mikefreinberg
mikefreinberg
Santa Cruz CA
21 registered members (BeezaBryan), 185 guests, and 54 spiders.
locobeta, Walt, DennisMartin, Dwight V, urbanghost
10387 Registered Users
NickL 98
Triless 88
reverb 82
Rohan 80
Mori55 79
Stuart 77
DavidP 72
btour 66
690,422 mail-order LSR
Topics68,045
Posts662,077
Members10,387
DBD rod side play #728120
03/09/18 5:54 pm
03/09/18 5:54 pm
Pacific NW
9
998John Offline OP
998John  Offline OP
Pacific NW
I have a customers DBD engine where build that was started several years ago. It has a new Alpha pin and Carrillo rod installed.
Not comfortable the side play of the rod, the crank was disassembled.
There is excessive side play between the rod and thrust washers. I can not get a feeler gauge between the pin shoulder and the crank.
The rod width is .873 and the distance between the thrust washers is .915 The outside shoulder to shoulder of the Alpha pin is 1.000.
Am I correct in thinking that the thrust washers are extremely warn? I don't know how thick a new thrust washer is.
Re: DBD rod side play [Re: 998John] #728156
03/09/18 10:35 pm
03/09/18 10:35 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
The pin shoulders are supposed to butt up to the crank as the taper seats. Chances of that happening with a new crank and pin=almost nil, Chances of that happening with a 60 year old crank=about the same as the pope getting pregnant
BSA B31 500cc "Stargazer"
Greeves 200cc "Blue Meanie"
Greeves 360 Challenger
Jawa 500cc "Llareggub"
'35 OK Supreme
'36 OK Supreme
Re: DBD rod side play [Re: 998John] #728158
03/09/18 10:37 pm
03/09/18 10:37 pm
County Durham
ducati2242 Offline
ducati2242  Offline
County Durham
The only crank i have available to check is a used one that i discarded for use myself . There is no play on the up and down movement but there's at least 1 mm of side to side movement . Could be worn but I never checked my new crank for side to side so dont know the as new tolerance your looking for . Someone will come along with the correct answer im sure .
Re: DBD rod side play [Re: 998John] #728164
03/09/18 11:29 pm
03/09/18 11:29 pm
Pacific NW
9
998John Offline OP
998John  Offline OP
Pacific NW
This crank has .042 rod side play (.915 - .873) The BMS book quotes .010 to .012 side clearance. This still leaves .030 too much side play.
I would like to find what the thickness of new thrust washer are to compare with those on this crank.
Re: DBD rod side play [Re: 998John] #728240
03/10/18 9:39 pm
03/10/18 9:39 pm
Elko, Nevada USA
dave - NV Offline
dave - NV  Offline
Elko, Nevada USA
John .. FWIW .. Several years ago I was fitting a new OEM crank pin into a used spare set of DBD flywheels. This was following a crank pin failure at moderate RPM that ruined a flywheel. The pin failed across the oil hole on the timing side as has happened to others. aargh. As Andy has mentioned the engineering 'dream' of the flanges bottoming simultaneous with the tapers is near impossible.
I had noticed the 'classic' fretting marks in the wheel tapers due to the wheels movement 'breathing' on the pin. I decided to lap in the pin to the wheels. My local machinist friend attempted to spin the pin in his mill with poor results, so I resigned myself to laboriously lap the pin in by hand using valve lapping compound. This took many hours of work and when finished I found the side clearance of the rod to be nil. I then had my local auto machine shop grind and narrow the rod side faces for 15 thou clearance that worked OK.
BTW, shortly after this exercise I ordered up my first Phil Pearson crank, rebuilt the engine and rode off with a big smile. BomBom Barroom. "Let The Goldie Sing" heh.
Speaking of Phil's cranks.. I've recently received one of his pressed up '5 main bearing' cranks in modified cases for my current Clubman project. A shame to hide them away, Jewelry!
Dave - NV
Re: DBD rod side play [Re: 998John] #728248
03/11/18 12:30 am
03/11/18 12:30 am
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
The rigidity of the Pearson crank makes for a very smooth engine. 80 mph cruising would be effortless and pleasant on my B31
'35 OK Supreme
'36 OK Supreme
Re: DBD rod side play [Re: 998John] #728254
03/11/18 3:05 am
03/11/18 3:05 am
Pacific NW
9
998John Offline OP
998John  Offline OP
Pacific NW
I will install new thrust washers and rivets, then see what the side play is. Grinding the shoulders on the pin will be the last option.
Lapping the taper may require a skim off the flywheels. I just don't want to box myself into a corner.
Re: DBD rod side play [Re: 998John] #728277
03/11/18 11:18 am
03/11/18 11:18 am
Middle East,
Kerry W Offline
Kerry W  Offline
Middle East,
As an enthusiast, rather than a professional engineer, I see the 'jiggery-pokery' of adjusting flywheels and pin to gain an acceptable fit as a short-term solution while one saves for a good crank! How many OEM pins actually fitted tapers in cranks that resulted in the shoulder being pulled up against the wheel when the nuts were done up tight? Not so many, I suspect...
I did have a very good (possibly never rebuilt) set of B33 flywheels (so probably never overstressed repeatedly either) and a brand new BSA-made (GS) pin...it went straight to the shoulder without much torque on the nuts...that said, it did get revved mercilessly for several seasons as a road-racer and never failed or produced high vibrations, excessive side-play, etc...it then sat, though was run regularly, for the next 10+ years before going to a new home, where I believe it has still to be rebuilt and is used regularly..
Peace of mind rests in a new cranks though, especially if it's in original (and number-matched) cases and used as they were intended...
Oliver Wendell Holmes
Re: DBD rod side play [Re: 998John] #728297
03/11/18 4:52 pm
03/11/18 4:52 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
I cannot stress enough, when rebuilding a crank place the rod in a suitable bin and BUY A NEW ROD.
Using an 60 year old rod is a sure way to make the "matching numbers" bike into a "non matching numbers" bike. A couple of hundred quid spent on a Carrillo (or similar) rod is cheaper than a scrapped engine. A leg out of bed will probably take out everything below the head gasket
'35 OK Supreme
'36 OK Supreme
Re: DBD rod side play [Re: 998John] #728299
03/11/18 4:55 pm
03/11/18 4:55 pm
montreal
johnnie690 Offline
johnnie690  Offline
montreal
I measured 2 sets of NOS connecting rod side thrust shims and they are .120 to .122 just to give you an idea what they started out as .
Re: DBD rod side play [Re: johnnie690] #728357
03/12/18 1:56 am
03/12/18 1:56 am
Pacific NW
9
998John Offline OP
998John  Offline OP
Pacific NW
johnnie690, Thanks for the info on new thrust washers. That will help determine what to do next. As I said before, I have a new Alpha pin and a new Carrillo rod so the customer wants to try and save the crank.
When I get to my Catalina, it will get a Pearson crank for sure.
Re: DBD rod side play [Re: 998John] #728364
03/12/18 2:36 am
03/12/18 2:36 am
montreal
johnnie690 Offline
johnnie690  Offline
montreal
998John, the Carrillo rod is the same width at the big end as is an original rod and the 1" shoulder to shoulder measurement of the pin is also the same as original parts.So that said it could very well be the thickness of the thrust washers.
Re: DBD rod side play [Re: 998John] #728555
03/14/18 10:51 am
03/14/18 10:51 am
Pacific NW
9
998John Offline OP
998John  Offline OP
Pacific NW
The thrust washer thickness checks out ok. Next plan will be putting a shim behind them. Won't know that thickness until the taper is lapped. Then making sure the shoulder on the pin is home at the same time the torque limit is reached. Fun Fun
Re: DBD rod side play [Re: 998John] #728570
03/14/18 2:24 pm
03/14/18 2:24 pm
city island ny
H
hunter h Offline
hunter h  Offline
H
city island ny
cheers I had crank with a Alpha pin and a Carrillo rod that needed work so it was sent back to Alpha and was made right . you could send the crank to them for the right fix. the can make a new over size crankpin if needed they did a great job. by the way i have two of Phil,s cranks .The stock parts could be sold to help cover costs of new. hunter
Re: DBD rod side play [Re: 998John] #728581
03/14/18 4:29 pm
03/14/18 4:29 pm
Pacific NW
9
998John Offline OP
998John  Offline OP
Pacific NW
Thanks Hunter, a bit over budget for this project so will mover forward in house. I have full machine shop capabilities including surface and od grinding.
It will be a learning experience to say the least.
