offline
gunner  Offline
Farnham, Surrey, UK
I have the same pipes fitted on my 1968 Firebird, however the clutch cable enters from behind the inner timing side cover so there is no issue with fouling the exhaust. Maybe you could convert to using the earlier inner timing side cover but I don't know if this works with the later OIF cases.
Re: Hornet pipes, late type clutch (A65) [Re: Manx] #730317
03/29/18 9:52 pm
03/29/18 9:52 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
Ditch the leg burners
BSA B31 500cc "Stargazer"
Greeves 200cc "Blue Meanie"
Greeves 360 Challenger
Jawa 500cc "Llareggub"
'35 OK Supreme
'36 OK Supreme
Re: Hornet pipes, late type clutch (A65) [Re: Manx] #730327
03/29/18 10:44 pm
03/29/18 10:44 pm
Norway
Manx Offline OP
Manx  Offline OP
Norway
As awkward or loud as these may be, this is what my bike originally came with.
The timing covers have been replaced at sometime and have end bearing and oil feed conversion so swapping those is out of the question.
I have made a clutch cable with an adjuster so the adjuster on the case can be screwed all the way in.
The cable is touching the pipe and I think I will use an exhaust P bracket and cut a slot to hold the cable off the pipe.
I've seen photos of hornet pipes on newer motors and am curious how people get around it.
Low slung pipes on a motorcross bike are pretty useless, I know this because I've just removed a set and they have had more hits than ABBA...
1957 B33
Re: Hornet pipes, late type clutch (A65) [Re: markoz] #730328
03/29/18 10:56 pm
03/29/18 10:56 pm
Norway
Manx Offline OP
Manx  Offline OP
Norway
Shorter how? The jug that is on now is the devimead just for mock up .
1957 B33
Re: Hornet pipes, late type clutch (A65) [Re: Manx] #730343
03/30/18 3:10 am
03/30/18 3:10 am
Illinois
Spitfire Ken Offline
Illinois
THE 64-65 HORNET PIPES "MIGHT" WORK BETTER.
The Devil is in the details.
1967 BSA A65 West Coast Hornet (under rstoration)
2001 Kawasaki W650
Re: Hornet pipes, late type clutch (A65) [Re: NickL] #730346
03/30/18 6:49 am
03/30/18 6:49 am
Norway
Manx Offline OP
Manx  Offline OP
Norway
Originally Posted by NickL
You could drill the late cover you have and convert it to the earlier style clutch operator.
The markings for the casting plugs are still there, just need sorting.
The devimead/srm 750 barrels are about 3/8 shorter, the 850 type are about the same as original.
That's why SRM supply pushrods with their 750 kits.
Piston height above the pin is much shorter with the B44 pistons for 750 displacement.
Ahh... I didn't know that but they did mention that the Devimead head bolts wouldn't fit, so now I know why.
The positive is that will give me better carb clearance but will proberbly bring the exhaust very close to the cable adjuster. I have to wait for the barrel before do anything else.
1957 B33
Re: Hornet pipes, late type clutch (A65) [Re: Manx] #730363
03/30/18 12:33 pm
03/30/18 12:33 pm
gavin eisler Offline
A steel swept bend might fix the clutch cable entry, look at Venhills cable bits this sort of thing, https://www.venhill.co.uk/cables-amp-components/af1c.html
Ever wonder why the OIF firebirds had pipes up the LHS.? Now you know.
of course the clutch cable now becomes a custom one off with a re route, maybe lead in from the front?
Re: Hornet pipes, late type clutch (A65) [Re: Manx] #730451
03/31/18 10:54 am
03/31/18 10:54 am
Mark Parker Offline
Mark Parker  Offline
I'm with Gavin, add a curved metal section to get it off the pipe. It's a common way to turn a cable run away from stuff. I have 90degree ones for throttle cables on my carbs. Just look at how much room you have and workout the angle you need, if you can pull the cable off the pipe a metal section with that curve should work, it should screw in and lock where you want it with a lock nut.
Re: Hornet pipes, late type clutch (A65) [Re: Mark Parker] #734573
05/09/18 4:35 am
05/09/18 4:35 am
Pacific NW
9
998John Offline
998John  Offline
Pacific NW
Is there a source for TT pipes for the 67 West Coast Hornet? The ones that came with the bike look more like Triumph TT pipes.
I have seen one other Hornet with similar pipes but none in any BSA flyers or brochures.
Re: Hornet pipes, late type clutch (A65) [Re: 998John] #735343
05/15/18 3:31 am
05/15/18 3:31 am
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
John,
No source for original West Coast model Hornet TT pipes. They are very hard to source. I maintain a database of known original Hornet TT pipes, both NOS and used around the world. The database is not very long. Granted there are pipes out there that I don't know about, but none the less, most that have them don't want to give them up. No accurate reproductions available that I know of. Some were made though, and I posted the differences (original vs reproduction) with images in the long Hornet/Wasp thread (a sticky thread). Because of the compound angles of the bends right out of the head, the very tight frame clearances (about an 1/8" or less), as well as very tight engine sump cover studs/nuts clearance (again 1/8" or less), they would be difficult to duplicate.
Re: Hornet pipes, late type clutch (A65) [Re: Manx] #735377
05/15/18 12:27 pm
05/15/18 12:27 pm
West Yorkshire
West Yorkshire
You could also retro-fit the earlier clutch mechanism in to the later inner case, early outer cases are very cheap too. simple enough to drill two holes, fit a cable adapter and add the lever.
Re: Hornet pipes, late type clutch (A65) [Re: Gary E] #735724
05/18/18 3:38 am
05/18/18 3:38 am
Pacific NW
9
998John Offline
998John  Offline
Pacific NW
Originally Posted by Gary E
John,
Gary,
Here's a set of "TT" pipe available from Classic Motorcycle Spares. Have you seen or know of anyone who has tried them?
http://www.classicmotorcyclespares....sa-a65tt-tt-style.html#BSA_Exhaust_Pipes
Re: Hornet pipes, late type clutch (A65) [Re: 998John] #735743
05/18/18 10:58 am
05/18/18 10:58 am
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
John,
Gary,
John,
I had a set that looked just like those. Don't know if the set was the same manufacturer or not. They didn't fit for s**t. They hit everywhere. Sold them, buyer sent them back, said he couldn't get them to fit. Sold them again, 2nd buyer said he'd keep them no matter what. I have the differences between factory originals and reproductions (with images) posted in the long (sticky thread) Hornet/Wasp et al thread. Oh, and that link you posted shows "out of stock".
Re: Hornet pipes, late type clutch (A65) [Re: 998John] #735753
05/18/18 12:42 pm
05/18/18 12:42 pm
Illinois
Illinois
I HAVE SEEN THESE BUT HAVE NOT TRIED THEM ON A BIKE FOR FIT. THE WELDS ARE NOT WERE NOT ACCURATE ENOUGH FOR A SHOW BIKE.
GARY I STILL HAVE THE USED SCRAPE UP SET THAT I SENT YOU PICTURES OF A WHILE BACK. I AM NOT GOING TO USE THEM BECAUSE I FOUND AN NOS SET THAT I AM USING ON MY BIKE.
2001 Kawasaki W650
Re: Hornet pipes, late type clutch (A65) [Re: Spitfire Ken] #735867
05/20/18 1:33 am
05/20/18 1:33 am
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
Ok Ken. I'll add your NOS set to the TT pipe database.
