BikeVice
BikeVice
San Rafael, Ca.
30 registered members (AML), 272 guests, and 459 spiders.
10257 Registered Users
Lannis 55
TBolt72 47
610,954 mail-order LSR
Topics67,153
Posts651,667
Members10,257
Page 2 of 2 1 2
Re: Cooler Thermostat [Re: DMadigan] #721857
01/12/18 7:50 pm
01/12/18 7:50 pm
Tridentman Online content
Tridentman  Online Content
Only just seen this posting.
Sorry for the delay, Jerry.
Dave is correct--that is the oil thermostat that I recommend for the triples.
You may be able to get it from your local transmission dealer.
I normally order via Amazon from Lakeside Transmissions in Washington State.
When I first started investigating these stats I talked to the parts manager there--when I explained the application it turned out that he owns a Triumph twin.
So ordering from there would sort of keep it in the family.
It helps that when I was looking in the early days they were also the cheapest supplier!
Re: Cooler Thermostat [Re: DMadigan] #721876
01/13/18 12:27 am
01/13/18 12:27 am
melbourne florida
bodine031 Offline
bodine031  Offline
melbourne florida
Well 82 degrees this afternoon took a 1hr+ ride on my Trident. Before leaving I took the brite orange cardboard off the oil cooler!!! Had it on last week with the highs in the low 60's where we are going again this week end!! BRRRR!!!!
Re: Cooler Thermostat [Re: DMadigan] #721878
01/13/18 12:47 am
01/13/18 12:47 am
Denver CO
Jerry Roy Offline
Jerry Roy  Offline
Denver CO
Thanks, I'll check the flow rate with the manufacturer and see if it will work. Decent price, too.
JR
Re: Cooler Thermostat [Re: DMadigan] #721882
01/13/18 1:06 am
01/13/18 1:06 am
Peter---yes!--you are correct--I do remember the radiator blinds for cars controlled by a cable from the drivers seat!
In fact my father had an old Morris Minor with one on!
However they work just like the radiator muff in Kevins photo.
The old cars had a small engine in a large engine compartment.
In the winter with only a small amount of power the airflow around the engine with no radiator muff meant that the coolant temperature never got up to the thermostat "cracking" temperature.
Certainly the heater (if one was fitted!) was pretty ineffectual in those circumstances.
Bodine---having to check out the temperatures and then adding or removing cardboard covers.
Perhaps time to come up to the modern times of the late 20th century and fit an oil thermostat? (tongue firmly in cheek!)
Re: Cooler Thermostat [Re: DMadigan] #721887
01/13/18 1:28 am
01/13/18 1:28 am
kevin roberts Offline
fefsa
fefsa
cooling a motor is a surprisingly fussy thing. surprising to me, anyway. lots happening.
i remember a rally car decades back with an over heating problem traced to stagnant air in the engine compartment. the solution was to just lift the rear of the hood about an inch to create flow-through and the problem was solved.
more was going on there, though, because that's typically a high-pressure region in front of the windshield, but as i recall that's what worked.
i have no idea what i'm doing.
Re: Cooler Thermostat [Re: Tridentman] #721922
01/13/18 2:46 pm
01/13/18 2:46 pm
melbourne florida
bodine031 Offline
bodine031  Offline
melbourne florida
And then what have to give up my 9 dollar TracFone. I have Japanese carbs, E.I., and solid state reg/rectifiers on all the Vintage Brits!!!!! That's as modern I will ever get!!!!
Re: Cooler Thermostat [Re: DMadigan] #721927
01/13/18 4:00 pm
01/13/18 4:00 pm
shel Offline
shel  Offline
Radiator blinds are making a come back on some modern cars
Re: Cooler Thermostat [Re: DMadigan] #722495
01/18/18 3:39 pm
01/18/18 3:39 pm
melbourne florida
bodine031 Offline
bodine031  Offline
melbourne florida
Yesterday 72 degrees mowed the grass and took the 76 Airhead out for a long ride & lunch. This morning 24 with the wind chill, cardboard in front of the G-30 van and no motorbiking for a few days!!!
Page 2 of 2 1 2
