ludwig
ludwig
belgium
17 registered members (Alan_nc), 185 guests, and 424 spiders.
Mums, MyrtleBeezer, Crockermc, mpotter78, Frezz
10485 Registered Users
NickL 97
franko 89
Triless 65
752,359 mail-order LSR
Topics68,895
Posts671,100
Members10,485
Brake drum removal #726391
02/22/18 5:00 am
02/22/18 5:00 am
Omaha, NE, USA
Paul Sammut Offline OP
Omaha, NE, USA
Hi all,
I am switching out the drums on my Series C Rapide and was wondering if there is a secret to dislodging them from the hub once the nuts have been removed. There is mention of the special nature of the bolts, but little suggestion of how to remove them. Before I gently whack on them with piece of wood, I thought I'd ask the experts.
Thanks in advance,
Paul.
Paul
'74 Commando - Interstate
"74 Commando - Hi-Rider, possibly
'65 Atlas, mostly anyway
'15 R1200 GS Adv
'51 Vincent Rapide
'58 Ariel Square Four
Support your #1 Vincent Forum
Vincent Motorcycles on e-Bay UK, Vincent motorcycles on e-Bay North America
Re: Brake drum removal [Re: Paul Sammut] #726497
02/23/18 1:50 am
02/23/18 1:50 am
Bundaberg, Australia
ksbundy Offline
ksbundy  Offline
Paul, be very careful. I believe the bolt H19/1 has a round offset head which holds itself against the hub when tightening the nuts. Make sure that the bolts are loose in the hub and brake drum before you try to remove (bash) then out. I have seen a broken brake drum because of it. Ken
Re: Brake drum removal [Re: Paul Sammut] #726510
02/23/18 3:16 am
02/23/18 3:16 am
Omaha, NE, USA
Omaha, NE, USA
Thank you, Ken, just what I was afraid of. I shall proceed cautiously and with as few expletives as possible.
Paul
Paul
'15 R1200 GS Adv
'51 Vincent Rapide
Re: Brake drum removal [Re: Paul Sammut] #726798
02/25/18 8:07 pm
02/25/18 8:07 pm
Birmingham, UK
Twin Pot Phil Offline
Birmingham, UK
Hello Paul, further to what Ken advises, make sure all the bolts are removed out of the hub before attempting to remove the drum (its a pig of a job - I made a 'pusher outer' that looks like a deformed valve spring compressor as I got fed up with damaging the threads!).
The drums are FRAGILE (said VERY loudly) - they are cast iron, free the drum from the hub by trying to rotate the drum while the hub is held, wood is your only friend when dealing with these things.
Re: Brake drum removal [Re: Paul Sammut] #727027
02/28/18 4:41 am
02/28/18 4:41 am
Omaha, NE, USA
Omaha, NE, USA
Thanks, Phil. Job done. I am extremely grateful for expert advice.
Paul
Paul
'15 R1200 GS Adv
'51 Vincent Rapide
Re: Brake drum removal [Re: Paul Sammut] #727057
02/28/18 12:51 pm
02/28/18 12:51 pm
Birmingham, UK
Birmingham, UK
No problem, Hey I'm no expert - I just got the opportunity to successfully break things much earlier than you did - when I was very much younger and waaaayyy more stupid than I am now!!
