Shadrach
Shadrach
Maryland
65 registered members (AML), 460 guests, and 498 spiders.
matg80s, Al Anderson, John Billerbeck, JMOnTwoWheels, SteveCompton
10572 Registered Users
franko 96
NickL 68
809,666 mail-order LSR
Topics67,467
Posts668,991
Members10,572
1960 Matchless G12 Clutch/Shifter problems #725510
02/14/18 12:15 am
02/14/18 12:15 am
WA
W
WilliamLangton Offline OP
W
WA
Hi all!!
First time posting to this great site.
I just purchased a 1960 G12 650, online. Owner said it ran perfect. Yeah, right. I managed to get it running, but when trying to put it in gear, it just chattered, as if the clutch was not engaged. I pulled the side cover and can see the pressure plate releasing from the clutch pack. Also, when just stationary, not running, I can only move the shifter from 1st to 2nd. It's jammed after that. I am a car mechanic, hot rod builder, and am unfamiliar with the workings of this transmission. What do you all think? Somehow, I get the feeling ill be diving deep into this gearbox. Thanks in advance. I am going to drink heavily in preparation for the news,yet still remain hopeful.
William
Seattle, Wa
william langton mccormick
Re: 1960 Matchless G12 Clutch/Shifter problems [Re: WilliamLangton] #725516
02/14/18 12:44 am
02/14/18 12:44 am
Oztralia
Rohan Offline
Rohan  Offline
Oztralia
Not getting gears without the engine running is not really a sign of anything.
Try spinning the back wheel while clicking through the gears is a better test, if you must.
(engine not running while you do this !)
Old clutches often need 'clearing' 1st thing in the morning.
Pull the clutch lever in, and kick it until the clutch frees off, and spins freely.
Then try starting it, and seeing if it goes cleanly into 1st gear.
And goes through all the gears as you speed off down the road.
Gotta get used to british bikes foibles...
Have fun, hopethishelps.
Re: 1960 Matchless G12 Clutch/Shifter problems [Re: Rohan] #725517
02/14/18 12:50 am
02/14/18 12:50 am
WA
W
W
WA
Rohan,
Your optimism is much appreciated. Kick it until the clutch frees off and spins freely? So, start it w clutch lever in, and then what is meant by, frees off?
So this is not uncommon? What's the cause? I know the bike has sat for a while, and the chain cover was full of milky oil.
Thanks again!
William
Re: 1960 Matchless G12 Clutch/Shifter problems [Re: WilliamLangton] #725521
02/14/18 1:05 am
02/14/18 1:05 am
kevin roberts Online content
kevin roberts  Online Content
the plates inside the clutch basket stick together solid when they're cold because of the oil. pull in the lever to take the spring pressure off, then kick. all the foot force goes to the driven plates, while the driving plates are held still by engine compression
the motor will turn over and over as you kick it until eventually the clutch will suddenly come free, and you will whack your shin on something.
if it's sat for a long time the plates might be well and truly glued, and you'll have to take the pressure plate off and winkle them apart.
Re: 1960 Matchless G12 Clutch/Shifter problems [Re: kevin roberts] #725523
02/14/18 1:28 am
02/14/18 1:28 am
WA
W
W
WA
Kevin,
Thank you for this explanation--makes total sense. A mentioned, the oil in the chain case was like a chocolate milkshake. I will take the plates out, and try to figure out what a winkle is. smile
What type of oil do you recommend?
Thanks again,
William
Re: 1960 Matchless G12 Clutch/Shifter problems [Re: WilliamLangton] #725525
02/14/18 1:43 am
02/14/18 1:43 am
shel Offline
shel  Offline
As soon as you try to walk the plates out you'll understand what he means by winkle. You'll have to wiggle them out side to side, top to bottom, a little at a time. Atf works good in the chain case, most seem to prefer the Ford type F fluid
Re: 1960 Matchless G12 Clutch/Shifter problems [Re: shel] #725527
02/14/18 2:13 am
02/14/18 2:13 am
WA
W
W
WA
Shel,
Roger that. Yeah Type f has more friction modifiers--good stuff. Any recommendation for my initial set up on the 3 clutch basket springs and the center stud w locknut?
William
Re: 1960 Matchless G12 Clutch/Shifter problems [Re: WilliamLangton] #725542
02/14/18 8:39 am
02/14/18 8:39 am
Peter R Offline
Peter R  Offline
Hello William, and welcome to this forum.
At the risk that you have already found this info yourself, here's a link to a pdf manual of your bike.
Note that this covers the twin as well as the single AJS/Matchless models.
http://archives.jampot.dk/book/Work...rkshop_Instruction_Manual_all_models.pdf
Re: 1960 Matchless G12 Clutch/Shifter problems [Re: Peter R] #725578
02/14/18 4:52 pm
02/14/18 4:52 pm
WA
W
W
WA
Awesome! Thanks Peter
Re: 1960 Matchless G12 Clutch/Shifter problems [Re: WilliamLangton] #725593
02/14/18 6:01 pm
02/14/18 6:01 pm
i thought "winkle" was a normal word.
Re: 1960 Matchless G12 Clutch/Shifter problems [Re: WilliamLangton] #725629
02/14/18 10:23 pm
02/14/18 10:23 pm
shel Offline
shel  Offline
I've winkled before so I understood
Re: 1960 Matchless G12 Clutch/Shifter problems [Re: WilliamLangton] #725659
02/15/18 2:54 am
02/15/18 2:54 am
Irene, South Africa
robcurrie Offline
robcurrie  Offline
Irene, South Africa
I've worn winkle pickers before, so I also understood.
Rob C
Re: 1960 Matchless G12 Clutch/Shifter problems [Re: WilliamLangton] #725664
02/15/18 4:38 am
02/15/18 4:38 am
Winklepickers, or winkle pickers, are a style of shoe or boot worn from the 1950s onward by male and female British rock and roll fans. The feature that gives both the boot and shoe their name is the very sharp and long pointed toe, reminiscent of medieval footwear and approximately the same as the long pointed toes on some women's high-fashion shoes and boots in the late 2000s.
The extremely pointed toe was called the winkle picker because in England periwinkle snails, or winkles, are a popular seaside snack which is eaten using a pin or other pointed object to extract the soft parts out of the coiled shell carefully, hence the phrase: "to winkle something out", and based on that, winklepickers became a humorous name for shoes with a very pointed tip. Other countries had other humorous names, e.g. in Norway and Sweden they were called myggjagere/myggjagare, literally "Mosquito hunter". They are still popular in the raggare and rockabilly subcultures. In some parts of the U.S. they are called "roach stompers."
i had never heard of winkle pickers.
although in america we have what we call waffle stompers
Re: 1960 Matchless G12 Clutch/Shifter problems [Re: WilliamLangton] #725971
02/18/18 4:42 am
02/18/18 4:42 am
WA
W
W
WA
Well,
I winkle picked those clutches apart and lo and behold, she freed right up. Gave them all a good cleaning and scuffing w 320 grit, filled the case w Type F and shes roaring like a two dollar whore on a trampoline. Thank you all so much. Now, onto another simple question:
The Smiths Gauge reads 32545. Since I have not ridden this bike yet, I can't know if the last digit reads in tenths or not. So does it have 3,254.5 miles, or 32,545??
Thanks in advance!!!
Winkle on.
Re: 1960 Matchless G12 Clutch/Shifter problems [Re: WilliamLangton] #725979
02/18/18 5:17 am
02/18/18 5:17 am
Oregon
Dana_twin Offline
Dana_twin  Offline
Oregon
I have never known any Plumstead product to make 32K, I am sure someone has though.
Moderated by  Matchman62
