Topics68,235
Posts684,691
Members10,937
Most Online14,755 May 5th, 2019
39 registered members (998John),
542
guests, and 922
spiders. |
Key:
Admin,
Global Mod,
Mod
Re: new engine
[Re: lemans]
#646167
03/28/16 5:06 pm
gavin eisler
Posts: 4,771 |
Hi Anne, nice progress, in the pic below you can see the Devimead solution for lubrication of the Timing side bearing, the original pressure feed is blanked and a small cavity is created on the top side of the bearing boss allowing oil to drip into the bearing. ![[Linked Image]](https://i101.photobucket.com/albums/m79/argpod/IMG_0589_zpsfkqjuhxs.jpg)
71 Devimead A65 750 56 Norbsa 68 Longstroke A65 Cagiva Raptor 650 MZ TS 250 The poster formerly known as Pod
Re: new engine
[Re: lemans]
#646176
03/28/16 5:38 pm
lemans
Posts: 219 |
hi Gavin, that is indeed a clever solution, being a needle roller the dripfeed is more than enough. As you can see in my earlier posts I used a scrub srew with a 1mm orifice. Same setup as with the old engine which lasted some 32 years/ 12000 miles. Regards A
see post 500026 and just follow the links
Re: new engine
[Re: lemans]
#680466
01/08/17 1:02 pm
lemans
Posts: 219 |
been a while but this christmass the new engine is work in progress. solved the axiaal end float voodoo, made a new bearing out of some phosphor bronze. in the end it is just a 5,25 mm thick slab of bronze, milled to the correct dimensions. end float is now 0,04 mm ![[Linked Image]](https://i1233.photobucket.com/albums/ff390/lemans41/BSA%20End%20Float-20170108-01641%202_zpsgzogipph.jpg) ![[Linked Image]](https://i1233.photobucket.com/albums/ff390/lemans41/BSA%20Axiaal%20lager-20170108-01641%201_zpsaubxtghi.jpg) next jobs on the list are: 1. camshaft 2. the SRM-Oilpump 3. gearbox, pity the five-speed from Scotland isn't available yet so have to resort to the four-speed. regards A
Re: new engine
[Re: lemans]
#680496
01/08/17 3:59 pm
JER.Hill
Posts: 366 |
Hi Anne
Nice to see your moving forward again. With regards to the 5 speed clusters, I've been surprised by the lack of interest, other than myself the other two which I know are in use, Mark Parker and Gavin Eisler are happy with the performance, of the 11 sets sold others don't really give you much feed back.
Hopefully your post can generate a little more interest, at the moment there are your self and four other who have shown an interest. I need to order a batch of ten, so if anyone is interested PM here or get in touch.
regards
Re: new engine
[Re: lemans]
#680502
01/08/17 4:29 pm
lemans
Posts: 219 |
well the five-speeder can be exchanged with the engine in the frame, so there's no real hurry yet still..... I want to shift one more time when they don't expect it.
the bike used to be run two-up and then the four-speed hasn't the best spaced ratio's. future use is again two-up regards A
Re: new engine
[Re: lemans]
#684593
02/11/17 8:53 am
lemans
Posts: 219 |
what better way to spend a snowy saturday morning ![[Linked Image]](https://i1233.photobucket.com/albums/ff390/lemans41/20170211-01658_zpsjvj8n51n.jpg) ![[Linked Image]](https://i1233.photobucket.com/albums/ff390/lemans41/20170211-01659_zpsrqz9z1z4.jpg)
Re: new engine
[Re: lemans]
#701030
07/07/17 2:02 pm
lemans
Posts: 219 |
Re: new engine
[Re: lemans]
#701031
07/07/17 2:03 pm
lemans
Posts: 219 |
cool this auto-censor-function
see if it works with this one
ooops Photobucket
Re: new engine
[Re: lemans]
#707812
09/09/17 11:37 am
lemans
Posts: 219 |
progress with the new engine is slow, very slow. with the upcoming winter season the objective is to have all components ready. and now the camshaft. I purchased a 90-drg camshaft a couple of years ago. and it is not straight. although new the complaining period is long past and I'm having a new one made at the local camshaft-shop http://www.hurricaneracing.nl/question now is: are the profiles for inlet- and exhaust-cam identical?.regards Anne
Re: new engine
[Re: NickL]
#708184
09/12/17 4:48 pm
Allan Gill
Posts: 6,041 |
It depends which cam you have. The standard 'spitfire' form is different.
I think this also alters depending on if its an original cam (to which I think your referring) or a remanufactured item, which I have seen lift heights and duration different to that of the factory item (and different to other makers versions of the same cam) The SRM race cam as far as 360 degree motors are concerned is a good cam.
Re: new engine
[Re: Allan Gill]
#708243
09/13/17 9:29 am
lemans
Posts: 219 |
[quote=NickL]
The SRM race cam as far as 360 degree motors are concerned is a good cam. I do think so but where can I find the profiles for the inlet- and exhaustcam. I do not think they are the same. regards Anne
Re: new engine
[Re: lemans]
#708581
09/15/17 9:12 pm
Dave T
Posts: 361 |
It seems I can no longer view the images on the forum threads unless I fork over money to photobucket to upgrade my account. Or am I doing something wrong?
Re: new engine
[Re: lemans]
#708584
09/15/17 9:21 pm
shel
Posts: 3,663 |
No, Dave you have to pay money to upload your own photos from photobucket, you still won't be able to see others photos unless the poster of those photos pays the ransom too
Re: new engine
[Re: shel]
#708876
09/18/17 12:08 pm
BrizzoBrit
Posts: 826 |
Go to BritBike FAQ.
Look at the photobucket ransom post by Andy Higham.
If you use Chrome as your browser you can install the app mentioned that shoves it right up Photo*uckits backside and allows you to view the images.
It works!!
BSA 1969 A65F BSA 1966 A65H Triumph 1968 T120 Kawasaki A1R & too many projects!
Re: new engine
[Re: lemans]
#746731
08/25/18 8:50 pm
lemans
Posts: 219 |
trying to get this thread running again. bought a 5-speeder lately in Portugal from James, nice chap who had one lying around. convinced my wife that a holiday to Pombal (PT) was long overdue, and who's having coffee at the Cafe Nicolai, James with a gearbox. how lucky can you get. she took it rather well.
don't know about photowhatever and running my own server now, trying to show some pictures, have patience
Re: new engine
[Re: lemans]
#746801
08/26/18 12:57 pm
Allan Gill
Posts: 6,041 |
looking forward to it Lemans
Re: new engine
[Re: lemans]
#749177
09/14/18 7:09 pm
lemans
Posts: 219 |
does anyone know if Nourish Engineering is stil in business?. http://www.nourishengineering.co.uk/page.phpI'm trying to contact Chris by mail and phone but to no avail, probably a new number?. regards Anne
Re: new engine
[Re: lemans]
#749201
09/14/18 9:59 pm
gavin eisler
Posts: 4,771 |
Mr Nourish sold the business a few years ago, the new owner has disappointed quite a few customers, not surprised they are incommunicado. Ive had no personal dealings, but from what Ive seen, you had better look elsewhere .
Re: new engine
[Re: lemans]
#749255
09/15/18 8:18 am
lemans
Posts: 219 |
Re: new engine
[Re: lemans]
#749499
09/17/18 3:19 pm
lemans
Posts: 219 |
indeed bad news, done some reading, especially the CRMF-Forum and reports are bad. the reason I wanted to contact Chris is that the 90-drg crankshaft he made doesn't fit. main dimensions are "slightly" off and although it fits the crankcase, it doesn't fit the barrel.
have to revert to a std 360-drg setup. pictures to follow later.
regards A
Re: new engine
[Re: lemans]
#749526
09/17/18 5:37 pm
gavin eisler
Posts: 4,771 |
Thats a tough break, can it be made to work ?, there are other decent machine shops out there. I read somewhere on a facebook page that you are not the only one to get badly made stuff from him. In the same thread someone suggested contacting Mr Nourish, he uses a decent engineering shop, although no longer trading/ doing this work he knows another shop thats capable. I tried to search for the facebook info and got lost, it was either on the "British Bike mechanics " or "BSA Singles and Twins" Theres a bloke across the pond that builds staggered cranks , you give him the crank, it gets sawn in half , welded rebalanced, sheds a lot of flywheel weight. Interesting site. http://www.offsetcrank.com/bsa_index.htmlI have no idea if this is still current.
Re: new engine
[Re: lemans]
#749609
09/18/18 8:53 am
Whisper
Posts: 218 |
I trust that you wore some heat-proof gloves when you pushed the bearing out with your fingers at 200 degrees :-)
Re: new engine
[Re: Whisper]
#749663
09/18/18 7:43 pm
lemans
Posts: 219 |
I trust that you wore some heat-proof gloves when you pushed the bearing out with your fingers at 200 degrees :-) if referring to the torrington inside the gearbox, a std heatgun and a screwdriver did the trick, no injuries sustained if referring to the crankshaft timing side bush, applied brute force and again no injuries but to assemble the needlerollerbearing inner race onto the crankshaft is a tricky operation. apply heat with the heatgun, then pick up the very hot inner race and position it on the exact position on the crankshaft timing side stub. and keep holding it in position and wait for the inner race to shrink cool your fingers and observe position of inner race, repeat untill satisfied. and yes I wore some gloves regards A
Re: new engine
[Re: lemans]
#749666
09/18/18 8:12 pm
gavin eisler
Posts: 4,771 |
When I took my devimead timing side bearing apart the inner race had a convenient 45 degree flat on the crank side rim, after heating it popped off easily with a small chisel tapped into the bevel. When I fitted the new race I reground the bevel, glad I did , it needed to come off for a small shim to prevent the crank cheeks binding on the bearing outer, this had to be stoned a little for a few more thou relief. Although the same OD and ID the new bearing was a few thou longer than the original and a couple of subtle changes were needed to get the correct float on the ball part of the combi bearing.
Re: new engine
[Re: lemans]
#758628
12/08/18 8:55 pm
lemans
Posts: 219 |
![[Linked Image]](http://77.163.36.45/025.jpg) as I was rather pissed of by photobucket's ransom actions already one year ago, I decided to move forward with a raspberry-pi webserver. took some time but this is the result. tadaaa. a server with my own pictures. as the chris-crank is of no use yet (not without extensive modifications) I reverted to the tested 360-degree setup (had to, damn) J.Hill alloy barrel 5-speed gearbox newby belt progress is being made regards A
