Shadrach
Shadrach
Maryland
65 registered members (AML), 460 guests, and 498 spiders.
matg80s, Al Anderson, John Billerbeck, JMOnTwoWheels, SteveCompton
10572 Registered Users
franko 96
NickL 68
809,666 mail-order LSR
Topics67,467
Posts668,991
Members10,572
Sidevalve decompression setup #724224
02/04/18 5:58 am
02/04/18 5:58 am
Perth, Western Australia
H
Howley Offline OP
Howley  Offline OP
H
Hi all,
I'm looking at my decompression setup. I've set the tappet clearance to the specified 0.012. The service sheet says to maintain a gap between the Lifter cam and the tappet head, but pulling the decompression lever only lifts the pushrod by less than 0.012 so the valve doesn't actually lift.
Is it ok to take up most of the tappet clearance with the Lifter?
Re: Sidevalve decompression setup [Re: Howley] #724239
02/04/18 12:45 pm
02/04/18 12:45 pm
BSA_WM20 Online content
BSA_WM20  Online Content
No.
There is near 1/4" of travel in the pin of an M series decompressor.
It rotates round in circles with no stop.
So set the clearence on the valve, tripple check it.
Then remove the decompression lever and rotate it till the pin is almost touching the cam follower then replace the lever on the spline so it points down at around 45 deg.
IF you still can not get enough lift then the valve guide has most likely shifted in the barrel.
Re: Sidevalve decompression setup [Re: Howley] #724245
02/04/18 2:02 pm
02/04/18 2:02 pm
H
Howley Offline OP
Howley  Offline OP
H
To clarify.
There is plenty of lift in the lever on the case, but the lever on the handlebar pulls so little cable that it only actuates a tiny bit.
Have I got the wrong decompression lever for the bar? It bottoms out after moving the lever on the case literally a few millimetres.
Re: Sidevalve decompression setup [Re: Howley] #724276
02/04/18 7:37 pm
02/04/18 7:37 pm
Australia
MattL Offline
MattL  Offline
Australia
Hi Howley,
Post a photo of the bar lever. Is the inner cable too long?
Re: Sidevalve decompression setup [Re: Howley] #724303
02/04/18 11:10 pm
02/04/18 11:10 pm
H
Howley Offline OP
Howley  Offline OP
H
Pics below. I can adjust the slack out of the cable no problem, although the curve in the cable at the engine end would contribute a little.
Note that the blob on the cable doesn't exactly fit in the lever but it is seated.
Re: Sidevalve decompression setup [Re: Howley] #724309
02/05/18 1:02 am
02/05/18 1:02 am
You are missing the ferrule that sits on the end of the cable at the handlebar end,
With this fitted you will be able to back out the adjuster on the engine at least 1/2" if not more and that will give you enough pull to raise the valve.
Note it only goes up a few thou.
Re: Sidevalve decompression setup [Re: Howley] #724319
02/05/18 3:20 am
02/05/18 3:20 am
H
Howley Offline OP
Howley  Offline OP
H
I've got the ferrule, it's recessed into the lever. I can raise the valve now, but only if the Lifter in its relaxed state is taking out 9 of the 12 thou of tappet clearance.
Re: Sidevalve decompression setup [Re: Howley] #724331
02/05/18 4:25 am
02/05/18 4:25 am
H
Howley Offline OP
Howley  Offline OP
H
This is approximately what I had after setting it up the first time.
Re: Sidevalve decompression setup [Re: Howley] #724336
02/05/18 5:04 am
02/05/18 5:04 am
The outer should be almost level with the mouth of the lever, not 1/4" to 1/2" inside
Also try moving the lever arm up one place on the spline.
From what I can see your inner is too short as well.
can you pull the lever all the way back to the handlebars ?
Re: Sidevalve decompression setup [Re: Howley] #724341
02/05/18 6:28 am
02/05/18 6:28 am
H
Howley Offline OP
Howley  Offline OP
H
I think this lever must be a different design, because all is normal at the lever, despite appearances in the pics. I can adjust any slack out of the cable no worries, and the lever pulls all the way to the bar.
I'm not discounting the lever being the wrong type though, although according to the vendor listing it is the correct one.
Re: Sidevalve decompression setup [Re: Howley] #724346
02/05/18 8:26 am
02/05/18 8:26 am
Australia
MattL Offline
MattL  Offline
Australia
My bar lever looks to be shorter and sticks out at a sharper angle (I mount mine below the clutch lever). Having said that the lever at the tappet chest only moves about 30 deg, say 2 o'clock to 3 o'clock.
[Linked Image]20180205_184057 by Matthew Leahy, on Flickr
[Linked Image]20180205_184136 by Matthew Leahy, on Flickr
[Linked Image]20180205_184151 by Matthew Leahy, on Flickr
[Linked Image]20180205_184206 by Matthew Leahy, on Flickr
Re: Sidevalve decompression setup [Re: Howley] #724824
02/08/18 11:36 pm
02/08/18 11:36 pm
H
Howley Offline OP
Howley  Offline OP
H
Thanks for your help guys. I'm on top of it now. The problem was a combination of:
1. Slop in the pivot of the handlebar lever (fixed by increasing the pivot screw size).
2. Inadequate travel of the handlebar lever (fixed with a bit of careful grinding, don't worry it was a pattern lever).
3. Poor lighting in my shed resulting in me not noticing that the tapped head was dished, meaning the clearance I was setting was in reality far greater than 0.012.
I'm going to grind the tappet heads flat again and re-set the clearances, I'm pretty sure I'll be good after that.
Re: Sidevalve decompression setup [Re: Howley] #724835
02/09/18 2:31 am
02/09/18 2:31 am
Canterbury, New Zealand
BevanC Offline
BevanC  Offline
I don't have an s.v., but wouldn't the tappet heads be hardened, so grinding could remove the hardened surface ?
Re: Sidevalve decompression setup [Re: Howley] #724846
02/09/18 4:30 am
02/09/18 4:30 am
H
Howley Offline OP
Howley  Offline OP
H
Interesting comment, although I'd just be grinding the flared edges and only licking the contact face.
Re: Sidevalve decompression setup [Re: Howley] #724991
02/10/18 10:39 am
02/10/18 10:39 am
H
Howley Offline OP
Howley  Offline OP
H
So it's all sorted. It turns out that most of the issue was due to the shape and orientation of the Lifter 'cam'. Where it needed to be set for clearance was around the bottom of its circle, meaning that for the first bit of cable movement it was moving sideways instead of up. I ground the cam a little so it starts at 6 o'clock or so. I also gave it a more aggressive cammy profile so it goes straight into max vertical movement.
I ground the tappet heads flat too, using a temporary fixture to keep it square to the side of the bench grinder wheel, so I've got heaps of lift now.
I fired the bike up today for the first time since I bought it three years ago. My leg is hurting, carb is leaking like a sieve, and flooding itself, and the fuel tap is leaking and not fully shutting off, so I'll be servicing all that next.
Good to hear it run finally!
