66 registered members (AML),
476
guests, and 504
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics67,467
Posts668,991
Members10,572
Most Online3,995 Feb 13th, 2017
Crinkle hub repair.
#724750
02/08/18 2:06 pm
02/08/18 2:06 pm
Posts: 930 Perth. Wild West Downunder.
M Shearer
I have a rear crinkle hub that has a slight gap between the two halves where they come together. It seems one or more of the rivets may have loosened. They come back together when clamped. I was thinking of drilling between the two halves at the joint in 3 or 4 spots with a 3/8" drill bit almost down to the inner sleeve, then welding in the hole to fix the two pieces together. Anyone think of any reason why I should not do this?
Mark F. '52 ZB34 Gold Star. '65 Lightning Rocket. '74 Roadster Commando.
Re: Crinkle hub repair.
[Re: M Shearer]
#724798
02/08/18 8:08 pm
02/08/18 8:08 pm
Posts: 456 Au
markoz
Au
[Re: M Shearer]
#724811
02/08/18 9:52 pm
02/08/18 9:52 pm
M Shearer
The wheel is already apart. The hub is not about to fall apart. The gap is really minor and would probably be ok as is but would be better repaired of course. We're talking a couple of thou. in one spot only.
[Re: M Shearer]
#724890
02/09/18 4:46 pm
02/09/18 4:46 pm
Posts: 2,867 Comox BC Canada
Gordo in Comox
As I recall there are three versions of the crinkle hub, plunger type, pre unit swingarm type and the later threaded speedo drive type. Many vendors do not know what they are selling.
[Re: M Shearer]
#724989
02/10/18 10:19 am
02/10/18 10:19 am
M Shearer
I'm not sure what type of hub I have. It has flush rivets and a threaded bearing retaining ring on one side only. The hollow spindle looks different to what is in the manual. The bike is a plunger GS but a bit of a bitsa so who knows what the hub is from.
