Posts: 153 Likes: 1
Posts: 153 Likes: 1 |
I haven't run across any oils with the SG designation and fully synthetic. If anyone is aware of it I would greatly appreciate a brand name. As has been noted in other posts, the SG designation captures the additive package needed by our older machines. Thank you very much, Steve
73 T140V; 02 Ducati ST4s
Posts: 10,574 Likes: 49
Posts: 10,574 Likes: 49 |
I haven't run across any oils with the SG designation and fully synthetic. You will find most synthetic oil rated for our motorcycles will be 20w50 SJ JASO MA2
Posts: 153 Likes: 1
Hi John, thanks. So, the SJ JASO MA2 rated oil has sufficient additives backward looking to be usable in our older bikes (1973 T140)?
Posts: 2,764 Likes: 11
#irideslow
#irideslow
Posts: 2,764 Likes: 11 |
In looking around, I haven't found a full synthetic with API SG rating, not so far anyway. There may be a message there. (I do use full synthetic in my "modern" bikes what with modern filtration and 4,000 or so mile oil change intervals.) For a while I used a "part" synthetic with SG rating in my BBs http://www.castrol.com/en_us/united-states/motorcycle-oil/4-stroke-engine-oil/act-evo-x-tra-4t.html[edit] I recall another oil thread about two years ago, someone here had contacted Castrol for a recommendation on which Castrol product to use in these old bikes, and Castrol recommended this Actevo 4T part synthetic with API SG rating. ... but have since changed back to "mineral-based" not-at-all synthetic in the BBs. Not sure why, just seemed like the right thing to do. Maybe because I put on less than 1,000 miles per year of easy-to-moderate use, and change the oil at least once a year. My '71 BSA A65L has a "Norton-type" external filter installed in the return line, I'll get to the Triumphs ... at some point. http://www.castrol.com/en_us/united...gine-oil/4t-4-stroke-motorcycle-oil.html
Last edited by kurt fischer; 08/31/17 4:40 pm. Reason: clarifications, details, and so on
Kurt
Posts: 1,764 Likes: 2
Posts: 1,764 Likes: 2 |
Lucas SYN 20-50 MOTORCYCLE OIL or Valvoline VR-1 Racing dino oil Join TIOC and you get John's tech knowledge. Like the Some Times You Have To Go Back To Go Forward article in the Summer 2014 Vintage Bike Mag.
Posts: 339 |
Amsoil has a 20w/50 SG JASO MA/MA-2 API SG/SL/CF/CG-4 ISO-L-EMA2 LINK
1969 BSA A65T w/A70 engine 1970 Royal Enfield Interceptor S ll
You want SG not SJ, as John wrote.] I did say most... ?????? Synthetics for most 4 stroke motorcycle oils are API SJ. Brad Penn synthetic 4 stroke motorcycle oil is API SJ Mobil 1 Synthetic: Typical Properties Mobil 1 Motorcycle Oils V-Twin Engine/Application Type 4-Cycle SAE Grade 20W-50 Service Classification API SJ, SH, CF Density, g/ml @ 15.6°C 0.87 Flash Point, °C (ASTM D93), 214 Pour Point, °C (ASTM D97) - -42 Kinematic Viscosity, 82.0 172.3 Kinematic Viscosity, 13.1 20.8 Viscosity Index 142 Cold Cranking, 7,500 @ -15°C Pumping, c 14,000 @ -20°C
Private sponsor
Private sponsor
Posts: 534 |
When I ran synthetic, my clutch would slip in fourth around 60mph and the rings never seated. ymmv
Posts: 6,923 Likes: 16
Posts: 6,923 Likes: 16 |
What we've since learned about synthetics is that the synthetic oil is not responsible for the clutches slipping and rings not seating. It's the additives that do that. I've been using Lucas 20-50 synthetic motorcycle oil lately in my bikes. It's pretty expensive, but the extended oil change interval and better protection makes it great economy in the long run. Cheers, Bill
Posts: 8,495 Likes: 55
Posts: 8,495 Likes: 55 |
Bill Did someone not know that?
Posts: 5,482 Likes: 60
Posts: 5,482 Likes: 60 |
Of course if your bike's clutch and transmission oil is separate from the engine this oil business is a bit different...
79 T140D, 96 900M Ducati ,61 A10 .On a bike you can out run the demons.. “But I don't want to go among mad people,” Alice remarked. “Oh, you can't help that,” said the Cat: “we're all mad here. I'm mad. You're mad.
Try this MAXIMA EXTRA 4 15/50 ESTER BASED SYN. JASO-MA SG/CC SG= SPARK gas engine CC= COMPRESION Diesel G&C = API rating Been using this since new in my 03 Bonny and the wife's 05 Kaw Z-750S rings seated and no clutch slip OH YEA and in the wife's T-160 after a complete engine reman. !!
Posts: 7,729 Likes: 33
Born To Run
Born To Run
Posts: 7,729 Likes: 33 |
Steve d -
What is it exactly that you wish to accomplish by using synthetic? Longer oil-change intervals? Less 'wear' on the engine? Cost?
Just curious....
'77 T140J "Vintage Bike". What's in your garage?
Posts: 11,242 Likes: 9
Posts: 11,242 Likes: 9 |
Right, because I thought the ball and roller mains chopped up the long chain polymers in the oils, mandating frequent oil changes no matter what oil you used. Following that thinking, the only thing that allowed you "longer intervals between oil changes" was adding on an oil filter. Just interested.
Don't hide 'em, Ride 'em !!
RF Whatley Cornelia, GA
You can have longer change intervals with mineral oil.
Not saying it's a good thing. Longer change intervals not be a good thing with synthetic oil either.
Just curious. If the people who market synthetics oils are claiming double mileage oil change intervals, and it's not true, doesn't that mean that oil industry people can't be trusted?
But, wait. If it wasn't true, then they would sell twice as much oil.......mo money mo money!
Having trouble wrapping my head around this.....
Cheers, Bill
Posts: 153 Likes: 1
I'm trying to achieve less wear on the engine and reduced sludge buildup in the sludge tube. I've installed a sump filter. I am looking for synthetic as it is less likely to break down versus mineral-based oil in high heat during the summer months when I primarily run the machine. I do run it for long periods in stop-and-go traffic and that is where oil breakdown can ultimately occur. I choose to seek a synthetic in order to avoid the frequent mineral-based oil changes that would overcome this situation. I reviewed the Amsoil 20-50 as well as the Lucas 20-50 synthetic oil data sheets. Both indicate they are SG rated. Thank you so much for the references. They should fit the bill for what I am hoping to use. Steve
Just curious. If the people who market synthetics oils are claiming double mileage oil change intervals, and it's not true, doesn't that mean that oil industry people can't be trusted? You may trust sales talk, if it pleases you to do so. But, wait. If it wasn't true, then they would sell twice as much oil.......mo money mo money!
Cheers, Bill I wouldn't be at all surprised if synthetic is better oil.
Right, because I thought the ball and roller mains chopped up the long chain polymers in the oils, mandating frequent oil changes no matter what oil you used. Following that thinking, the only thing that allowed you "longer intervals between oil changes" was adding on an oil filter. Just interested. But what is frequent oil changes?, The majority of modern bike engines share oil with the transmission that is full of many many roller and ball bearings and gears Of course all newer bikes have full flow oil filters..Oil change intervals are as long as 8000 miles on some models.Modern engines most likely have less blowby crap in the oil and more consistant operating temperatures than a vintage bike so that would allow longer intervals...
Posts: 10,158 Likes: 16
Posts: 10,158 Likes: 16 |
Hi Richard, I thought the ball and roller mains chopped up the long chain polymers in the oils, You are mistaken. the only thing that allowed you "longer intervals between oil changes" was adding on an oil filter. Given Triumph and BSA triples have "ball and roller mains", a proper micropore oil filter and at least double the oil change intervals of any twin, guess what's important for "longer intervals between oil changes" ...  Regards,
Air cooled vs liquid cooled is the answer. If you have a liquid cooled motor, then I think you can get quite a few more miles from your oil before it feels like water between your fingers. Yep, that's my empirical oil testing method. Wash your hands after. Nasty stuff that. I'm really trying hard to get 3k miles from my Honda before I change the Lucas 20-50 synthetic motorcycle oil. It's a difficult thing. All my instincts are telling me 1500 miles. Perhaps even 5k miles would be OK. That Honda motor will likely go 100K miles no matter what I did to it. I'd love to run synthetics in my classics(I know, the Honda is over 30 yrs old but it's just about impossible to think of it as a classic.) The main reason is that they don't get ridden daily. Just weekly or sometimes monthly. I think the coating that synthetics leave on metal will help with dry starts. But the synthetics dramatically increase engine noise which I find offensive. No real evidence to support that except from various internet sources. But in the end, there's always just a little bit of faith involved in our decisions. Cheers, Bill
I'm trying to achieve less wear on the engine And that is exactly what we found when we switched several Vincents to Mobil 1 v-twin 20w50 API SL JASO MA2. Vincents are known for premature cam and lifter wear. Mobil 1 v-twin decreased cam and lifter wear significantly. My opinion about oil changes hasn't changed with synthetic. When used for short hauls in areas, or weather, where condensation will collect, and the engine never gets hot enough to distill it off as water vapor, I change it a lot. When used for long hauls the change intervals increase up to the manufacturers recommendation. Thee is no one answer to when to change your oil.
Cheers, Bill
You're not the only person I've heard say synthetics can make more engine noise or perhaps a different noise. Go on Bob is the Oil Guy message board and there is all sorts of stories about certain oils being noisier.. ..With synthetics I noticed a slight difference in engine noise in the Buell ,no difference on the 96 Ducati, both using Mobil 20/50 V Twin oil.. ...I use Valvoline full synthetic VR1 20/50 in the Triumph race bikes...It's a SL rated oil with friction modifiers and more ZDDP than almost all Jaso bike oils..These bikes don't share engine and primary oil...The engines don't seem to make more mechanical clatter than a stock Triumph...But they have open pipes... To determine oil change interval besides the usual factors, I think you have to look at the additive package...And as mentioned a quality oil filter To be truthful I change oil in my bikes and Jeeps/truck once a year......
Posts: 3,267 Likes: 26
Posts: 3,267 Likes: 26 |
Oil beliefs are like religion. If you believe one way, a thousand proofs proving you wrong are not going to change your mind. If you have the money and think one thing is better than another, spend it. Most people riding these old turds around are looking to spend four or five bucks a quart. That's me. I used to ride 10,000 miles a year or more. I change oil once a year, if it needs it or not. Sometimes I doubt if there is 500 miles on it. I hate getting old.
