Shadrach
Shadrach
Maryland
65 registered members (AML), 460 guests, and 498 spiders.
matg80s, Al Anderson, John Billerbeck, JMOnTwoWheels, SteveCompton
10572 Registered Users
franko 96
NickL 68
809,666 mail-order LSR
Topics67,467
Posts668,991
Members10,572
Amal 276 questions #725132
02/11/18 3:16 am
02/11/18 3:16 am
Perth, Western Australia
H
Howley Offline OP
Howley  Offline OP
H
I have three questions:
1. The literature states the m21 uses a "standard" needle jet. What size is that. 0.106?
2. How do I tell if my throttle slide/body is worn?
3. Are there any baseline settings for the pilot air screw?
This is on a 1949 m21.
Thanks!
Re: Amal 276 questions [Re: Howley] #725144
02/11/18 5:14 am
02/11/18 5:14 am
Canterbury, New Zealand
BevanC Offline
BevanC  Offline
Gidday,
You probably kniw this already, but Draganfly.co.uk have a comprehensive listing of carb data for BSA models, including M21.
Cheers, Bevan
Re: Amal 276 questions [Re: Howley] #725145
02/11/18 5:30 am
02/11/18 5:30 am
H
Howley Offline OP
Howley  Offline OP
H
Yep, I've seen it. It just lists 'std' for the m21.
Re: Amal 276 questions [Re: Howley] #725149
02/11/18 8:43 am
02/11/18 8:43 am
United kingdom
Phil Beresford Offline
United kingdom
The "standard" needle jet size on 276 carburettors was .1065".
Re: Amal 276 questions [Re: Howley] #725150
02/11/18 9:00 am
02/11/18 9:00 am
Sydney, Oz
Shane in Oz Offline
Shane in Oz  Offline
Sydney, Oz
Amal has a nice little search capability fo finding the right carb for specific models, though it can take a few attempts to narrow down.
Once you have the right carb, go down to the parts lit and click on "view" for the carburettor. It shows the M21 has a 276BR/1B, with a 4 slide, 160 main and 106 needle jet.
Re: Amal 276 questions [Re: Howley] #725162
02/11/18 10:54 am
02/11/18 10:54 am
H
Howley Offline OP
Howley  Offline OP
H
Thanks guys.
Buried in the bsa parts book it list a 0.1065 needle as Phil said.
Thanks Shane, I didn't know about that feature on the website.
Having disassembled the carb I found the needle clip missing, a worn, pitted and bent needle on the wrong position and a 130 main jet. No wonder it was hard to start!
Re: Amal 276 questions [Re: Howley] #725181
02/11/18 1:05 pm
02/11/18 1:05 pm
gavin eisler Online content
gavin eisler  Online Content
If the bike is running and you push the slide towards the motor with a finger and the engine note changes, the slide is worn out, they are about a 3 thou loose fit when new. Really bad slides will rattle at tickover.
Re: Amal 276 questions [Re: Howley] #725187
02/11/18 2:49 pm
02/11/18 2:49 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
You would be very lucky indeed to find a Concentric with 0.003" clearance even when new
Re: Amal 276 questions [Re: Howley] #725189
02/11/18 2:59 pm
02/11/18 2:59 pm
Talking slide fit, a mate with a lathe made new slides for his concs, , much tighter fit, more like 0.001", the bike wouldnt run at all, I loaned him an old set and it ran fine, they were designed for a loose fit. Once they are truly Donald ducked the tickover goes unstable, by then you can hear them rattling.
Re: Amal 276 questions [Re: Howley] #725190
02/11/18 3:02 pm
02/11/18 3:02 pm
John Healy Online content
John Healy  Online Content
And for very valid reasons!!!!
When the clearance was increased by AMAL, modifications were made to the low throttle jetting specification to compensate. When a Concentric is sleeved, and the slide clearance is reduced below the correct clearance, the jetting at low throttle openings will be very rich. Boring the body to "clean-it-up" weakens the structural integrity of the body and actually increases the chances that the slide will stick when the mounting hardware is over tightened. When AMAL decided upon the slide clearance they new what they were doing!
Re: Amal 276 questions [Re: Howley] #726950
02/27/18 12:33 pm
02/27/18 12:33 pm
H
Howley Offline OP
Howley  Offline OP
H
Hi guys.
Update. I got some new bits, including a new slide since the old one was totally cooked.
Weirdly, the new slide is basically a 'press fit' in the bore. It's a tight slip fit in the upper section and very tight toward the intake.
Obviously it's not going to function as is, is it safe to skim the bore to bring it out to the 0.003" clearance?
I'd hone it if my hone would fit inside...
Any thoughts?
Re: Amal 276 questions [Re: Howley] #726964
02/27/18 2:39 pm
02/27/18 2:39 pm
Ewing. NJ
E
edunham Online content
edunham  Online Content
E
Ewing. NJ
Either the new slide is oversize, or more likely your carb body is warped. I would check for warping, and if present, try to remedy that through careful use of pressure rather than boring.
Ed from NJ
Re: Amal 276 questions [Re: Howley] #727495
03/04/18 1:40 pm
03/04/18 1:40 pm
H
Howley Offline OP
Howley  Offline OP
H
Good call mate. A bit of work in the vise and a light hone did the job.
