R Moulding
R Moulding
Christchurch NZ
43 registered members (Al Eckstadt), 269 guests, and 389 spiders.
10174 Registered Users
Lannis 96
reverb 91
Stuart 70
koan58 67
L.A.B. 54
553,347 mail-order LSR
Topics66,593
Posts645,545
Members10,174
B32 gearbox selector mechanism reassembly #720478
12/30/17 11:49 am
12/30/17 11:49 am
Hampshire
JacobP Offline OP
JacobP  Offline OP
Hampshire
Hi, sorry to make my first post a plead for help, but i have reached the end of my ability with this problem.
I have this 1948 BSA B32 which I bought a few weeks ago. It has the original gearbox, which I believe was only used by BSA for a few years.
I removed the inner gearbox cover and failed to note the position of the selector quadrant. I also do not know what gear the bike is in.
Selector Quadrant.
I have been trying by trail and error for around 8 hours to reassemble it correctly, but I can never get access to all the gears.
My method of testing has been to replace the inner cover and turn the quadrant using a spanner, so sans gear change mechanism. Is this an ok way to test the gear selection?
My main problem is that i do not know which gear corresponds to which segment of the selector quadrant; also i need help in getting the gearbox into a known gear.
Thank you, Jacob
Re: B32 gearbox selector mechanism reassembly [Re: JacobP] #720490
12/30/17 2:33 pm
12/30/17 2:33 pm
Upstate NY
Red Lapierre Offline
Upstate NY
Jacob here is a link to B.S.A. Service Sheet No. 306 which might help.
https://www.britishonly.com/pdf/bsa/sectionB_BSAservicesheetno306.pdf
Red
57 A10 GF
61 A7
61 A10 GF
63 A10 SR
76 CB 125 Honda
76 FLH
2012 FLHTP
Re: B32 gearbox selector mechanism reassembly [Re: Red Lapierre] #720497
12/30/17 3:09 pm
12/30/17 3:09 pm
Hampshire
JacobP Offline OP
JacobP  Offline OP
Hampshire
Thanks for replying. i have a book with all the service sheets in, they have not been helpful thus far. I suppose i can assume that the position shown in the fig b.14 is either 1st or 4th?
Part of the trouble is i have no clue what gear the bike is in, the gearbox is still in the frame, which obviously makes things harder, but i am reluctant to remove it as it do not have the necessary tools to remove the clutch
Re: B32 gearbox selector mechanism reassembly [Re: JacobP] #720503
12/30/17 3:49 pm
12/30/17 3:49 pm
Rotherham, UK
Ian Clifton Offline
Ian Clifton  Offline
Rotherham, UK
Hello Jacob, AFAIK the position shown refers to 4th gear position. There should also be a centre pop mark which will correspond to a line or centre pop? on the selector shaft actuation gear (there was on my 1952 M33 gearbox). If you refer to Service Sheet 608 this may help you better. HTH
Just a few Beezers.. ☺
Re: B32 gearbox selector mechanism reassembly [Re: JacobP] #720510
12/30/17 5:21 pm
12/30/17 5:21 pm
kommando Offline
kommando  Offline
In 4th the sleeve gear is locked to the main shaft by the furthest away selector fork pushing the mainshaft sliding gear into the sleeve gear, you want the gearbox to be in this position and then follow fig B-14 for the selector quadrant.
Service sheet 608
https://www.britishonly.com/pdf/bsa/sectionM_BSAservicesheetno608.pdf
Re: B32 gearbox selector mechanism reassembly [Re: JacobP] #720511
12/30/17 5:57 pm
12/30/17 5:57 pm
Hampshire
JacobP Offline OP
JacobP  Offline OP
Hampshire
It appears I have been a fool and have made a stupid error.
I have previously had the inspection cover off, but I have been doing all this work with it on.(As the box is in the frame, I wanted to prevent debris from falling in.)
So I decided to remove the cover and had another attempt at refitting the selector mechanism. This time everything worked; i could access all gears.
I think i must have had the cover on upside down. I just tried refitting it, and it seems as though it will foul one of the selector forks if it is mounted wrong.
Thanks for the help everyone.
Page Time: 2.552s Queries: 15 (0.235s) Memory: 1.0228 MB (Peak: 1.1762 MB) Zlib disabled. Server Time: 2018-04-25 18:19:04 UTC
