51 registered members (998John),
352
guests, and 729
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics67,491
Posts669,173
Members10,574
Most Online3,995 Feb 13th, 2017
Re: Robs engine rebuild help thread
[Re: Manx]
#732228
04/17/18 9:22 pm
04/17/18 9:22 pm
Posts: 225 Norway
Manx
Norway
So I have booked myself in to a motorcycle show on Saturday, in the riden to the show catogory and I havn`t even fired her up yet! Made some fittings for the right hand pipe, hopefully do the other side tomorow. Unfortunatly the hole in the frame is in another possition on the left hand side to make room for the rear light switch so I cant just measure the stuff I made tonignt. ![[Linked Image]](https://i.imgur.com/Oil9E6w.jpg) ![[Linked Image]](https://i.imgur.com/TAJZVfS.jpg) ![[Linked Image]](https://i.imgur.com/VA3zZCB.jpg) I think it will be pretty sturdy when the tie bar is fitted to the headers, Made the bracket out of 3.5mm stainless. I kicked them up slightly which is how they are fit on a picture I found in the Metisse book. Loads of room for the clutch cable and exhaust is off my leg for when standing on the pegs.
1966 Rickman Metisse (a65) 1957 B33 1959 lambretta li 150 1960 lambretta li150
[Re: Manx]
#732389
04/19/18 7:07 am
04/19/18 7:07 am
Posts: 225 Norway
Manx
Norway
Tonights the night!
Going to (try) and fire her up. I just need petrol...
Wish me luck
[Re: Manx]
#732395
04/19/18 8:48 am
04/19/18 8:48 am
Posts: 225 Norway
Manx
Norway
I have fit internal baffels but bet that its still pretty loud.
Life is to short to worry about my neighbours.... haha
[Re: Manx]
#732480
04/20/18 7:41 am
04/20/18 7:41 am
Posts: 225 Norway
Manx
Norway
AARRRGGGHH!
So. Last night I was going to fire her up.
I am Running Electrex world 12v kit.
I had an ok spark 4-5 kicks, then nothing.
This kit works by charging a capasitor from the rotor, and the 65w to the lights.
I think the capasitor had som charge in it (which is why it fired a couple of times) and the CDI has either died or stator isn`t giving any charge.
Stripped the bodywork last night and disconnected the kill switch to eliminate that and nothing. completely dead.
[Re: John Healy]
#732791
04/23/18 6:31 am
04/23/18 6:31 am
Posts: 225 Norway
Manx
Norway
No!
I have absolutley no spark.
Dead.
I have orderd a new CDI, I ohmed the stator and that is working.
[Re: Manx]
#733346
04/28/18 6:06 am
04/28/18 6:06 am
Posts: 225 Norway
Manx
Norway
Got the new cdi yesterday! I'll strobe the timing today and tweak the carb.. maybe even take her for a ride. [video:youtube] https://youtu.be/XuzCq-2Y-Wo[/video]
[Re: Manx]
#733857
05/02/18 9:12 pm
05/02/18 9:12 pm
Posts: 225 Norway
Manx
Norway
Thanks PRT. I went for the first ride today. The bike feels solid, the gears are easy to select, sounds nice and the suspension works well. My lights don't work so I'm currently searching for a loose connection or bad earth but it's running very rich. Pulls like a train up to half throttle but burbles and blows black smoke. I took off the filter but that didn't help so I moved the needle down a clip to see how that works out. Luckily with the single carb set up, I only need to take off the tank to get to the carb ( just one screw). I have a small oil leak in the rocker feed hose but otherwise it seems fantastic. Starts first kick and nice tickover at idle. Could someone explain what the 2 screws do on the AMAL (pilot and air) ? I'm not quite sure how U should set them?
[Re: Manx]
#734053
05/04/18 10:53 am
05/04/18 10:53 am
Posts: 4,351 argyll. scotland, uk
gavin eisler
The horizontal screw controls the pilot mixture, screw in to make richer, out for leaner, the angled screw is the throttle stop and controls idle speed.Once the motor is warmed up ( after a short run) not just a few seconds of throttle blipping, adjust the pilot mixture screw to give the highest idle, then lower the throttle stop screw to the desired idle speed. Typical pilot screw settings are one to 1.5 turns out from fully closed in.
71 Devimead A65 750 56 Norbsa 68 Longstroke A65 Cagiva Raptor 650 MZ TS 250 The poster formerly known as Pod
[Re: Manx]
#741142
07/08/18 10:35 am
07/08/18 10:35 am
Posts: 225 Norway
Manx
Norway
Bollox. My second electrex world ignition went belly up and I ended up re-wireing the bike again but this time I went for a Pazon ignition system with a battery and rotor/stator and dyna coil. Simplyfied wireing as per lowbrow customs diagram. The bike just farts, burps and pops. It wont start, even if I try bumping it. The battery was low yesterday 10.4v but I think that might be normal after 300 kicks and pushing the bike around the block a few times. One fault I found was that the Pazon trigger was dragging on the crankshaft seal and moving position, so I measured an old Boyer trigger and put the pazon on my lathe so it now fits as it should. I`m going to swap petrol and change the plugs but i`m seriously starting to loose hope on this engine. I can`t figure out why she wont start. just so frustrating.
[Re: Manx]
#741159
07/08/18 2:12 pm
07/08/18 2:12 pm
Posts: 1,754 Mississauga, Ontario.
Adam M.
It was starting before without a problem, wasn't it ? Using Electrex ignition. Are you sure everything is all right with your AMAL carb, you complained in former posts about excessive richness ? Perhaps your petrol level is too high for some reason ? Or your idle circuit got clogged ? I'd take a carburetor off the engine and check it, those engines with one carb should start with one or two kicks every time. If they dont, something isn't right.
[Re: Manx]
#741178
07/08/18 4:25 pm
07/08/18 4:25 pm
Posts: 225 Norway
Manx
Norway
I charged the battery last night and because of the problem with the trigger yesterday I had really given up.
Started second kick
[Re: Manx]
#741206
07/08/18 8:21 pm
07/08/18 8:21 pm
Posts: 225 Norway
Manx
Norway
Went for a ride today, just lovely.....
Until I was going to start it again.
I think something has let go in my motor. It will only turn 30 degrees back or forth.
Gutted.
[Re: Manx]
#741271
07/09/18 11:07 am
07/09/18 11:07 am
gavin eisler
Your motor is so fresh, its hard to imagine a main component letting go, may be something as simple as a jumped push rod, a quick look in the rocker box will help narrow stuff down. Was it running OK when it was last shutdown?
[Re: Manx]
#741363
07/10/18 5:45 am
07/10/18 5:45 am
Posts: 225 Norway
Manx
Norway
Stripped the motor last night and found that the tip of one of the cam followers was gone!
So lucky that it happend, when it happened. I found it with an inspection camera and manage the to dislodge it out of a balancing hole with the camera and a piece of wire.
This must be a first! Case looks good as it was stuck behind the oil pipe that leads to the sump.
Need to find some followers now asap so I can get it going before my summer holidays.
[Re: Manx]
#741364
07/10/18 5:46 am
07/10/18 5:46 am
Posts: 225 Norway
Manx
Norway
Posted twice...
[Re: Triless]
#741367
07/10/18 7:28 am
07/10/18 7:28 am
Posts: 225 Norway
Manx
Norway
Original follower that had been re-ground locally.
Those tips are hard, could have done a lot of damage if it let go while riding 90km/h.
I think I was very lucky. or very unlucky, depending on how I look at it.
[Re: Manx]
#741368
07/10/18 7:41 am
07/10/18 7:41 am
Posts: 1,329 Bolton Lancs UK
Andy Higham
Bolton Lancs UK
Did the whole foot break off or did the stellite pad become detached?
BSA B31 500 "Stargazer" Greeves 200 "Blue Meanie" Greeves 350 Greeves 360 Suzuki GSX1100 EFE "Sorcerers Apprentice" GM500 sprint/LSR bike "Deofol" Jawa 500 "Llareggub" Aprilia RSV Mille "Lo Stregone" '35 & '36 OK Supreme Kawasaki ZZR1400 "Kuro no senshi"
