ludwig
ludwig
belgium
19 registered members (Alan_nc), 185 guests, and 402 spiders.
Mums, MyrtleBeezer, Crockermc, mpotter78, Frezz
10485 Registered Users
NickL 97
franko 89
Triless 65
752,359 mail-order LSR
Topics68,895
Posts671,100
Members10,485
bottom of kick lever part? #728538
03/14/18 1:48 am
03/14/18 1:48 am
Smackinthemiddle, NJ
rocketscientist Offline OP
At the bottom of the kickstarter, where it goes through the 90 degree / wedge part. At the bottom, there are grooves cut for a detent to index the lever (deployed vs. stowed).
Is that a pin and spring? I have nothing there......
Support your #1 Velocette Forum
Velocette Motorcycles on e-Bay UK, Velocette motorcycles on e-Bay North America
Re: bottom of kick lever part? [Re: rocketscientist] #728557
03/14/18 11:09 am
03/14/18 11:09 am
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
You're missing this special spring washer -it's like a flat spiral going through about 720 degrees (I forget what they are called), and a special washer with a depression pressed in it that mates with the grooves in base of the black housing, (scuse fingers!) -it also has little tabs on the inside diameter that slide into those grooves in the base of the main lever.
When it's all bolted up causes the 'detent' to hold the lever in / out when it rotates.
(Hard to describe really!). Assembly as follows: slide the housing onto the main lever, followed by the 'detent washer' so that the indents in the washer fit into the corresponding depressions in the housing, and the little tabs slide into the slot, then the spring washer, then a plain washer and bolt.
Gawd it sounds all a bit long-winded eh?! Make sense?
Re: bottom of kick lever part? [Re: rocketscientist] #728565
03/14/18 1:32 pm
03/14/18 1:32 pm
Ewing. NJ
E
edunham Offline
edunham  Offline
E
Ewing. NJ
It has been awhile since I was into the kickstart on my Venom, but I don't remember any of those bits! Was there a design change between the early MACs and the Venom?
Ed from NJ
Re: bottom of kick lever part? [Re: rocketscientist] #728632
03/14/18 10:57 pm
03/14/18 10:57 pm
Make perfect sense. thank you . Now i need to just find the spring and tab/washer.
Part number????????? source?
Re: bottom of kick lever part? [Re: rocketscientist] #728635
03/14/18 11:23 pm
03/14/18 11:23 pm
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
Yes Ed, these were used only on the old ones (Pre 1946 I think)
Sorry I can't help with a source, but part numbers are as follows:
A278 -"Clickwasher for swivelling footstarter crank"
A254/2 -"Springwasher for swivelling footstarter crank"
I'd be surprised if you couldn't track down a suitable springwasher at good fasteners outlet, size is: I.D. 5/8", O.D. 1", Approx 3/8" thick uncompressed
And it wouldn't be too hard to fabricate the clickwasher.
Re: bottom of kick lever part? [Re: rocketscientist] #728672
03/15/18 12:24 pm
03/15/18 12:24 pm
Thanks J: mine bike is a a1952 rigid MAC. Its the older style gearbox. I just made a "click washer". 1" od washer, drilled the center to 5/8? ground a piece of welding rod to a "D" sections. Laid is across and welded it in, then took out a little center piece. works fine. Still no washer. I'm going to cut a piece of 5/8 heater hose (heavier wall than garden hose), and let that be my spring. should work fine....
Mike
Re: bottom of kick lever part? [Re: rocketscientist] #728722
03/15/18 11:26 pm
03/15/18 11:26 pm
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
I like that M, ingenuity - job done!
Re: bottom of kick lever part? [Re: rocketscientist] #728730
03/16/18 1:42 am
03/16/18 1:42 am
now that I have it together........something doesn't look right. It pretty much is the only way that it goes together, all the pieces that came out went back in!
Seems that I've seen MACS with the same gearbox; with the kicker up, pointing at 11, 12 and over the top at 1 o'clock. What gives?
Mine looks like the nut for the pin hits the stop at the top of the ramp. Can this be right?
Or will it stop in a different position , when installed on the gearbox?
Attached Files 20180315_202939_resized.jpg20180315_202945_resized.jpg20180315_202953_resized.jpg20180315_185928_resized.jpg
Re: bottom of kick lever part? [Re: rocketscientist] #728775
03/16/18 1:50 pm
03/16/18 1:50 pm
Ewing. NJ
E
edunham Offline
edunham  Offline
E
Ewing. NJ
Can you put the pin in from the other side so that the nut is on the backside?
Ed from NJ
Re: bottom of kick lever part? [Re: edunham] #728782
03/16/18 3:35 pm
03/16/18 3:35 pm
Ed from NJ
no. holes are different sizes. I looked at my "before" picts, and its in the same place as before disassembly. I've looked at other same vintage MACs. the kick start mechanism changes....but the ones that "look" like mine, clock in a multitude of different positions.......
Re: bottom of kick lever part? [Re: rocketscientist] #728808
03/16/18 8:51 pm
03/16/18 8:51 pm
Ewing. NJ
E
edunham Offline
edunham  Offline
E
Ewing. NJ
Is the pin an off the shelf cotter, something made by Velo, or something home made? I am wondering if you can either get a pin with a smaller diameter threaded portion or make a nut with a smaller hex? By the way is the nut fully home?
Ed from NJ
Re: bottom of kick lever part? [Re: rocketscientist] #728824
03/16/18 10:58 pm
03/16/18 10:58 pm
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
Looks like the cotter pin is too long - shouldn't be that amount of thread above the nut.
The housing ramp may be worn, resulting in contact with the cotter nut.
But that would affect the kickstart engagement too, you'd need to assemble it on the 'box to check it.
A thinner nut and washer would help obviously.
Re: bottom of kick lever part? [Re: rocketscientist] #728927
03/17/18 7:53 pm
03/17/18 7:53 pm
I am officially a "dope". holes were the same size, I just put the cotter in from the wrong side. All is right with the world. Ed had it right!
Down on the kicker, the gear moves out......lever up, the ramp pulls the gear in. 5/8 rubber spring works pretty well.
Attached Files 20180317_153143_resized.jpg20180317_153136_resized.jpg20180317_153003_resized.jpg
