Huntmaster
Huntmaster
Ottawa, Canada
40 registered members (Alan_nc), 244 guests, and 472 spiders.
10257 Registered Users
Lannis 60
TBolt72 46
609,192 mail-order LSR
Topics67,120
Posts651,371
Members10,257
Can I swap A65 primary chaincases between years? #728213
03/10/18 2:23 pm
03/10/18 2:23 pm
Near York, UK
JonnyD Offline OP
JonnyD  Offline OP
Near York, UK
Hi I have a 1965 A65 Rocket that is fairly original. It has the very old style primary chaincase, part number 68-0240.
I've been offered a very late one, with the rotor inspection cover and the 2 Phillips screws for oil level and oil drain. It's part number is 71-1045.
Can anyone tell me whether or not it will fit?
Just by the way, the various old BSA parts manuals I have seem to list the following as other part number for this item
Approx 1966 68-0720
Approx 1967 68-837
Late, not sure when 70-9112.
Thanks very much for any help
Jon
Re: Can I swap A65 primary chaincases between years? [Re: JonnyD] #728258
03/11/18 4:09 am
03/11/18 4:09 am
Mark Z Offline
Mark Z  Offline
Any cover will fit, but one thing to check, the covers became a bit bulgier in the clutch area at some point. When I fit a later cover on my bitsa (not sure what year the cover is from), the '66 footrest hit it when mounted. I can't say for sure that the footrest was never bent inward, but it did fit with the '66 primary cover. I solved the problem by having the footrest heated and re-shaped. I'd be interested in knowing if you run into this problem.
Re: Can I swap A65 primary chaincases between years? [Re: JonnyD] #728279
03/11/18 11:38 am
03/11/18 11:38 am
Near York, UK
JonnyD Offline OP
JonnyD  Offline OP
Near York, UK
Thanks very much for your advice! Very helpful.
Jon
