sawtooth
sawtooth
New York
22 registered members (andrei), 164 guests, and 437 spiders.
Mums, MyrtleBeezer, Crockermc, mpotter78, Frezz
10485 Registered Users
NickL 97
franko 89
Triless 65
752,359 mail-order LSR
Topics68,895
Posts671,100
Members10,485
What breaks on a Triumph 650 twin ? #726334
02/21/18 4:00 pm
02/21/18 4:00 pm
England
F
ferretjuggler Offline OP
F
England
I've got quite a good collection of unit 650 and 750 crankcases.
There seems to be two common areas of damage.
One is around the final drive sprocket and I can only blame this on poor maintenance, owners running chains that are worn out or of an inferior quality.
You can't really blame it on poor design.
The second common area of damage is in the crankcase mouth where the cylinder barrel fits.
I always thought that the most common cause of blow ups on old Brits was a broken rod.
Close examination of the cases I've got looks more like tappet failure - the damage seems to be on the centre line where the crankcase halves join, not in line with the bore centres.
Am I barking up the wrong tree here ?
Re: What breaks on a Triumph 650 twin ? [Re: ferretjuggler] #726336
02/21/18 4:37 pm
02/21/18 4:37 pm
triton thrasher Offline
We can't see what you're looking at.
Rods breaking for no reason isn't very common in road use.
Rods breaking because a bearing is seizing, maybe.
Re: What breaks on a Triumph 650 twin ? [Re: ferretjuggler] #726339
02/21/18 5:12 pm
02/21/18 5:12 pm
dave jones Offline
dave jones  Offline
I agree with Triton. The rods are ok if the bearings have oil. The big ends last forever, normally. I would say the weak point on a unit is the drive side main bearing. If the engine is put together carefully then this will last well. The guides and bores have to be really terrible to even make any smoke. It is a good engine.
Re: What breaks on a Triumph 650 twin ? [Re: ferretjuggler] #726340
02/21/18 5:29 pm
02/21/18 5:29 pm
Running from demons in WNY
Hillbilly bike Online content
Piston seizures ...almost always from poor tuning or lack of piston to cylinder clearance...Detonation caused cracked rings or pre ignition punching a hole in the piston...Again, poor tuning and or lugging the engine and or poor quality fuel are the causes..
I take off bike parts until it doesn't function, then put on just enough so it functions
Re: What breaks on a Triumph 650 twin ? [Re: Hillbilly bike] #726343
02/21/18 6:08 pm
02/21/18 6:08 pm
That lot is so common I'm not sure if it's classed as a blow-up!
Re: What breaks on a Triumph 650 twin ? [Re: ferretjuggler] #726349
02/21/18 7:13 pm
02/21/18 7:13 pm
HawaiianTiger Offline
I think you may be seeing evidence of ham fisted mechanics. The tappet holes in the case are sometimes broken out when people who don't know what they're doing try to separate the cases without removing the two special screws in the crankcase mouth.
It is an antique motor with antique design. It has high dome pistons and hemispherical combustion chambers when everyone else was going to flat top pistons, squish bands, narrow included valve angles, you know, modern engine designs.
Consequently, it suffers from incompatibility with modern fuels, more so that other designs. These things can be mitigated by applying some techniques during a rebuild.
All in all, I think it's the power characteristics and sound that people find pleasant and even fun. So, the bikes continue to be popular to a number of folks like us.Reliability is a factor, but no more or less than other bikes of the period.
Re: What breaks on a Triumph 650 twin ? [Re: HawaiianTiger] #726351
02/21/18 8:10 pm
02/21/18 8:10 pm
Those thin bits can break and it doesn't matter.
Re: What breaks on a Triumph 650 twin ? [Re: ferretjuggler] #726352
02/21/18 8:10 pm
02/21/18 8:10 pm
Naarfuk, UK
Tigernuts Online content
Tigernuts  Online Content
Naarfuk, UK
I reckon Bill's right, those two screws are easily overlooked by the ham-fisted fraternity. I have seen cases which have had these parts of the cadting busted off. I've never heard of a cam follower breaking, as in snapping. I have only come across the Stellite feet falling off, which is pretty inconvenient but doesn't tend to cause much damage in the bottom half.
Re: What breaks on a Triumph 650 twin ? [Re: ferretjuggler] #726353
02/21/18 8:23 pm
02/21/18 8:23 pm
People break the tappet blocks trying to remove them from the barrel.
Re: What breaks on a Triumph 650 twin ? [Re: ferretjuggler] #726354
02/21/18 8:46 pm
02/21/18 8:46 pm
Isle of Wight, UK
koan58 Offline
koan58  Offline
Isle of Wight, UK
I’ve not had a chain (rear or primary) break or derail on any bike (other than a pushbike) and in my early years I took chains and sprockets to Armageddon.
Worst example was a rear sprocket so rounded off that to get up the incline to Aust services, had to severely tighten the chain such that as it went round I could feel the tightspot bending the swingarm/frame.
It got me a coffee, and to Newport in Wales, where I got a new chain. This got me to and fro, back home (~200 miles) and the new chain was dead. Quite a few of the roller shells had cracked off.
So, apart from in racing, there is no excuse for chain breakage.
I suspect most instances derive from rear wheel alignment issues and/or putting the “U” clip either the wrong way or not securely in place.
I had 2 blowups in my juvenile years with p/u Triumphs, 1st at 18 when I employed meccano skills to a top end job, naively pressed small end bushes into the rods, and made them fit the pins using wet and dry.
That ended with a small end opening on the M4, but knocked along until I was down the A34, when it stopped abruptly. Hid it behind a bridge, hitched home, came back with a van a week later. Luckily, only damage to rods, barrels and pistons.
The next was with an alloy 500 p/u engine I bought as seen, newly rebuilt, and it did run beautifully while I was running it in for about a month in 1979. On the way to the pub with a few others, to discuss our biking holiday to celebrate finishing uni, it locked up, doing say 30 mph. After pushing it home and opening it up, can you imagine the gloom on finding that one of the cylinder sleeves had cracked near the top, and then pulled down into the crank area? What a mess. It didn’t damage the cases though.
Ended up exchanging those bits, plus an entire road legal but shoddy Norbsa, for the engine I have used ever since. A 6T case with T120 bits in and on.
Never needed to tear it down because of bottom end issues, the 3-piece crank is still standard grind.
Still using the same cams, tappets, rockers that came with it.
I’m not clear how tappet failure would damage the cases?
Bill’s clumsiness explanation may be the answer, in which case, if it hasn’t warped the case over a wider area, they should be ok.
I believe it was only the 650’s that still had the mouth screws?
Re: What breaks on a Triumph 650 twin ? [Re: triton thrasher] #726355
02/21/18 8:53 pm
02/21/18 8:53 pm
Yeah, just wait for it to cool a bit and it's good to go again....more ring leakage but it still goes..
Re: What breaks on a Triumph 650 twin ? [Re: ferretjuggler] #726365
02/21/18 11:22 pm
02/21/18 11:22 pm
Isle of Wight, UK
koan58 Offline
koan58  Offline
Isle of Wight, UK
The 650's do break crankshafts, it was never uncommon at race tracks both unit and pre-unit types.
3 piece and 1 piece. Many were badly re-ground i suppose but it was a triumph weakness.
I'd imagine that happens in racing conditions with any crankshaft. Why do you say it was a triumph weakness? In comparison with what?
If they were reground improperly, is that a triumph weakness?
What they do is go onwards.
Re: What breaks on a Triumph 650 twin ? [Re: NickL] #726369
02/22/18 12:05 am
02/22/18 12:05 am
Originally Posted by NickL
They broke with alarming regularity at race tracks, i had 3 go over 2 years. (i do admit one was badly ground and had a 'shoulder' on the journal)
The big end Journal is small on a triumph and allows much flexing. That was the weakness.
Nick, is the BSA drive side main is about .060 bigger than Triumph? It makes that much of a difference?
Re: What breaks on a Triumph 650 twin ? [Re: ferretjuggler] #726370
02/22/18 12:08 am
02/22/18 12:08 am
Isle of Wight, UK
koan58 Offline
koan58  Offline
Isle of Wight, UK
Fair dinkum Nick, but who was talking about racing, except when I allowed for the possibility by saying:
"I'd imagine that happens in racing conditions with any crankshaft."
Apart from boy racer times 40 years ago, I have no racing experience. What relevance does that have to the original subject?
The topic is a few crankcases, unless I'm much mistaken.
Re: What breaks on a Triumph 650 twin ? [Re: HawaiianTiger] #726376
02/22/18 12:47 am
02/22/18 12:47 am
England
F
F
England
Funny but I didn't think of that even though it's the most obvious explanation.
Looking at my "collection" none of the 750 cases have damage there.
I really can't believe that people would be so stupid but not everyone is as fussy as me.
And you can't see the damage with the engine assembled.
Re: What breaks on a Triumph 650 twin ? [Re: ferretjuggler] #726393
02/22/18 7:39 am
02/22/18 7:39 am
750s don't have the screws there, so far as I know.
Re: What breaks on a Triumph 650 twin ? [Re: ferretjuggler] #726431
02/22/18 5:25 pm
02/22/18 5:25 pm
Dibnah Offline
Dibnah  Offline
With some care and modern oil these dinosaurs have a few decades in them yet.
Re: What breaks on a Triumph 650 twin ? [Re: triton thrasher] #726434
02/22/18 5:57 pm
02/22/18 5:57 pm
England
F
F
England
That's exactly what I was implying.
IIRC when I assembled my '71 TR6C engine I deliberately left out those two screws.
The 750 twins dont have them, so I reasoned that they can't be critically important.
I won't have to struggle with them the next time the engine is stripped.
Re: What breaks on a Triumph 650 twin ? [Re: ferretjuggler] #726471
02/22/18 9:59 pm
02/22/18 9:59 pm
Naarfuk, UK
Naarfuk, UK
I really can't believe that people would be so stupid...
Sadly, judging by the horrors I've encountered when dismantling old British bikes, they are!
