oilyrag
oilyrag
Lancashire UK
Vidane, BenM, New_Warrior, Chad Bradshaw, Bell47
10661 Registered Users
franko 96
NickL 49
876,424 mail-order LSR
Topics66,573
Posts668,466
Members10,661
76 registered members (Adam M.), 834 guests, and 189 spiders.
Need clutch plates in US #698287
06/13/17 1:54 am
06/13/17 1:54 am
Tennessee
M20 Offline OP
M20  Offline OP
Tennessee
I believe I'm in need of clutch plates for my 54 MSS, anyone have a good source in US? Any ounce in US?
Support your #1 Velocette Forum
Velocette Motorcycles on e-Bay UK, Velocette motorcycles on e-Bay North America
Re: Need clutch plates in US [Re: M20] #698290
06/13/17 3:26 am
06/13/17 3:26 am
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
Just a word of caution here mate...
What makes you think that you need new clutchplates?
Remember, this Velo clutch is like no other! -It can show various symptoms that can be misleading if you are used to working with conventional clutches.
It's quite possible that it's showing the symptoms of worn plates, but it may not be that at all.
What are the symptoms?
Re: Need clutch plates in US [Re: Joolstacho] #698291
06/13/17 4:41 am
06/13/17 4:41 am
Tennessee
M20 Offline OP
M20  Offline OP
Tennessee
It doesn't seem to want to go into gear. I have pics of the plates, let me see if I can post them.
Re: Need clutch plates in US [Re: M20] #698293
06/13/17 5:02 am
06/13/17 5:02 am
Tennessee
M20 Offline OP
M20  Offline OP
Tennessee
Re: Need clutch plates in US [Re: M20] #698294
06/13/17 5:04 am
06/13/17 5:04 am
Tennessee
M20 Offline OP
M20  Offline OP
Tennessee
Re: Need clutch plates in US [Re: M20] #698295
06/13/17 5:05 am
06/13/17 5:05 am
Tennessee
M20 Offline OP
M20  Offline OP
Tennessee
I think they are missing things that are needed!
Re: Need clutch plates in US [Re: M20] #698296
06/13/17 5:12 am
06/13/17 5:12 am
Tennessee
M20 Offline OP
M20  Offline OP
Tennessee
I am also open to any recommendations on clutch mods. If needed. I'm new to the Velocette world.
Re: Need clutch plates in US [Re: M20] #698297
06/13/17 5:28 am
06/13/17 5:28 am
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
Well, yes! those missing tabs on the plain plates are, err... not good. (Actually bloody 'orrible!!!) Dis you find any bits of steel floating around in the PCC?
As you say an new set of plain and inserted plates is required. The question is what is the chain-wheel like?
Are the chainwheel inserts fairly even and similar? proud of the steel? Teeth reasonable? centre bearing ok?
If they are reasonable just get a set of the plain and inserted plates and try it.
You have a good club over there, surely they have a club spares scheme?
Here (Oz) I'd get them from our club, or Grove Classics in UK.
The clutch thrust bearing is a big issue with Velos. Velo owners do not 'ride' the clutch, we learn to find neutral before stopping, because the standard thrust bearing can't handle the pressure.
There is an easily available 'uprated' thrust bearing which replaces the 3/16" balls with rollers. Fixes the issue. That's the best thing you can do with your clutch.
The next best 'upgrade' is to learn is the clutch adjustment routine, and use it without fail!
Other things to be aware of are:
Ensure you have an original clutch lever, or one with the right amount of throw.
A good cable is a MUST.
There are a few setup tricks, (like shims behind the banjo) but it's beyond the scope here.
Re: Need clutch plates in US [Re: Joolstacho] #698412
06/14/17 1:58 am
06/14/17 1:58 am
Tennessee
M20 Offline OP
M20  Offline OP
Tennessee
Great I'm going to get an order in so I can replace it all and ad the roller bearing thrust plate.
Thanks for the great advice.
Re: Need clutch plates in US [Re: M20] #698424
06/14/17 6:37 am
06/14/17 6:37 am
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
You'll need the 3-piece thrust bearing assembly consisting of:
1. Flat hardened steel ring.
2. Roller bearing - brass/bronze caged race with rollers.
3. Spherical hardened steel ring.
Will probably be sold as an assembly, but it's as well to know what you need.
Re: Need clutch plates in US [Re: M20] #698503
06/14/17 11:59 pm
06/14/17 11:59 pm
LAS VEGAS NEVADA
DAVE ARTHUR Offline
DAVE ARTHUR  Offline
LAS VEGAS NEVADA
I also live in the USA so when you get it please post the part numbers and where you got it from. Thanks Dave
Re: Need clutch plates in US [Re: M20] #698507
06/15/17 12:37 am
06/15/17 12:37 am
Tennessee
M20 Offline OP
M20  Offline OP
Tennessee
Will do, getting an order together right now. I will let you all know how it goes.
Cheers from the other side of the Country!
Signal Mountain, Tn.
Re: Need clutch plates in US [Re: M20] #698683
06/16/17 1:30 pm
06/16/17 1:30 pm
Tennessee
M20 Offline OP
M20  Offline OP
Tennessee
I am trying to identify a name for a part without the parts book to speed up my order. There are two washers or shims behind the sprocket on the crank output. Does anyone know what those would be called? I have all the other parts nailed down but don't know what these would be called.
Re: Need clutch plates in US [Re: M20] #698686
06/16/17 1:45 pm
06/16/17 1:45 pm
Tennessee
M20 Offline OP
M20  Offline OP
Tennessee
Re: Need clutch plates in US [Re: M20] #698688
06/16/17 1:55 pm
06/16/17 1:55 pm
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
I think you must mean the 'Driving shaft shim'
Comes in 4 thicknesses:
2 thou, 3thou, 5 thou, 8 thou thick.
They fit between the main bearing and the crankcase, and provide the correct preload for the crankshaft mainbearings.
You have to go through a process of measuring and selective assembly to get the correct preload on the main bearings. From memory a few thou.
Bit of a 'business' to fit.
But they're INSIDE the crankcase. I don't think there's anything else meant to be there outside the crankcase behind the engine sprocket.
Re: Need clutch plates in US [Re: M20] #698690
06/16/17 2:12 pm
06/16/17 2:12 pm
Tennessee
M20 Offline OP
M20  Offline OP
Tennessee
These are definitely outside the cases behind engine sprocket, not sure why a P.O. would have added those but time will tell. Looks like something that could be sourced locally if needed for some reason. Thanks for all your help, I will keep you all posted on the progress.
Re: Need clutch plates in US [Re: M20] #698706
06/16/17 5:57 pm
06/16/17 5:57 pm
Draper, Utah
F
Fullminator Offline
Fullminator  Offline
F
Draper, Utah
Perhaps these shims are an attempt by a previous owner to bring the primary chain into alignment??
I don't think Velocette showed anything here as a part or in the parts book.
Fullminator
Re: Need clutch plates in US [Re: M20] #698738
06/16/17 10:43 pm
06/16/17 10:43 pm
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
Yes, or an attempt to pack out a weak engine shaft shock absorber spring. -Which could explain why they look pretty graunched up.
Re: Need clutch plates in US [Re: M20] #698745
06/16/17 11:24 pm
06/16/17 11:24 pm
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
...And while you're down there (as the actress said...) check for crankshaft end-float.
There should be no end float at all, -the bottom end is assembled with a small amount of preload, briefly, you assemble crank, bearings, shims etc, into the cases, so you have .004" preload.
Meaning when you get the cases together but not bolted firmly together, you should be able to slide a 4 thou feeler gauge between the case mating surfaces, then you'll have 4 thou preload when they're all bolted up tight.
Re: Need clutch plates in US [Re: M20] #698841
06/17/17 9:14 pm
06/17/17 9:14 pm
Oregon
Dana_twin Offline
Dana_twin  Offline
Oregon
If you still need any clutch driven plates I should have some good ones (3) somewhere, but they are for a Venom not an MSS
Re: Need clutch plates in US [Re: M20] #698848
06/17/17 11:05 pm
06/17/17 11:05 pm
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
They should be the same.
Re: Need clutch plates in US [Re: M20] #699214
06/21/17 12:45 am
06/21/17 12:45 am
LAS VEGAS NEVADA
DAVE ARTHUR Offline
DAVE ARTHUR  Offline
LAS VEGAS NEVADA
M20, Where are you ordering the clutch plates and roller throwout bearing assembly from? Can you post the part numbers? Thanks, Dave
Re: Need clutch plates in US [Re: DAVE ARTHUR] #699450
06/23/17 11:52 pm
06/23/17 11:52 pm
Tennessee
M20 Offline OP
M20  Offline OP
Tennessee
Grove Classic Motorcycles is the place I ordered from, I am at British in the Blueridge right now, I will send a parts list when I get home Sunday. I ordered everything I could for a 7 plate clutch.
Re: Need clutch plates in US [Re: M20] #699741
06/27/17 1:07 am
06/27/17 1:07 am
Tennessee
M20 Offline OP
M20  Offline OP
Tennessee
Joolstacho, or anyone with info on the MSS, is there a seal behind the engine sprocket or the inner primary behind the engine sprocket? I don't have a parts book so I am trying to make sure everything is there that's suppose to be. The inner primary tin seems a little wanked, may be sticking out a little more than it should. I don't see anything to stop oil from flooding primary.
Re: Need clutch plates in US [Re: M20] #699752
06/27/17 3:09 am
06/27/17 3:09 am
Tennessee
M20 Offline OP
M20  Offline OP
Tennessee
I will list the parts I ordered for the 7 plate clutch tomorrow, left the list in my truck, I ordered from Grove Classic last week and it was here today ! They should get an A+ for shipping, I have had parts on order from England for my James from another company for over a month and I still don't know if they are on the way or not! I may trash that company later but.... Grove Classics has done a good job on this order and I will order from them again. I promise a ride report when the MSS is on the road in the East Tennessee Mountains, soon I hope.
Re: Need clutch plates in US [Re: M20] #699754
06/27/17 4:44 am
06/27/17 4:44 am
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
"seems a little wanked"
Well that's a good 'un ! (Something lost in translation I think, hee hee).
There should be a large rubber O-ring that fits over the crankcase boss behind the engine sprocket. May be of dubious value with any but a new, dead straight inner PCC.
There should be a thick cork gasket between the gearbox and the inner PCC inner face. There are 4 shouldered screws that hold the PCC to the box, but they are supposed to just impart enough pressure to stop oil leakage, but allow just enough 'slip' so that the box can move back and forwards for adjusting the primary chain tension. There is a felt seal outside of the clutch, there is a spacer between the PCC halves that is important not to miss.
This system is virtually impossible to keep leak-free. Crankcase pressure is free to escape into the PCC via the mainshaft bearing. Oil can seep past the sleevegear bushing -other places vulnerable too.
Some people attain something less than a gush, but it takes plenty of work to achieve. For example there is a 'proper' oil seal that replaces the cork I think. Do try to get the inner PCC as flat as possible, that'll help a lot. But don't beat the **it out of it and stretch the metal).
After some years of trying, I ended up fabricating a nice alloy sheet sump guard which, with some felt applied, fixed most of the PCC oil leaks. (A bit like turning the car radio volume up to instantly fix noisy tappets!)
Re: Need clutch plates in US [Re: Joolstacho] #699789
06/27/17 11:41 am
06/27/17 11:41 am
Tennessee
M20 Offline OP
M20  Offline OP
Tennessee
That explains a lot and is kind of what we were thinking, I think the washers we discussed earlier behind the sprocket were an attempt to keep the primary chain from rubbing the inner PPC. The PPC looks to be a little proud on that end and you can see where the primary chain has hit a few times. On another note, I think you were dead on about the tool box sticking out to far. It appears to be mounted incorrectly for some reason, looks to be an easy change. Great information, I will keep plugging along.
Re: Need clutch plates in US [Re: M20] #699821
06/27/17 4:49 pm
06/27/17 4:49 pm
Draper, Utah
F
Fullminator Offline
Fullminator  Offline
F
Draper, Utah
M20, my experience with Groves matches yours. I have ordered much from them, and they have an A+ rating from me in the shipping department.
I also agree with Joolstacho, the primary chaincase is a real challenge to get leak free. Making a moveable gearbox to facilitate primary chain adjustment and making it leak free are two diametrically opposed intentions.
I have a new primary chaincase, (from Groves) so it is relatively straight. I also installed the large O-ring at the crankshaft end, behind the inner case half on the crankcase boss. I also used a good amount of RTV silicone sealant here as this opening is not subject to component movements. Groves also sells an upgrade nitrile rubber seal for use at the crankshaft end, on the outer primary chaincase half. I haven't installed this yet as I am still struggling to get the &%$#* clutch to go together.
Viva Velocette!
Fullminator.
Re: Need clutch plates in US [Re: Fullminator] #699849
06/27/17 8:48 pm
06/27/17 8:48 pm
Bry Offline
Bry  Offline
As an alternative to trying to seal the PCC, I have had good experience running the primary dry using an IWIS endless 'o' ring chain in my Venom. I have been using this set up for the last 5 years (~8,000 miles) without problem and am planning a similar conversion on my newly acquired Iron MSS over the winter. During this period the primary chain has only needed minor adjustment twice. I have been keeping an eye on the shock absorber spring drive cam assembly but it seems to get enough lubrication from the oil mist created from the crankshaft breather.
1946 Velocette MSS
1955 Triton
1959 Velocette Venom
1966 Triumph T120
Re: Need clutch plates in US [Re: M20] #699867
06/28/17 12:09 am
06/28/17 12:09 am
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
That's a good solution Bry, obviously it works well for you. And you've had no problems running the clutch dry? No issues with the clutch thrust bearing? -Have you done the oil groove mod to the 'banjo'?
It's been said in the past that running the clutch dry results in too much heat build up, (though heat might not be such an issue up there Bry :-), plus no lubrication to the big chainwheel bearing, less to the thrust bearing. Anyway I'll be looking at this option for my KSS/Viper project I think.
Fullminator, are you having problems starting the big tubular nut on the sleeve gear thread? (You probably know all this anyway, but at the risk of teaching granny how to suck eggs)... The right tool makes a difference - (easy to make -just a short length of scaffold tube with a 4 short pegs brazed in and a simple tommy bar). And how many springs in the spring holder, 16 or 20. And are they the right length? Got the two shim washers on between the springs and tubular nut to stop the springs bending and inhibiting?
Re: Need clutch plates in US [Re: Joolstacho] #699899
06/28/17 8:17 am
06/28/17 8:17 am
Bry Offline
Bry  Offline
I've had no problems with running the clutch dry Jools, ambient temperature may be a factor that will have a greater effect where you are though. I am using the Club spares plates and roller thrust bearing, packed with grease on assembly, imo this is a very worthwhile modification.
The oil groove mod to the banjo you are referring too, I assume is grinding a small groove into the thrust cup? If so, I did consider this when I built my Venom but decided against it as I could not see any major benefit and a risk to weaken what is already quite a fragile looking component, I just applied a light coating of grease to the cup on assembly.
As you will know, "dry running" a Velo primary is a relative term, there is still quite a bit of oil mist that enters via the crankshaft breather hole; this, I believe is sufficient to lubricate the large chain wheel bearing, which is lightly loaded anyway. I actually still drain out excess oil from the PCC every 800 miles or so, and this is with the later breather arrangement modification from that back of the timing case area.
Fullminator, +1 on what Jools says about using the right tool to fit the nut onto the sleeve gear, this will save you a lot of time and frustration. If this is indeed the issue you are experiencing in assembling your clutch, then polishing the ends of the springs on an oil stone (especially if the springs are new) and lubricating the washer will prevent them from catching and bending over as you get the nut started on the thread.
1946 Velocette MSS
1955 Triton
1966 Triumph T120
Re: Need clutch plates in US [Re: Bry] #699940
06/28/17 6:11 pm
06/28/17 6:11 pm
Draper, Utah
F
Fullminator Offline
Fullminator  Offline
F
Draper, Utah
Bry/Joolstacho, my clutch experience is quite a story. I have the following parts, all new from Groves: brass caged roller bearing, plain square roller bearing thrust ring, bonded clutch lining plates, plain flat plates, chainwheel, chainwheel bearing, (16) clutch springs, (2) shims on the sleeve gear nut, & sleeve gear nut. I reused the existing spherical thrust ring, frying pan thrust cup, & (3) thrust pins.
The book says the springs should be 1-1/8", but the new ones from Groves are nearly 1-1/4". This may be the problem. I polished the spring ends
I have the sleeve gear nut installation tool, but even then I have had a major problem getting the nut started. I finally made a 3/4" X 2" flat steel plate, about 1/8" thick, with a hole in the middle to fit over the clutch shaft that I could use the clutch nut to compress the springs as I started the nut on the sleeve gear. It worked, the clutch went together and I tightened up the sleeve gear nut as far as it would go, but now it seems to me the clutch springs are coil bound. After hooking up the clutch cable and pulling the lever, the whole clutch pack moves on the pivot, and it pulls hard. there is no separation of the plates at all. I suspect the springs are too long, but 1-1/8" to 1-1/4" difference isn't that much. How close to coil bound are the clutch springs in normal operation anyway? Holding the lever of the clutch in, are the springs very near coil bound?
Thanks.
Fullminator
Re: Need clutch plates in US [Re: M20] #699968
06/29/17 12:25 am
06/29/17 12:25 am
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
Those springs are too long. There's not much leeway at all, length should be 1 1/8", and coilbound at 3/4". (Surprised Groves would have sent incorrect lengths).
What's the overall thickness of your clutch pack assembled loosely off the bike? One of the problems with these clutches is that there are quite a few parts from different models and years which are slightly different but will interchange, but the clutch needs all the correct parts to function properly.
Re: Need clutch plates in US [Re: M20] #700042
06/29/17 5:28 pm
06/29/17 5:28 pm
Draper, Utah
F
Fullminator Offline
Fullminator  Offline
F
Draper, Utah
My clutch pack measures 1" thick, which I understand to be correct. I agree that the springs are too long, but I will check to see if they measure 3/4" at full bind.
Thanks.
Fullminator.
Re: Need clutch plates in US [Re: Fullminator] #700132
06/30/17 7:58 am
06/30/17 7:58 am
Bry Offline
Bry  Offline
Obviously something is not right with the assembly, hopefully the fix will be as simple as replacing the springs.
Was this a complete and working clutch before you fitted the new replacement parts?
There were some subtle changes to some of the clutch components over the years, and I believe it is possible to interchange components that can result in the situation you are describing.
If you have not seen this already, here is link to an article with links therein to very useful reference tables of clutch components and combinations.
http://v-tec.velocette.info/clutch.html
1946 Velocette MSS
1955 Triton
1966 Triumph T120
Re: Need clutch plates in US [Re: M20] #700134
06/30/17 8:31 am
06/30/17 8:31 am
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
Now, to clarify, we're talking a postwar 9 plate clutch I assume? (Note, the plate count includes all elements in the clutch, including backplate, chainwheel and outer pressure plate). Postwar MSS should be 9 plate unless some PO has mixed components. Clutch pack total thickness for a 9 plate clutch is 15/16". Your pack at 1" thick is 1/16" too thick, but may just need bedding in.
(The 7 Plate assembly would be 7/8" thick) I guess we could assume a clutch with all new components might be slightly thicker because the inserted plates haven't bedded in yet).
That info on Bry's link is excellent, (thx Bry), the trouble is that it doesn't tell you what YOUR bike should have! Part numbers are all very well but how do you relate them to YOUR bike?
I have a list of the clutch parts AND DIMENSIONS based on bike/year. Let me know if you need a copy, I can scan and send it.
Re: Need clutch plates in US [Re: Joolstacho] #700136
06/30/17 8:46 am
06/30/17 8:46 am
Bry Offline
Bry  Offline
Jools, there are links to 2 tables in the article the "main table" relates to year/model designation with components, the "...elements table" is a breakout of individual parts.
Your dimensioned list would be very useful, can you post it as a scanned image?
Bry
1946 Velocette MSS
1955 Triton
1966 Triumph T120
Re: Need clutch plates in US [Re: M20] #700143
06/30/17 10:40 am
06/30/17 10:40 am
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
Now. I just have to give credit where credit is due. This chart is nothing to do with me, but comes courtesy of Norm Trigg, a stalwart of the Australian Velo Club. A bloody wonderful ol' feller is Norm. He's a Velocette guru with a depth of knowledge of Velos and engineering in general that seems endless. There is a publication called 'Norm's Technicalities' that's a mine of useful information about Velos, compiled by Norm over many years, which was published by the Aussie Velo Club. I may see if/how it's possible for international enthusiasts can get a copy.
This is the clutch chart:
May be of some help.
Norm's weapon of choice is his superb 580cc longstroke Venom sidecar outfit, with alternator and electric start conversions, all engineered by Norm.
Re: Need clutch plates in US [Re: Joolstacho] #700204
06/30/17 5:37 pm
06/30/17 5:37 pm
Draper, Utah
F
Fullminator Offline
Fullminator  Offline
F
Draper, Utah
Jools/Bry, yes my clutch is a 9 plate, 1962 Venom. Thanks much for your posts and the clutch items detail tables. I see the two differ on the clutch spring size, not that it is that big of deal. One says 1-1/8" and the other 1-5/32"
This was a working clutch before being dismantled. The new springs I got from Groves are very obviously too long at almost 1-1/4", the problem is where to source the correct length ones?
I suppose I could cut these off, but then I wouldn't have a nice finished end.
Fullminator
Re: Need clutch plates in US [Re: Fullminator] #700215
06/30/17 6:43 pm
06/30/17 6:43 pm
Bry Offline
Bry  Offline
Fullminator, if you are a member of the Velocette Owners Club, use the spares scheme for your clutch springs (...and possibly a set of fibre plates). If you are not, it's worth joining the club just for access to the spares scheme although there are other benefits including the excellent monthly Fishtail magazine; in fact, members received a free copy of Norm's Technicalities book a few years back that Jools has taken the time to post the clutch information from above.
The club spares scheme is run by volunteer Velocette enthusiasts and they strictly control the quality of parts supplied.
http://www.velocespares.co.uk/vsl-sales.html
If you have the old parts availble I would try reassembling with the original fibre plates and springs, as I suspect that these are the replacement parts that are causing you the problem.
Also - for starting the nut on the sleeve gear try selecting fourth gear, as this can help to stop the sleeve gear from sliding back.
Bry
1946 Velocette MSS
1955 Triton
1966 Triumph T120
Re: Need clutch plates in US [Re: M20] #700736
07/04/17 4:48 pm
07/04/17 4:48 pm
Tennessee
M20 Offline OP
M20  Offline OP
Tennessee
My bottom rocker exhaust arm MAS118 is worn to the point that the compression release will not engage the rocker arm. Grove is out and does not know when one will be available. Does anyone have another source or a used one for sale? I may be able to weld this one up but that may be a crap shoot.
Re: Need clutch plates in US [Re: M20] #700751
07/04/17 7:35 pm
07/04/17 7:35 pm
Bry Offline
Bry  Offline
Hi, if it was mine I'd try welding first (tig with a heat sink!), it shouldn't need much to rebuild. For a used replacement, give Nick Payton in London a call, great bloke to deal with and he has a huge stock of used and NOS parts.
http://www.totalbikebits.com/product_locator/dealerdetails.php?id=234
1946 Velocette MSS
1955 Triton
1966 Triumph T120
Re: Need clutch plates in US [Re: M20] #700898
07/06/17 1:09 am
07/06/17 1:09 am
Tennessee
M20 Offline OP
M20  Offline OP
Tennessee
Thanks Bry, going to try and weld it up first as suggested.
Re: Need clutch plates in US [Re: M20] #700911
07/06/17 8:16 am
07/06/17 8:16 am
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
Just wondering if you could weld a little extra 'nib' on the lifter itself rather than welding the rocker arm. ?
Yes I know that it needs to be removed from the case so needs to be circular, but it could work - ah, maybe not.
Re: Need clutch plates in US [Re: M20] #723312
01/26/18 1:29 pm
01/26/18 1:29 pm
Ontario , Canada
RGSROB Offline
RGSROB  Offline
Ontario , Canada
the shims you are referring to are fitted between the spring retain nut and the outer top of the 16 springs.The idea is to create some slippage so that springs are not pulled over as the nut is tightened. Does not work well but is better than none.
