BSA Boy
BSA Boy
Boulder, CO
Phil Andersen, Bud O, knobby, coomo, Chris mannifield
11025 Registered Users
franko 140
DavidP 78
Rohan 59
koan58 59
1,157,537 mail-order LSR
Topics69,027
Posts691,618
Members11,025
75 registered members (AML), 1,262 guests, and 981 spiders.
Penetrating oil ATF Acetone versus rest #713114 10/29/17 8:17 pm
gavin eisler Online Content OP
OP Online Content
Cut and pasted from another place.
"I know that I have seen this topic, to some extent, on here before. At our BMAC (British Motorcycle Association of Colorado) meeting yesterday our president brought in a handout for the members on the subject - in print. "Magical Mystery Fluid Revealed", I will just touch on the highlights to keep it short. In 2007 "Machinist's Workshop Mag. tm" published information on various penetrating oils including subjective tests of many of the popular penetrants. The following list is the results of their test with the control being the torque in foot pounds required to remove a nut from a bolt in a "scientifically rusted" environment.
Penetrant ------------------------------------------ Average Load
None ------------------------------------------------ 516 Ft. Lbs.
WD-40 ---------------------------------------------- 238 Ft. Lbs.
PB Blaster ----------------------------------------- 214 Ft. Lbs.
Liquid Wrench ------------------------------------ 127 Ft. Lbs.
Kano Kroil ------------------------------------------ 106 Ft. Lbs.
ATF*/Acetone Mix --------------------------------- 53 Ft. Lbs.
ATF= Automatic Transmission Fluid
The ATF/Acetone mix was a "home brewed" mix of 50/50 automatic transmission fluid and acetone which proved to be better than any of the commercial brands of penetrant on a removing a nut rusted onto a bolt. No matter which penetrant is used they all require a period of time to wick down into the threads, but because acetone has an extremely low dynamic viscosity, it's thin, it gets into the threads quicker than the other products with the ATF following shortly behind for lubrication. Expecting comments!!!"
Re: Penetrating oil ATF Acetone versus rest [Re: gavin eisler] #713122 10/29/17 9:16 pm
Swan Offline
Qualitatively, I concur with the results. ATF/acetone or Kroil are my first choices for frozen hardware.
1966 Triton
1962 BSA DBD34 Gold Star
1966 Triumph Bonneville
Re: Penetrating oil ATF Acetone versus rest [Re: gavin eisler] #713124 10/29/17 9:28 pm
Peter R Offline
I tried the ATF/acetone mix on a seized piston of my Benelli, unfortunately, it did not work, and I had to resort to more drastic measures, in spite of the fact that I let it soak for more than two weeks. frown
Re: Penetrating oil ATF Acetone versus rest [Re: gavin eisler] #713125 10/29/17 9:35 pm
OP Online Content
I mind Swans epic unseizing of the Goldstar, sometimes snake oil is not enough.
Re: Penetrating oil ATF Acetone versus rest [Re: gavin eisler] #713231 10/30/17 5:41 pm
Dibnah Offline
Re: Penetrating oil ATF Acetone versus rest [Re: gavin eisler] #713234 10/30/17 6:12 pm
kevin roberts Offline
well, i didn't have any ATF, so an hour ago i poured a cupful of acetone and power steering fluid into the plug hole of my seized-up 69 starfire.
ATF and power steering fluid were interchangeable in identical honda and sterling power steering pumps, so we'll see whether they behave similarly in a stuck cylinder.
Re: Penetrating oil ATF Acetone versus rest [Re: gavin eisler] #713415 10/31/17 8:53 pm
F
Fetch Offline
F
I had no idea WD40 was that ineffective as a penetrating lubricant, like wise I did not realize how effective an Acetone/ATF cocktail is. Thanks for the vry informative post......I feel wiser already!
Re: Penetrating oil ATF Acetone versus rest [Re: Fetch] #713446 11/01/17 4:21 am
Magnetoman Online Content
Read this post before you drink the acetone/ATF Kool-Aid.
Re: Penetrating oil ATF Acetone versus rest [Re: Magnetoman] #713449 11/01/17 6:56 am
The time you spent writing that could have been spent trying it.
Re: Penetrating oil ATF Acetone versus rest [Re: gavin eisler] #713454 11/01/17 10:12 am
Hillbilly bike Offline
In 50 years of working on my junker cars/trucks I've found all brands of penetrating oil is more or less useless on fasteners with more than very slight rust...Kroil has as nice smell when burned off with the oxy torch. When you soak a fastener with the oil and it finally unscrews are the threads dry like I always see?..Piston stuck in the cylinder? Car guys say by diesel or kerosene works well...
Re: Penetrating oil ATF Acetone versus rest [Re: triton thrasher] #713469 11/01/17 2:22 pm
It's not that simple. If I used acetone/ATF on a random rusted fastener how would I know the fastener wouldn't have been released with the same torque had I not used the acetone/ATF? How would I know it wouldn't have been released with even less (or more) torque had I used Kroil instead?
Kroil on the outside of a rusted fastener picks up a reddish coloration, i.e. a chemical reaction with the rust is taking place. That doesn't happen with either acetone or the one brand and type of ATF I have in my garage. For the reasons I gave in that other post, without a chemical reaction I don't see a plausible reason why a substance would work. Without having a reason to expect that acetone/ATF would work any better on a rusted fastener than, say, sprinkling talcum powder on it there's no reason for me to try to devise an experiment that might yield results I could rely on.
The contact area under a bolt head is a significant fraction of that of the threads. If penetrating oil only succeeded in removing the rust there, without even reaching the threads, it would significantly reduce the torque. Also, because rust requires oxygen to form it "grows" into the threads from the outside in so it will be thickest at the top and so penetrating oil only has to work on the first few threads to significantly reduce the torque.
Re: Penetrating oil ATF Acetone versus rest [Re: Magnetoman] #713489 11/01/17 6:39 pm
You must not live in the north east grin Let me be more clear...when and if the nut/bolt unscrews, there is no signs of oil on the threads or the surface the fastener was up against...This isn't usually a problem on bikes. but I often work on older 4x4 stuff...The best improvement on vehicles I have seen is in the last 15 years the use of anaerobic thread sealers on suspension and drive lines by some manufacturers....
Re: Penetrating oil ATF Acetone versus rest [Re: Hillbilly bike] #713496 11/01/17 7:22 pm
If I did I'd have to deal with rusted nuts and bolts all the time, costing me a fortune in bottles of Kroil...
Re: Penetrating oil ATF Acetone versus rest [Re: Hillbilly bike] #713519 11/01/17 11:10 pm
Jon W. Whitley Online Content
Yes, I have noticed that too and I have dealt with quite a few lately.
1971 BSA A65 650 - Project
Re: Penetrating oil ATF Acetone versus rest [Re: gavin eisler] #713620 11/02/17 5:12 pm
57nortonmodel77 Offline
For commercially bought products, I like Kroil, but have had better success with the 50/50 mix of acetone & FLM/ATF.
My first test was removing a set of aluminum Offenhauser heads off a cast iron 1950 flat head Ford. Forty eight nuts as I recall. I used a number of commercially available chemicals, WD-40 was the worst, but to be fair, it was designed as a water displacement (WD). In the end, some still wouldnt budge, on those, careful application of heat to the nuts did the trick, but with aluminum directly below, I had to be very carefull of the temperature range.
Perhaps not collegiate grade scientific testing, but real world guy in the garage testing, as most of us here are.
As a side note, if you have brake cleaner in your garage, NEVER use it on anything you will be heating with a torch!!!
I dont know any chemists to confirm, or de-bunk this, but why take the chance:
http://www.brewracingframes.com/safety-alert-brake-cleaner--phosgene-gas.html
Magneto & Dynamo restorations & supplies
My Bikes
1948 Norton 500T Trials bike
1950 Norton Model 7
1952 Norton ES2
1957 Norton Model 77
1960 Norton Nomad 600cc Desert sled
1961 Norton ES2 (slimline)
1964 Norton Atlas Scrambler
1972 Bultaco Alpina
Re: Penetrating oil ATF Acetone versus rest [Re: Magnetoman] #713710 11/03/17 2:14 pm
F
Fetch Offline
F
Ok, so I read it. There is a problem flaw in your assumption/observation. Extract from your post:
"Anyway, to free rusty steel fasteners (or piston rings) you need a penetrating fluid with a low enough viscosity and surface tension that it can penetrate through the microcracks in the rust. To some extent ATF in acetone satisfies this. But, you also need an ingredient that chemically "reduces" the iron oxide, i.e. breaks the Fe-O chemical bonds to "dissolve" the rust. Even if a fluid makes it through the microcracks to displace the air in those cracks, unless the oxide bonds are broken the fastener will be held by the still-present oxide with the same strength as before so the presence of a lubricant in the microcracks won't do any good."
You agree the cocktail will penetrate the "microcracks" but then you say you need to "dissolve the rust" or the "the fastener will be held by the still present oxide WITH THE SAME STRENGTH as before"
So I rung up my cousin who is a retired Chemical engineer and scary kinda garage magician when it comes to stuff like this. His reply, "The specific gravity of the Acetone allows it to carry the AFT into all sorts of places, the ATF is a sufficient friction reducer......if it doesn't work, heat it up or drill it out.
Re: Penetrating oil ATF Acetone versus rest [Re: Fetch] #713719 11/03/17 3:52 pm
here is a problem flaw in your assumption/observation....
So I rung up my cousin who is a retired Chemical engineer and scary kinda garage magician when it comes to stuff like this. His reply, "The specific gravity of the Acetone can carry the AFT into all sorts of places, the ATF is a sufficient friction reducer......if it doesn't work, heat it up or drill it out.
Sorry, but your garage magician cousin is quite wrong. As any chemical engineer should know, specific gravity has nothing to do with the ability of a fluid to penetrate cracks. Viscosity and surface tension do, both of which are unrelated to a fluid's specific gravity.
Heat certainly will help thanks to differential thermal contraction creating additional microcracks, and any substance that reduces friction will help after a fastener starts to move. However, these are red herrings because the issue is what properties a penetrating fluid has to have in order to reduce the required torque all by itself.
Look, anyone who wants to believe acetone/ATF works, that's fine by me. It seems to me that all that need be said on the topic has been so it's a good time to let it go.
Re: Penetrating oil ATF Acetone versus rest [Re: gavin eisler] #718965 12/16/17 3:19 am
Mori55 Offline
I worked on bridges for 40 years as a ironworker. And we dealt with old rusted bolts and pins. They were big say 1 1/4 by 6 “ or bigger. usually rusted corroded. Always tried to drive them out by hand or old river guns. Heat was last resort. But I swear by pb blast. I’ve seen 6” bolts that were spraye on one side that had the fluid come out the other side after awhile. These were bolts we couldn’t budge with 16lb beaters until we used the pb blast.
Re: Penetrating oil ATF Acetone versus rest [Re: gavin eisler] #718980 12/16/17 11:57 am
AngloBike Online Content
I watched a tv programme where they unseized an engine (head off I think) by heating either oil or diesel on a gas ring until it was very hot and then poured it into the cylinder. Probably similar to the gold star technique
Re: Penetrating oil ATF Acetone versus rest [Re: gavin eisler] #718982 12/16/17 12:12 pm
Interesting how this old thread has resurfaced, but ok.
I fail to see how acetone will help with de-rusting anything to be quite honest. Apart from it providing an accelerant if heated and lowering the viscosity of the ATF it’s being mixed with, it will have mostly evaporated before the ATF had worked between the bolt and nut.
Someone mentioned the flammability of brake cleaner, well yes it works as a solvent so remove grease and oil’s to stop the disk rusting in storage. However because it is a solvent it will evaporate in atmospheric temperatures (over a time) and because it is a solvent it has a very low flash point.
In the garage we used to use heat and maintenance fluid (like WD 40) to remove stubborn bolts, or in a place where heat would cause much bigger problems (like heating up a ball joint with grease inside) I would either....
Grind the top of the stud and nut until they were flush and shiny, or grind/cut through one face on the nut, whack with a chisel and the nut would spread leaving you able to wind the nut off... in that instance causing minimal damage to the bolt part.
Re: Penetrating oil ATF Acetone versus rest [Re: gavin eisler] #719036 12/16/17 8:35 pm
my starfire is going on six weeks with acetone and power steering fluid. i checked it yesterday, still stuck.
maybe i'll pour in a can of coca cola and see what the phosphoric acid will do.
Re: Penetrating oil ATF Acetone versus rest [Re: kevin roberts] #719094 12/17/17 1:28 pm
It probably has a spun bearing and bent connecting rod grin.. Get that oil out of the cylinder,buy some liquid 100 percent lye drain cleaner and pour it in...Lye will eventually dissolve the aluminum piston and clean the steel bore.....It will also corrode an aluminum rod and head but at least the piston isn't stuck...
Re: Penetrating oil ATF Acetone versus rest [Re: gavin eisler] #719098 12/17/17 2:01 pm
kommando Offline
I would go coke first as that attacks rust and aluminium oxide, if that does not work then go more drastic.
Re: Penetrating oil ATF Acetone versus rest [Re: gavin eisler] #719100 12/17/17 2:18 pm
less drastic is the way to go, i think. i want some sort of motorcycle thing at the end of this, rather than a big puddle of shiny goo.
Re: Penetrating oil ATF Acetone versus rest [Re: gavin eisler] #722643 01/19/18 10:16 pm
OP Online Content
Found this vid on you tube , accordng to the beardy guy Acetone plus rust gives CO2 , Water , and crucially ferric carbide , which is brittle, supposedly how this works.
Unlike the guy I do not reccomend adding a 14 year old Single malt to the mix, nutter.
https://www.youtube.com/watch?v=o7hpmmlYBFM
