Bonnie 71 120RV
Bonnie 71 120RV
Ann Arbor Michigan
68 registered members (AML), 480 guests, and 497 spiders.
matg80s, Al Anderson, John Billerbeck, JMOnTwoWheels, SteveCompton
10572 Registered Users
franko 96
NickL 68
809,666 mail-order LSR
Topics67,467
Posts668,991
Members10,572
A65 endfloat on a 1970 rebuild #724090
02/02/18 9:36 pm
02/02/18 9:36 pm
Stafford, UK
Andy Lorenz Offline OP
Stafford, UK
BSA A65 Crank endfloat
Rebuilding a 1970 A65 lightning, replaced the drive side roller bearing as it had been standing for 40 years, used an RHP bearing.
On reassembly, the outer race was dropped in perfectly after placing the engine cases in an oven, the inner race did not want to slide onto the crankshaft, it preferred to be drifted lightly.
Also the primary drive front sprocket was a very tight fit. So I used a fine emery paper to lightly clean the crank so that the sprocket slid snugly. I also lightly cleaned the crank for the inner roller bearing.
When assembling to measure end-float, I found that the rollers were stiff when sliding into their outer race, the crank rotates smoothly.I also torqued up the rotor to 60 ft/lbs.
I cannot get any end float, the crank rotates smoothly.
I have removed ALL the shims and shim case, but there is still no end float. Is the rollers grabbing their outer race, preventing the crank from sliding?
Thoughts Gentlemen please.
Thrash, Bang, Re-Build...
Re: A65 endfloat on a 1970 rebuild [Re: Andy Lorenz] #724092
02/02/18 10:04 pm
02/02/18 10:04 pm
Lancaster, California
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
What clearance roller bearing?
Re: A65 endfloat on a 1970 rebuild [Re: Andy Lorenz] #724093
02/02/18 10:13 pm
02/02/18 10:13 pm
Stafford, UK
Stafford, UK
Don't know the clearance, it was supplied by Burton Bike Bits
Re: A65 endfloat on a 1970 rebuild [Re: Andy Lorenz] #724162
02/03/18 6:55 pm
02/03/18 6:55 pm
Stafford, UK
Stafford, UK
The bearing is an RHP MRJA1.1/8JC2
Re: A65 endfloat on a 1970 rebuild [Re: Andy Lorenz] #724166
02/03/18 8:08 pm
02/03/18 8:08 pm
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
Should be a CN
Re: A65 endfloat on a 1970 rebuild [Re: C.B.S] #724170
02/03/18 8:53 pm
02/03/18 8:53 pm
Sydney, Oz
Shane in Oz Offline
Shane in Oz  Offline
Sydney, Oz
Should be a CN
Should it be CN or C3? A lot of the other BSA engine/gearbox bearings are C3.
SKF has a summary of the clearance markings here
Re: A65 endfloat on a 1970 rebuild [Re: Andy Lorenz] #724187
02/03/18 11:00 pm
02/03/18 11:00 pm
Stafford, UK
Stafford, UK
I will ring Burton Bike Bits on Monday as they supplied the bearing.
Re: A65 endfloat on a 1970 rebuild [Re: Andy Lorenz] #724237
02/04/18 11:51 am
02/04/18 11:51 am
Stafford, UK
Stafford, UK
Just had a thought, have I installed the inner back to front, does it make a difference ?
I have the writing on the inner face facing the crankshaft centre.
Re: A65 endfloat on a 1970 rebuild [Re: Andy Lorenz] #724256
02/04/18 4:37 pm
02/04/18 4:37 pm
No, it is good practise to have the writing facing outwards only so on the next disassembly the new owner knows what bearing is in there before taking the bearing out but has no effect on how it operates. C2 is too tight for a bearing in an alloy housing with the correct inference fit, BSA have always been C3 on any engine I have dismantled, only on Triumphs and Nortons have I found CN and never C2.
Re: A65 endfloat on a 1970 rebuild [Re: kommando] #724282
02/04/18 8:05 pm
02/04/18 8:05 pm
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
I have a box full of roller bearings from A65's and all are CN but have the stamping V3 (Hoffmann). V3 is the vibration rating and not the clearance rating. I have yet to find a C3 roller bearing out of an A65.
I do agree that most BSA models did use C3 ball bearings.
I would try a CN bearing or perhaps a C3.
Re: A65 endfloat on a 1970 rebuild [Re: Andy Lorenz] #724812
02/08/18 10:06 pm
02/08/18 10:06 pm
Stafford, UK
Stafford, UK
Update: Spoke to Burton Bike Bits, and they confirmed that the correct bearing should have been a CN not a C2.
They are going to update their web page catalogue, and said that the wrong bearing had been placed onto their parts shelf.
They are going to refund the bearing. However, they cannot supply a CN bearing so SRM are offering a NKE main version which is a CN version.
Re: A65 endfloat on a 1970 rebuild [Re: Andy Lorenz] #724825
02/08/18 11:39 pm
02/08/18 11:39 pm
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
You can always give us a try! I have SKF (England) Cheers
Re: A65 endfloat on a 1970 rebuild [Re: Andy Lorenz] #724842
02/09/18 3:14 am
02/09/18 3:14 am
gavin eisler Online content
gavin eisler  Online Content
