Support Your #1 Forum
Buy BritBike's staff a coffeeStill here since 1996.. Click here to buy BritBike staff a coffee.
30 registered members (Alan_nc), 293 guests, and 262 spiders.
Fumi, brennan devine, sivaraj, LarryL, chickin
10613 Registered Users
franko 121
koan58 81
Mori55 72
reverb 64
NickL 60
831,727 mail-order LSR
Topics67,840
Posts672,060
Members10,613
Actual inverted oil seal photo #725865
02/17/18 12:36 am
02/17/18 12:36 am
In a NY state of mind
Hillbilly bike Offline OP
My rider took the double engine Triumph land speed racer to Maine for initial speed runs...I stayed home this time.....The bike ran 142 MPH on 5he initial run with the rider shutting down early ,, He figured more speed on an all out second run...But the bike was plagued by random carb flooding issues so he got off the throttle at about 130 mph and coasted down..he pulled over to get a time slip and notice the oil pressure on the front engine was about 10 at idle and 30 at speed.Both engine we seeing 40 at idle and 80 at speed as warmed up as they get in 1-1/2 miles of full throttle acceleration...At the track he and a friend pulled the side cover, checked oil flow from the tank , swapped OPRV's but saw nothing wrong and the oil pressure remained low .No more racing... The other race bike ran flawlessly ...
I finally got the bike over the my place and checked the sump screens cut open cartridge return filters....no bearing material, no other ugly crap...I pulled the side cover ... The seal blew out...Now it gets interesting, I have in my parts several PW seals...But the seal in the engine is a "SDA"... I turned the crank quill to .609 to clean up damage....015 below standard..I have PW POS2072 seals on the shelf... The ID is .590..I believe the interference fit is supposed to be at least .020...So I also had the SDA seals designed for a .020 undersize....Well the SDA seal failed.... I learned a lesson.....I betting there's no internal engine damage...
The seal blow out is near 4 oclock
If it was not for bikes I may have been an Emperor
Re: Actual inverted oil photo [Re: Hillbilly bike] #725866
02/17/18 12:48 am
02/17/18 12:48 am
John Healy Offline
John Healy  Offline
HB I will send you a couple of Real Pioneer Weston undersize crankshaft oil seals. Also you really need some P-80 to install those rubber seals.
Re: Actual inverted oil photo [Re: Hillbilly bike] #725880
02/17/18 4:34 am
02/17/18 4:34 am
If I was still doing that conversion, I'd install TWO seals. There's enough room.
You don't really need anything to stop the seal from coming out, either. The crank shoulder would do the trick.
Re: Actual inverted oil photo [Re: HawaiianTiger] #725885
02/17/18 5:29 am
02/17/18 5:29 am
OZ
Triless Offline
Triless  Offline
OZ
Bill, wouldn't there be a chance, then, of the outermost seal turning with the crank and buggering things !
Re: Actual inverted oil photo [Re: NickL] #725902
02/17/18 12:09 pm
02/17/18 12:09 pm
John, thanks ! ...I thought the one side of the seal bore is too thin to even machine one MM for a circlip....The seal is proper press fit in the bore..The four cotters seem adequate considering the seals have a metal outer ring...The other engine has the exact same set up with a genuine PW seals because the crank end is standard size..I did this same conversion on a Pre unit I rode for many years with no problems...
When I first started the engine the oil pressure pinned the 100 psi gauges...I went through a pile of OPRV springs and shims until I got the oil pressure to not exceed 80 psi when cold...
I'm quite pleased with the bike build other than this one problem....Besides the clip on bars, and the basic frame, everything was done in my shop with an old lathe and hand held tools. The bike goes runs straight down the track, the Hillbilly primary drive fabricated with a jackshaft supported by a Subaru wheel bearing assembly worked well..And the on board Harley starter makes it so easy...
And keep in mind what pilots used to say....
two engine doubles the risk of an engine failure...
Re: Actual inverted oil photo [Re: Hillbilly bike] #725903
02/17/18 12:26 pm
02/17/18 12:26 pm
John, thanks ! .Like Nick L said but the crank does not allow for two seals..I thought the one side of the seal bore is too thin, .065", to machine one MM (.039)for a circlip....The seal is proper press fit in the bore..The four cotters seem adequate considering the seals have a metal outer ring...The other engine has the exact same set up with a genuine PW seals because the crank end is standard size..I did this same conversion on a Pre unit I rode for many years with no problems...
The Pazon electronic magneto conversions use a Lucas taper fit drive gear...Instead I used cam timing gears machined to fit the center metal hub of a fiber gear and TIG welded the pieces together..
Home made oil hose fittings to suit the installation
Re: Actual inverted oil photo [Re: Hillbilly bike] #725905
02/17/18 1:51 pm
02/17/18 1:51 pm
kevin roberts Offline
i thought the mechanic said he looked at the seals at the track.
i seem to remember him saying so.
Re: Actual inverted oil seal photo [Re: kevin roberts] #725909
02/17/18 2:21 pm
02/17/18 2:21 pm
He told me the same .. He is a trained new car dealership mechanic, 15 years experience , I told him on the phone what to look for and he didn't see it?....They also complained about random carb flooding,that ended the second run early.... did you see him take off the float bowls? When I checked the bowl center drain plugs,all spotless..
Re: Actual inverted oil seal photo [Re: Hillbilly bike] #725920
02/17/18 5:20 pm
02/17/18 5:20 pm
no, i didnt see him touch it. just talked with him when they were getting ready to load it back up. never saw anything apart.
Re: Actual inverted oil seal photo [Re: Hillbilly bike] #725950
02/18/18 12:04 am
02/18/18 12:04 am
OK. I'll get it fixed up for Arkansas this summer....I have to make a removable top rail on the frame so the rear engine rocker boxes can be removed without pulling the engine.. I made the bike as low as possible, the engine offset to the left slightly... and it does cause maintenance issues...I think the heads need some port reshaping to make the necessary power to be winner...
Re: Actual inverted oil seal photo [Re: Hillbilly bike] #725956
02/18/18 12:58 am
02/18/18 12:58 am
man, i cant afford arkansas and loring both. wish i could, i have folks in arkansas.
Re: Actual inverted oil seal photo [Re: John Healy] #725964
02/18/18 3:19 am
02/18/18 3:19 am
Isle of Wight, UK
koan58 Offline
koan58  Offline
Isle of Wight, UK
John, so undersize seals are available? From messages on the forum, I had got the impression that it was a fraud, and that folks were getting a standard seal in the guise of a special?
I would of course trust your approval, are they specially made?
Re: Actual inverted oil seal photo [Re: Hillbilly bike] #725970
02/18/18 4:39 am
02/18/18 4:39 am
why is your oil green?
are you running brad penn in this motor?
i used brad penn 30W to break in mine, and i'm still using it.
Re: Actual inverted oil seal photo [Re: kevin roberts] #726012
02/18/18 12:43 pm
02/18/18 12:43 pm
Valvoline 20/50 VR1 Full synthetic racing oil...It's actually a blue color in the bottle..I also use Brad Penn break in oil.......The Valvoline has high ZDDP and a good dose of moly but not suitable for wet clutches or perhaps bikes sharing engine and trans oil...But the moly reduces friction and maybe gives another 1/2 HP..
Re: Actual inverted oil seal photo [Re: Hillbilly bike] #726028
02/18/18 4:31 pm
02/18/18 4:31 pm
Lancaster, California
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
I wrote a blog post about this a few weeks ago, yall should give it a read:
https://www.classicbritishspares.com/blogs/news/tech-triumph-twins-oil-feed-seal
I stock the good oil seals by Pioneer too:
https://www.classicbritishspares.com/products/triumph-crankshaft-points-seal
Re: Actual inverted oil seal photo [Re: Hillbilly bike] #726042
02/18/18 5:41 pm
02/18/18 5:41 pm
CBS, I notice the seals pictured in your links are SDA brand, that the same brand that is shown blown out in my original post....I do realize your link also says you have PW seals... Of course what I'm doing to the engines is far more stressful than street bikes ....
Re: Actual inverted oil seal photo [Re: Hillbilly bike] #726045
02/18/18 6:32 pm
02/18/18 6:32 pm
The site is currently displaying both seals at this time, as well as an undersized spec'd seal.
Re: Actual inverted oil seal photo [Re: HawaiianTiger] #726049
02/18/18 6:49 pm
02/18/18 6:49 pm
The site mentions Pioneer seals but....I see images of two seals, both are not Pioneer..... I can only speak of the quality of the SDA seal that blew out in a racing situation ...I have bought items from CBS and in no way am I saying he is less than the best.. Just pointing out what I see...
Re: Actual inverted oil seal photo [Re: Hillbilly bike] #726059
02/18/18 7:31 pm
02/18/18 7:31 pm
John Healy Offline
John Healy  Offline
Yes, for a long time the standard seal was flogged for both standard and .020" undersize. Recently Velocette had Pioneer Weston make a .020" undersize (70-6387). To make it even more confusing they sell them under the part number 70-4568.
The Pioneer Weston POS2072/MP802 is one of the original seals used by Triumph for this application. Gaco was also a supplier.
The Pioneer Weston # is W10006018R21/29 (.020" undersize seal) it is branded Pioneer Weston. Any UK dealer who trades with David Holder has access to these seals under part number 70-4568.
Re: Actual inverted oil seal photo [Re: Hillbilly bike] #726069
02/18/18 8:53 pm
02/18/18 8:53 pm
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
If you click on the product link...... I clearly indicate which each seal should be used for. There should be no confusion..
Taken from the listing:
70-4568 - Points Seal (Taiwan)
This particular Taiwan seal is rated very low and should only be used for the points seal on a vintage Triumph twin. We do not recommend using the Taiwan seal as the crankshaft seal despite it having the same part number - it could cause low oil pressure.
70-4568 - Crankshaft Seal (USA)
This new USA made seal is the best quality seal to be used as a crankshaft feed seal and also as a points seal. This seal features a metal hosing (just like original) and is rated up to 100+ pounds to withstand oil pressure. This seal happens to be my personal favorite.
70-6387 - Crankshaft Seal (-.020")
If your oil feed spigot on your crank end shows signs of wear (grooving) it is wise to use an undersized seal. The 70-6387 seal features a smaller inner diameter (-.020) to make up the wear on your crankshaft end spigot. To be clear this part is the same as 70-4568 but with a smaller inner diameter.
Re: Actual inverted oil seal photo [Re: Hillbilly bike] #726070
02/18/18 8:55 pm
02/18/18 8:55 pm
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
The "USA" seal is a metal caged seal. As far as I'm concerned that is a pioneer seal. I wrote that blog post because I had the same issue you are having with my TR6. Using the "USA" seal fixed my problem. My PSI is @75 @4K RPM
Re: Actual inverted oil seal photo [Re: Hillbilly bike] #726152
02/19/18 2:30 pm
02/19/18 2:30 pm
John Healy Offline
John Healy  Offline
