65 registered members (AML),
460
guests, and 498
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics67,467
Posts668,991
Members10,572
Most Online3,995 Feb 13th, 2017
Re: Reboring a Venom Alloy cylinder
[Re: barry2]
#682791
01/27/17 1:48 pm
01/27/17 1:48 pm
Posts: 3 Uk
57clubman
Uk
A similar rattle that you describing can be caused by the big end cage they tend to wear abainst the crank pin, this can sometimes be detected by side to side movement on the conrod, they will run to enternity like this but it may not make for a pleasant ride.
[Re: barry2]
#724751
02/08/18 2:32 pm
02/08/18 2:32 pm
Posts: 626 Ontario , Canada
RGSROB
Ontario , Canada
ideally ,after assembly, you should aim for no more than .001/.0015 T.I.R.of the shafts at or near the main bearing locations. If you get some discrepancy when clocking up the od of the flywheels it is less important. When the OD of the individual flywheels were machined there is a good probability that they may not be Concentric with each other. After flywheel discs were machined,Velocette mounted the shafts to each flywheel then balanced those individual assemblies prior to fitting the big end .
