sawtooth
sawtooth
New York
Support Your #1 Forum
Buy BritBike's staff a coffeeStill here since 1996.. Click here to buy BritBike staff a coffee.
86 registered members (998John), 559 guests, and 765 spiders.
sivaraj, LarryL, chickin, Hill Easterwood, Stanier8F
10611 Registered Users
franko 123
Mori55 77
koan58 71
NickL 68
reverb 65
830,383 mail-order LSR
Topics67,819
Posts671,852
Members10,611
Gearchange Camplatebut does it work? #727058
02/28/18 1:06 pm
02/28/18 1:06 pm
UK - Bucks
Steve Wilson Offline OP
UK - Bucks
Looking for advice on A65 gearboxes :-) (1971 Thunderbolt)
Mine seems Ok but has never had a slick change. Clutch is mostly rebuilt - light - not dragging.
Engine is apart at the moment so there's an opportunity to tinker
I have seen stepped Camplates for sale - claimed to help gear selection by supporting the selector forks better - sounds logical but does it work?
Last edited by Steve Wilson; 02/28/18 1:08 pm. Reason: Didnt get the last sentance in!
SJW
Re: Gearchange Camplatebut does it work? [Re: Steve Wilson] #727078
02/28/18 3:56 pm
02/28/18 3:56 pm
gavin eisler Online content
gavin eisler  Online Content
Stepped?, later cam plates were braced with a stiffening strap, its better than not having a stiffening strap. you can lighten the change by polishing all the surfaces where the selector forks run, cam track and cam track shoulders., layshaft end float makes most difference , set to 3 thou, as found its usually a lot more, needing a thicker shim at DS end of layshaft, BSA offered 2 oversizes on this shim, the fattest one usually does it, the closer to 3 thou ( but no less ) the better it gets. Cutting 2 turns off the cam plate plunger spring make the change better, do all three, polish cam plate, shim Lay shaft. trim spring, and it will feel much better to use.
David drew sells lovely ball ended cam plate plungers on eBay, these prevent the plunger ploughing into the cam plate, this is usually where you see most obvious wear, it can be repaired by welding, reprofiling. if the rest of the plate is sound.
Re: Gearchange Camplatebut does it work? [Re: Steve Wilson] #727085
02/28/18 5:07 pm
02/28/18 5:07 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
The shift forks are supported by the rod, the camplate only provides the side thrust.
The track around second gear is usually worn the most because of the shorter radius from the camplate pivot and steep angle required for the movement.
The slots look to be sheared out and are very rough so what Gavin said will help but do not go too far as it increases the fork slop.
A worn camplate that I have shows all of Gavin's comments: rough tracks, groove in the detent path and wear grooves around the plunger windows.
Re: Gearchange Camplatebut does it work? [Re: Steve Wilson] #727094
02/28/18 6:27 pm
02/28/18 6:27 pm
i find the wear around the plunger windows is not so significant for a good change , sometimes it might even help a little, so long as the little pawls are not chipped, that does make a huge difference. As DMadigan says, the cam track slots have an obvious depression one side and up pull on the other from the shear process, flattening the "up pull" on 150 grit stuck to a flat surface, then light polishing with 200 down to 400 grit works, its easy to make them much better , how much is up to you. If you find rough spots on the cam plate track selector fork track roller surfaces a small wooden dowel split and wrapped with a bit of 200 grit then 400, spun in a drill will do the job ..
Re: Gearchange Camplatebut does it work? [Re: Steve Wilson] #727121
02/28/18 11:35 pm
02/28/18 11:35 pm
Australia
NickL Online content
NickL  Online Content
Australia
The last of the camplates were indeed stepped, i've just fitted a new old stock one to the engine on my bench.
They were the best of 'em but hens teeth now. (57-2767)
The ones with the brace were around for a few years but were replaced by a thicker one in about '70. Then the stepped one in late '71
The brace part never seemed to make any difference, it's the track shape that improved things.
What Gavin says.
Shimming the layshaft end-float is very important. As is the condition of the camplate tracks, getting full engagement of the dogs
especially in 2nd is the thing to aim for. Grip the end plate in a vice and go through the gears with it assembled you'll see what is required.
Sometimes the camplate needs shimming in the end plate as well. The poor parallel dogging of this box needs all the help it can get.
An outrigger bearing setup will also improve shifting as it helps stop the bowing in the mainshaft.
Life is much too important to be taken seriously.
Re: Gearchange Camplatebut does it work? [Re: Steve Wilson] #727136
03/01/18 1:50 am
03/01/18 1:50 am
I didnt know that about the strap being earlier than the step,,live and learn,. my bike came with an assortment of plates, was never sure what year was what. I think the last 4 speed one I got from SRM was stepped when I look back, more chunky and a less sloppy fit.That was circa 1985 it lasted well. shows slight grooving on the plunger track , I spent a couple of hours spiffing it up around 2000 , noticed a big improvement to the change .
Re: Gearchange Camplatebut does it work? [Re: Steve Wilson] #727319
03/02/18 9:58 pm
03/02/18 9:58 pm
UK - Bucks
UK - Bucks
Thanks Guys. I think Burton Bike bits have the stepped ones in stock. Will look at the end float as well.
SJW
Re: Gearchange Camplatebut does it work? [Re: Steve Wilson] #727327
03/02/18 11:57 pm
03/02/18 11:57 pm
Australia
Australia
When using that camplate, you should check it doesn't foul the bottom of the cases in the box when 4th is selected.
You may need to get the file out.........................
Re: Gearchange Camplatebut does it work? [Re: Steve Wilson] #727608
03/05/18 9:35 am
03/05/18 9:35 am
UK - Bucks
UK - Bucks
Thanx
SJW
Re: Gearchange Camplatebut does it work? [Re: NickL] #730886
04/04/18 9:51 pm
04/04/18 9:51 pm
UK - Bucks
UK - Bucks
Well - I checked out the old camplate and decided it could be used. Polished it up as suggested. Ran a dremel round the selector tracks. When the bearings turn up I will sort out the end float.
SJW
Re: Gearchange Camplatebut does it work? [Re: Steve Wilson] #730895
04/04/18 11:27 pm
04/04/18 11:27 pm
Australia
Australia
The thing to check with the camplate is the fit of the selector rollers in the tracks as well as the plunger face.
2nd and 3rd gear are where most wear occurs, that's where the fit of the rollers needs to be good, when the plate
wears the dogs don't engage properly and it'll jump out of gear or just knacker/round off the dogs.
With the box assembled and held i a vice, you can easily check all this.
Re: Gearchange Camplatebut does it work? [Re: Steve Wilson] #731772
04/13/18 9:15 am
04/13/18 9:15 am
UK - Bucks
UK - Bucks
All back together now - just perceptible play on layshaft and polished camplate - fingers crossed
Bit off topic but - How would the panel suggest I do up the gearbox sprocket nut? Neets 100Lb/ft - Can't lock it up and can't get a socket on it!
SJW
Re: Gearchange Camplatebut does it work? [Re: Steve Wilson] #731833
04/13/18 11:16 pm
04/13/18 11:16 pm
Australia
Australia
Buy an old fashioned 'box/tube spanner' they are cheap enough and use a big tommy bar in it.
Re: Gearchange Camplatebut does it work? [Re: Steve Wilson] #731837
04/14/18 12:19 am
04/14/18 12:19 am
Tridentman Online content
Tridentman  Online Content
Steve--the BSA specialists all sell the box spanner/wrench that Nick refers to.
Used to be made by Metco in UK if I remember correctly.
Re: Gearchange Camplatebut does it work? [Re: Steve Wilson] #731856
04/14/18 4:15 am
04/14/18 4:15 am
Mark Z Offline
Mark Z  Offline
Hmm, easier before the gear cluster goes in (I know, hindsight is 20-20).
And don't worry too much about an exact torque spec - just get it as tight as you can; the locktab washer does a good job of keeping it in place.
Re: Gearchange Camplatebut does it work? [Re: Steve Wilson] #731883
04/14/18 5:39 pm
04/14/18 5:39 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
If you cannot find a boxtube spanner you can weld a 1/2" drive 1" socket on the back of a 3/4" drive 1.5" socket. That will get you over the mainshaft to secure the nut. To hold the sprocket. weld or pin a piece of old chain on the end of a bar and wrap the chain around the sprocket.
Re: Gearchange Camplatebut does it work? [Re: Steve Wilson] #731893
04/14/18 7:31 pm
04/14/18 7:31 pm
Bolton Lancs UK
Andy Higham Online content
Andy Higham  Online Content
Bolton Lancs UK
For my B31 I bought a cheap 3/4" square drive impact socket, I bored the square out to clear the mainshaft and milled a hexagon on the outside.
I put another socket on the hexagon and used my battery rattle gun to tighten the sprocket
[Linked Image]20160302_171443_zpssscfo0ky by Sigma Projects, on Flickr
Re: Gearchange Camplatebut does it work? [Re: Steve Wilson] #731907
04/14/18 10:54 pm
04/14/18 10:54 pm
I use a Mini ball joint socket, https://www.minispares.com/product/classic/TOOL03.aspx not this one, mine is poorer looking, careful mini owners will borrow it.
Re: Gearchange Camplatebut does it work? [Re: Steve Wilson] #732211
04/17/18 7:02 pm
04/17/18 7:02 pm
Pittsburgh,Pa.
Redd32 Offline
Redd32  Offline
Pittsburgh,Pa.
Is the camplate hardened? Could it be welded up and reshapped?
Re: Gearchange Camplatebut does it work? [Re: Steve Wilson] #732216
04/17/18 7:30 pm
04/17/18 7:30 pm
Not very, judging by the way the plunger can plough through it.
Yes, weld up the wear and grind/ polish back to profile.
Re: Gearchange Camplatebut does it work? [Re: Andy Higham] #732868
04/23/18 10:26 pm
04/23/18 10:26 pm
UK - Bucks
UK - Bucks
Did something similar in the end - but I don't think you need to bore the centre out (I didn't) if its 3/4" drive. I just cut two flats and used an adjustable spanner and a torque wrench. Would have cut all six flats but the socket moved in the machine vice and took out the cutter! Locked the sprocket with chain round it .
SJW
Re: Gearchange Camplatebut does it work? [Re: Mark Z] #732869
04/23/18 10:27 pm
04/23/18 10:27 pm
UK - Bucks
UK - Bucks
Thanx for that - I'm not certain I torqued it up right but used Loctite and the lockwasher !!
SJW
Re: Gearchange Camplatebut does it work? [Re: Redd32] #732870
04/23/18 10:28 pm
04/23/18 10:28 pm
UK - Bucks
UK - Bucks
My camplate didn't seem to be. I draw filed it and you can usually tell
SJW
Re: Gearchange Camplatebut does it work? [Re: Andy Higham] #732871
04/23/18 10:32 pm
04/23/18 10:32 pm
UK - Bucks
UK - Bucks
I also machined about 1/8" off the front of the socket - its usually heavily chamfered and with the nit only being about 1/4" thick its not got much to grip.
SJW
