John Goodwin
John Goodwin
Bowral NSW Australia
31 registered members (Bob Buchanan), 255 guests, and 427 spiders.
10294 Registered Users
Stuart 97
Lannis 68
Mori55 67
640,014 mail-order LSR
Topics67,418
Posts654,633
Members10,294
65-3337 G/Box layshaft bushing O.D. dimension help #721761
01/11/18 5:55 pm
01/11/18 5:55 pm
minnesota
joe a. Offline OP
joe a.  Offline OP
minnesota
picked up a 65-3337 gear box bushing (blind,main box housing) for my 59 A10 and it measures .8755 o.d. can anyone confirm this dimension please. line fit at best presently..
joe
Re: 65-3337 G/Box layshaft bushing O.D. dimension help [Re: joe a.] #721772
01/11/18 9:10 pm
01/11/18 9:10 pm
Cork Ireland
chaterlea25 Offline
chaterlea25  Offline
Cork Ireland
Hi Joe,
"line fit at best presently.." ??
I do not know what you mean by this?
Very often the gearbox casing bush holes have "grown" either due to bushes being pressed in cold or the alloy "relaxing"
over the last 60 odd years
I make my own bushes aiming foe a 1.5-2 thou interference fit, heat the casing and the bush will easily push into place
On A10's I always find that the layshafts wear as well, and need machining or grinding undersize
This means a bespoke bush.
A blind bush is difficult to size accurately once fitted, one way is to make the bush with a through bore and than fit an end cap once the bush is reamed to size, this needs careful fitting and sealing
Re: 65-3337 G/Box layshaft bushing O.D. dimension help [Re: joe a.] #721780
01/11/18 9:31 pm
01/11/18 9:31 pm
minnesota
joe a. Offline OP
joe a.  Offline OP
minnesota
hi John,
what i mean is no interference.....not sure if new bush was made correctly, probably aftermarket. i have one old bush that may be out of this gearbox( had boxes of parts sitting around for years) and o.d. is .877 which will work but the i.d. is to large....
joe
Re: 65-3337 G/Box layshaft bushing O.D. dimension help [Re: joe a.] #722164
01/15/18 9:16 pm
01/15/18 9:16 pm
New Hampshier USA
MikeG Offline
MikeG  Offline
New Hampshier USA
Working from memory here, but I just made them for my A10 box and .877 sounds correct. As John states, heat the aluminum housing and chill the bushing and install should be fairly easy.
1960 BSA A10
2007 Suzuki Bandit
1957 A10
(Used to be a Triumph here)
71 Norton Commando
17 Triumph Bonneville
Re: 65-3337 G/Box layshaft bushing O.D. dimension help [Re: chaterlea25] #722169
01/15/18 9:47 pm
01/15/18 9:47 pm
New Hampshier USA
MikeG Offline
MikeG  Offline
New Hampshier USA
Hi Joe,
John-I did just this on the one I made. After installing I turned an aluminum plug for a .004 fit, heated the case/bushing and chilled the plug. I was also considering a spot of two part epoxy just for extra measure before the sprocket and covers go back on.
1960 BSA A10
2007 Suzuki Bandit
1957 A10
71 Norton Commando
Re: 65-3337 G/Box layshaft bushing O.D. dimension help [Re: joe a.] #722544
01/18/18 11:26 pm
01/18/18 11:26 pm
minnesota
joe a. Offline OP
joe a.  Offline OP
minnesota
Hi...
Yes it seems like the three old bushing (o.d.) i had all were .877 or .8775. The new bush (repop?) was .8758 and it pushes almost all the way into the g/box by hand! I was just hoping someone had a extra new old stock to verify or sell (if correct O.D.)..other wise i will need a custom bushing which sucks since i sold my lathes.....
i did check with a few BSA spares dealers and they said the bushes they had were .8755 so still hoping someone has a .877,my search continues...
joe
