Shadrach
Shadrach
Maryland
65 registered members (AML), 460 guests, and 498 spiders.
matg80s, Al Anderson, John Billerbeck, JMOnTwoWheels, SteveCompton
10572 Registered Users
franko 96
NickL 68
809,666 mail-order LSR
Topics67,467
Posts668,991
Members10,572
Page 1 of 3 1 2 3
Start up/oil flow questions #724453
02/06/18 3:46 am
02/06/18 3:46 am
los angeles
J. Grant Offline OP
J. Grant  Offline OP
los angeles
Tonight I fired up my 68 Lightning.....first time running in 30 years. The engine was rebuilt to stock specs with points and the AMAL carbs. I kicked over the engine about 40 times with no plugs and then fired it up for about 5 seconds. Then I thought about the oil flow and that I should be checking to see if there is oil coming back into the tank. What is the procedure for this? Can I look in the tank and see oil flowing as soon as the engine starts? Should I see oil flowing back to the tank if I remove the plugs and just kick over the engine?
Re: Start up/oil flow questions [Re: J. Grant] #724463
02/06/18 7:52 am
02/06/18 7:52 am
Yes
Takes a 100 or so kicks
Re: Start up/oil flow questions [Re: J. Grant] #724525
02/06/18 6:09 pm
02/06/18 6:09 pm
Lancaster, California
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
Are the lines hooked up properly? If you are not sure, disconnect the pipes, squirt some oil in each pipe and kick the engine over. The pipe that "spits" the oil is the return. If all is well you could prime the engine
Re: Start up/oil flow questions [Re: J. Grant] #724530
02/06/18 6:40 pm
02/06/18 6:40 pm
los angeles
J. Grant Offline OP
J. Grant  Offline OP
los angeles
There are 3 lines coming from the engine. The smallest line goes to the rockers, the medium one (I think the return) goes to the bottom of the tank in the center. The largest line goes to the tank outlet near the drain plug. What do I look for in the tank? Will there be a clear oil stream coming from that bent pipe just inside the tank or will I have to look down to the bottom to see any movement? I have never even seen this or any other bike with an oil tank like this running before and I don't have an oil pressure gauge to tell me all is OK. What is the standard process for starting after a rebuild? Should I keep kicking it over until oil flows or should I start it and check? If starting how long do I wait before shutting off if I don't see oil flow?
Re: Start up/oil flow questions [Re: J. Grant] #724536
02/06/18 6:53 pm
02/06/18 6:53 pm
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
Should see a nice stream of oil. It has a rotary pump so it should be consistent. Did you put oil in the crankcase before you put the barrel on? Did you fill the sludge trap with oil as well? 5 seconds won't do any harm. I would start it again and monitor the oil tank.
Re: Start up/oil flow questions [Re: J. Grant] #724540
02/06/18 7:06 pm
02/06/18 7:06 pm
los angeles
J. Grant Offline OP
J. Grant  Offline OP
los angeles
I put 8oz of oil in the crankcase but didn't fill the sludge trap. I'll give it a go later today when i get home. Thanks.
Re: Start up/oil flow questions [Re: J. Grant] #724553
02/06/18 8:56 pm
02/06/18 8:56 pm
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
Let us know how it goes. Cheers
Re: Start up/oil flow questions [Re: J. Grant] #724557
02/06/18 9:48 pm
02/06/18 9:48 pm
Ewing. NJ
E
edunham Online content
edunham  Online Content
E
Ewing. NJ
Do the check to see if you have the oil lines hooked up correctly. On first startup, it could take 15-20 seconds before oil starts spurting out the tube in the oil tank. You will be able to see it and it will be the longest 15-20 seconds you have ever experienced.
Ed from NJ
P.S. It doesn't hurt to fill both the feed and return lines with a pressure oil pump to ensure you do not have any air bubbles in the lines.
Re: Start up/oil flow questions [Re: J. Grant] #724569
02/06/18 11:26 pm
02/06/18 11:26 pm
Farnham, Surrey, UK
gunner Offline
gunner  Offline
Farnham, Surrey, UK
Ideally you should prime the oil pump via the inlet oil feed pipe as suggested by edunham above, this can easily be achieved by using a hand type oil pump with flexible spout inserted into the rubber inlet pipe. Pump oil in until its full and you feed resistance, then connect the feed pipe back to the oil tank.
Its also worthwhile feeding the rockers using the same method as above and additionally remove the rocker cover and pour 1/2 a pint of oil over the rockers and valves. Some of this oil should find its way down to the cam followers and help lube the camshaft additionally some will drain into the sump and be picked up by the oil scavenge.
As mentioned, you should see oil spurting back into the oil tank after a short time, if you have a return oil filter fitted it may take longer as the filter needs to fill.
Re: Start up/oil flow questions [Re: J. Grant] #724573
02/06/18 11:41 pm
02/06/18 11:41 pm
los angeles
J. Grant Offline OP
J. Grant  Offline OP
los angeles
I have oil flow. I now have to time with a strobe light and adjust the carbs. Will a regular strobe light work with the positive ground?
Re: Start up/oil flow questions [Re: J. Grant] #724576
02/06/18 11:57 pm
02/06/18 11:57 pm
I always use a second separate battery for the strobe light so as not to confuse it by using the bike battery.
Re: Start up/oil flow questions [Re: J. Grant] #724630
02/07/18 12:32 pm
02/07/18 12:32 pm
gavin eisler Online content
gavin eisler  Online Content
When you observe the oil return flow back to the tank dont be surprised if it starts to spurt rather than continuously flow after about a minute. The return gears are twice the size of the feed, ie it empties faster than it fills, once the sump clears the oil flow back to the tank becomes intermittent, this is correct.
When you use the strobe a second pair of hands is very useful, at max advance around 4K the bike will want to walk backwards on its stand, one pair of hands for bars and throttle makes this a lot easier, the other pair uses the strobe and tweaks ignition to suit. it helps if the strobe marks are highlighted with typing correction fluid, and the workshop doors are closed lights off, background brightness makes the strobe hard to read.
Re: Start up/oil flow questions [Re: J. Grant] #724714
02/08/18 1:37 am
02/08/18 1:37 am
los angeles
J. Grant Offline OP
J. Grant  Offline OP
los angeles
The bike starts easily and at high rpm the timing pin and mark lines up. Oil flow is good. After it warms up for 10-15 seconds the exhaust gets really smoky. seems whitish when idling and if I give it some gas it goes blackish. I adjusted the mixture and idle screws but without changing the smoking. The idle changed when I adjusted the screws though. I ran it for 5 minutes or more hoping it was the oil left over from the rebuild but that should have burnt off by now. After the engine cooled I checked the exhaust and found that it was really sooty (new pipes). Not oily. Plugs are the same. NGK BS8. Sooty but not oily. Could it be poor spark or just carbs bad. I rebuilt with an AMAL kit but could it be float adjustment or wrong jetting? Should I start a new thread?
Re: Start up/oil flow questions [Re: J. Grant] #724726
02/08/18 6:54 am
02/08/18 6:54 am
BSA_WM20 Online content
BSA_WM20  Online Content
Yes it would be good to start a new thread.
If you have not bored the engine of fitted new rings, don't worry about it for now.
Take it for a few runs around the block and see what it is like after an hour or so running.
Good chance the rings have gummed up a little or could even be stuck in a groove.
Re: Start up/oil flow questions [Re: BSA_WM20] #724727
02/08/18 7:03 am
02/08/18 7:03 am
los angeles
J. Grant Offline OP
J. Grant  Offline OP
los angeles
I do have new rings. When I switched the bike off there was vapor coming out of the carbs which made me thing it was running rich rather than oil getting past the rings. The soot seems really dry too. Checked float level and that was ok. one carb had the needle jet on the middle groove rather than the top one so I fixed that. I tried to start it again but fuel wouldn't flow to the carb. It would come out of the tank with the hose removed but wouldn't flow through the hose to carb. Decided to call it a day.
Re: Start up/oil flow questions [Re: J. Grant] #724737
02/08/18 11:37 am
02/08/18 11:37 am
Check the filters in the float bowl banjos, they are probably blocked.
Are chokes fitted? If so do you know that the chokes are on when the lever is NOT pulling the cable, unlike every other choke in the world, amals are arsey facey, tight cable choke OFF.
Dont worry about vapour coming out of the carb, this is OK, just means it stopped with the inlet valve open.
Re: Start up/oil flow questions [Re: J. Grant] #724738
02/08/18 11:47 am
02/08/18 11:47 am
If you have new rings, and hopefully gave the bore a quick hone, stop faffing around and go do a dozen laps of the block.
Some wide open throttle some heavy engine breaking to get those rings bedded in.
Then you can worry about the finner points of tuning.
Sitting in your shed at idle forever & a day will just glaze the bores and then you will be fiddleing with the carb for the next 1000 miles.
Re: Start up/oil flow questions [Re: BSA_WM20] #724776
02/08/18 6:02 pm
02/08/18 6:02 pm
just a guy from Jersey [Hopewe...
nert Offline
nert  Offline
Be careful not to overheat the engine. The air cooled engine relies on air flow to keep it cool. Stationary, setting timing, fooling with carb can quickly cause the engine to overheat.
Re: Start up/oil flow questions [Re: J. Grant] #724830
02/09/18 1:40 am
02/09/18 1:40 am
los angeles
J. Grant Offline OP
J. Grant  Offline OP
los angeles
Took it out for 15 minutes around the neighborhood. The smoke didn't get worse, was maybe a little better, especially the left pipe. It seemed to pull well but there was a little backfiring when I revved the engine with the bike standing still after the ride so I will recheck timing and valve adjustment. I have fuel filters in the line from the carbs to the tank and they don't fill much. I think that may be some of the problem with the backfiring. On the timing should I strobe the stator mark to the pin at full advance (~3000 rpm) or should I retard the timing slightly to account for crappy fuel nowadays?
Re: Start up/oil flow questions [Re: J. Grant] #724831
02/09/18 1:42 am
02/09/18 1:42 am
los angeles
J. Grant Offline OP
J. Grant  Offline OP
los angeles
I checked the crank case for wet sumping and there was about 120cc's in there. I think that is ok?
Re: Start up/oil flow questions [Re: J. Grant] #724837
02/09/18 3:00 am
02/09/18 3:00 am
Remove the in line fuel filters they are unnecessary, the taps have filters as do the banjos, adding a 3 rd filter achieves very little except for adding bulk.
if the PO fitted in line filters its likely the gauze strainers at the taps have been damaged, or are missing entirely.
120cc s is fine,
if the pipes are not sealed well at the head this will cause backfiring, as will poor fitting silencers. To seal the headers, remove, clean port and header to bare metal and glue in with ordinary builders silicone, for pipe to silencer use exhaust paste.
Do you have chokes fitted? Are here two cables into the top of each carb, and a small lever on the bars?
Re: Start up/oil flow questions [Re: J. Grant] #724847
02/09/18 4:49 am
02/09/18 4:49 am
los angeles
J. Grant Offline OP
J. Grant  Offline OP
los angeles
The petcocks are missing the strainers so I have in line filters. I have no chokes but the hole is plugged. I was running 10/30 oil but bought some 40w tonight....maybe thicker oil will help?
I removed the plugs after my ride and found the right one was totally black and oily. I think this may have been the reason for the backfiring. My plan now is to clean the plugs, change oil, check valves and timing and then ride it. It seems as tough the main problem is smoke and is caused by the rings and the may or may not bed in properly. Does that sound reasonable and if so how long should I give it before I give up and redo the rings? If it's possible to do the job with the engine in place?? it shouldn't take too long.
Re: Start up/oil flow questions [Re: J. Grant] #724867
02/09/18 11:06 am
02/09/18 11:06 am
I think you may have broken or miss installed the rings, motor can stay in the frame , but its a complete top end strip.
When the barrels were fitted to the pistons , did you check the ring gaps first? rings can be fitted up side down.
Maybe if you used a lot of oil on assembly thats what caused the fouling, if it persists after cleaning the plugs , , then its strip down time.
I prefer to fit rings with only a light amount of oil on the bores, if large quantities are used it prevents or delays proper break in, correct honing grit for bores should be no finer than 200 grit, the factory finish was about 180, the honing should leave a 45 degree cross hatch pattern.
10/30 is very thin ( it wont have done any harm), I break in with 10 /40 cheap stuff, then go to 20/50 after the first change at 50 miles or so.
Petrol taps can be repaired by soldering in new gauzes.
A fresh rebuilt motor may smoke for a few secs on first start up, if it persists then something is wrong.
Re: Start up/oil flow questions [Re: J. Grant] #724907
02/09/18 6:25 pm
02/09/18 6:25 pm
los angeles
J. Grant Offline OP
J. Grant  Offline OP
los angeles
I'm going to tear it down again. I think the honing was way too fine. The cross hatching was almost invisible compared to what I would see on freshly honed VW cylinders but I trusted the machinist. Is there a source for the petcock screens or do I make them up myself?
Re: Start up/oil flow questions [Re: J. Grant] #724924
02/09/18 7:40 pm
02/09/18 7:40 pm
Tridentman Online content
Tridentman  Online Content
This suggestion is going to get me shouted at.
But these old Brit bikes are pretty crude pieces of engineering,
."In the day" --in the 60s when I started riding and had no money the accepted way of solving your problem was to get a piece of emery paper of about 150 grit and push it up and down the bore while turning it so that you got a cross hatch of about 45 degrees.
Make it rough---Triumph apprentices were told that if you couldn't strike a match off the bore then it was too smooth.
Then wash it thoroughly in warm soapy water x times---where x is a lot more than you think necessary.
Dry assemble--just one drop of oil on each thrust face of the piston.
Once you start it then make the engine work on and off using the gears.
When racing in the 60s we would "run in" ("break in" for US readers) a new bore in just a couple of laps.
Don't be too mamby pamby with these motors--they respect a tough hard approach.
Page 1 of 3 1 2 3
