ludwig
ludwig
belgium
18 registered members (Alan_nc), 183 guests, and 413 spiders.
Mums, MyrtleBeezer, Crockermc, mpotter78, Frezz
10485 Registered Users
NickL 97
franko 89
Triless 65
752,359 mail-order LSR
Topics68,895
Posts671,100
Members10,485
Working on the double Triumph... #728492
03/13/18 3:30 pm
03/13/18 3:30 pm
Running from demons in WNY
Hillbilly bike Offline OP
I have been working on the bike on and off... Got the oil pressure issue fixed, inverted crank seal...No unusual debris on magnetic drain plugs or sump screens or on inside the cut open oil filters so I assume all is ok ...Have to get some race gas and fire it up to check....
The primary drive took a beating from several hours on the dyno and a few trips down the track.And my crew failed to oil the chains as directed !!!..The front chain was partially siezed ,EK brand.. The rear engine chain and primary chain are Chinese "Ultima" brand and held up ok...I cut a new Ultima chain to size for the front..
Substituted different type fuel filters.Hopefully it's cure the occasional random carb flooding...
The bike will probably be run this summer at the new location of the ECTA in Arkansas
I take off bike parts until it doesn't function, then put on just enough so it functions
Re: Working on the double Triumph... [Re: Hillbilly bike] #728508
03/13/18 8:01 pm
03/13/18 8:01 pm
melbourne florida
bodine031 Offline
bodine031  Offline
melbourne florida
Brings me back to one of my heros's in my way younger days. Grew up a motorhead on L.I. Boris on the Tri. and the triple triple Kaw.!!!!!!!!!
Good luck this summer keep us posted
Re: Working on the double Triumph... [Re: Hillbilly bike] #728561
03/14/18 12:18 pm
03/14/18 12:18 pm
Nova Scotia, Canada
koncretekid Offline
koncretekid  Offline
Nova Scotia, Canada
Interesting that the fuel filters might have been the cause of random carb flooding problems. I saw massive carb flooding on my bike while on the chassis dyno at higher rpm which I attributed to being tied down with the rigid rear, possibly causing the needle valve to vibrate off its seat . Or maybe they were flooding while competing that I wasn't aware of. I lowered float level slightly which apparently solved the flooding problem on the dyno, without adversely affecting performance.
As for the excessive wear on the primary chains, I saw one innovation that dripped water onto the chains on a dual Yamaha engined bike to at least keep them cooler. There is apparently no rule against dripping water onto the track (at Bonneville.) Other than that, what about using "open gear" lubricant that is used on open transmission gears and chains? Sticky as hell, but you would have to add shields to contain it.
Tom
Re: Working on the double Triumph... [Re: Hillbilly bike] #728567
03/14/18 2:00 pm
03/14/18 2:00 pm
Tom, the previous fuel filters were home made screens...The petcocks are 3/8 NPT ,I rolled up 100 micron steel screen and stuck it in the nipple hoping it would work.Real Hillbilly filters.....The tanks are also home made and there's a bit of junk inside that flakes off....The new filters have 40 micron bronze stone filters...I will check the flow...
On the dyno the engines' power rose normally and then flattened out around 6200 RPM but still pulled to 7200 RPM...Despite what the air /fuel meter said the very experienced dyno operator thought the carbs were going rich on top end...Could be harmonics messing with float levels..I lowered the floats 1 MM....
Water cooling sounds good.... but dripping water on a paved track might be frowned on ? The chains are being used beyond their design limit and belts would be better in this situation...But the cost of belts and custom designed pulleys might be too frustrating..And the chains are reliable for about an hours use...many runs down the track...
Re: Working on the double Triumph... [Re: Hillbilly bike] #728585
03/14/18 4:56 pm
03/14/18 4:56 pm
Nova Scotia, Canada
koncretekid Offline
koncretekid  Offline
Nova Scotia, Canada
Water injection into the intakes is perfectly legal even in the gas class as long as it's pure water and such a tank would not raise any alarms. A small water tank with a valved line running into the chain guards would not seem to be counter to any rules in the books. I'm sure that small amount of water would be no more than what comes out of the majority of cars running down the tracks, so I wouldn't worry about it. I would point out to the starter (Paul, at Loring) that it's water, as he does look each machine over and will flag a bike if it's leaking gas or oil. Easier to beg forgiveness than to ask permission. Incidentally, I was one of the tech inspectors on your bikes at Loring last year as I usually go to the track a day early to help out with bike inspections.
Re: Working on the double Triumph... [Re: Hillbilly bike] #728587
03/14/18 5:15 pm
03/14/18 5:15 pm
I wasn't at Maine in July when the bike was run....My friend/bike owner and rider, friendly guy with lots of tattoos, said you guys did a thorough inspection and had a bitch or two about minor stuff but let the bike run as it was...I don't know if it was you but an inspector said " anyone can buy and race a Hayabusa, this bike is what LSR is about " I take that to mean a grass roots home built machine...
I don't think the bike will be at Maine this year...There are plans to go to the ECTA meet at the new location in Arkansas...A 16 ounce tank of water will fit on the front down tube and gravity fed with a valve....What's the worst ? Inspector says remove it...
Edit, Tom PM'ed me to say there was a discussion at tech inspection with my rider concerning the way I made a tranny mount...But they were considerate and let the bike run as is....
Re: Working on the double Triumph... [Re: Hillbilly bike] #728594
03/14/18 6:16 pm
03/14/18 6:16 pm
kevin roberts Offline
your bike had a crowd wherever it was parked. there were bikes much newer and faster that didnt get a second glance.
Re: Working on the double Triumph... [Re: Hillbilly bike] #728601
03/14/18 7:26 pm
03/14/18 7:26 pm
Well my rider likes attention...The bike is interesting to look at with all parts from Suzuki and Harley..and the home made stuff...I didn't have any plans of drawings, just built it from a picture in my mind and the primary drive design idea from the McEvoy/Martinez Triumph double..The engines are offset 3/4 inch to the left of center line and with the big clutch and chain drive hanging off the left side I had some concern the bike might drift left at speed...The rider said it goes straight down the track and can be steered slightly if necessary to stay on course...He also said it's a very intense internal combustion experience....
I recently had a discussion with the man who built the the Moto Guzzi that holds the Bonneville MPG1000 record of 150 MPH. The Guzzi was timed at 159 during non record runs in the same trim running in altered class....He says the engine makes 78-83 HP on a Superflow dyno....Both my Triumphs were run on a Superflow ...It's a eddy current machine that read about 10 percent less than the more common inertia Dynojet....The numbers I give here are Dynojet conversion because guys like to compare numbers.... The double has 87 Superflow HP (the 650 bike has 49 Superflow HP) So depending on drag and air density ....155 or so should be realistic for the Double Triumph...
Re: Working on the double Triumph... [Re: Hillbilly bike] #729119
03/19/18 2:19 am
03/19/18 2:19 am
South cone
reverb Offline
reverb  Offline
South cone
...did you do something to keep the oil inside? I mean; for example putting the ball bearings under the studs?
I have in two bikes a leak under the head and possibly is from a stud.
--there s a guy with some clips in ytube that has a Trident replica of the 70s Triumph racers done by R North. He was riding in the Isle of man with the camera in front of the clocks and into the town at some point he s riding at 154MPH!
Moderated by  Allan Gill
