BritBike SponsorBritBike SponsorBritBike SponsorBritBike SponsorBritBike Sponsor SteadfastCyclesBritBike SponsorBritBike SponsorBritBike SponsorBritBike SponsorHepolite Pistons
Kerry W
Kerry W
Middle East,
Swinging arm washers?
#696883 05/30/17 7:34 pm
6T Offline OP
..Hi,I'm putting together a 1967 T120R frame BUT can't get the swinging arm in?...The problem is the 'cupped' washers with the O rings stop the arm from going forward to get the bolt in?...I'm about 1/4"short to align the holes up & if I maybe use the earlier 'washers' it would work..I have 'photos & will post them tomorrow...VERY confusing indeed..Thanks in advance...
T120R '67
6T 1965
T110 1958
Re: Swinging arm washers?
6T #696894 05/30/17 8:28 pm
Can't say when the change over happened, but the 67 doesn't take the later O-ring style cups, as they're bigger. You can easily make room for them by grinding though, I've done it myself, or simply buy a pair of the original ones.
Hth
6T #696896 05/30/17 8:40 pm
6T Offline OP
..the parts book said the washer 'cupped' F7848 has an o ring F8090?..
T120R '67
6T 1965
T110 1958
6T #696906 05/30/17 10:46 pm
I had the same thing happen to me with a '67 frame, turned out I was using a later swing arm and associated cupped washers, I switched to the earlier flat washers and all was well. I aslo used the earlier swingarm, as the machining for the o-rings was different, although I don't know that the later one wouldn't have worked. I also just checked my '67 parts book, no mention of o-rings or cupped washers.
tiumphdave #696928 05/31/17 5:23 am
6T Offline OP
Hi Dave.both parts books number 6&7 have the 'cupped washers & O-rings'(F7848/F8090)mentioned but as this is a bit of a 'bitsa' perhaps I'll just have to get hold of the earlier washers?Cheers!
T120R '67
6T 1965
T110 1958
6T #696929 05/31/17 7:07 am
I think you want part book No.5 for 67 650's.
Rod
New, Genuine Lucas Motorcycle parts!
Insist on something else.
R Moulding #696936 05/31/17 9:45 am
6T Offline OP
....very true Rod...must be old age galloping up on me..usually it's "Read the manual!" but for me it's the "Parts Book!"...Many thanks...
T120R '67
6T 1965
T110 1958
6T #697517 06/05/17 6:40 pm
I have a 66 6T and my Parts book clearly shows a washer ( called an end plate) and googling image of the part number shows a plain washer, no mention of any O ring at all either on Google images or the parts book No 4
The washer is 9/16" x 1 3/4 x 0.065"
Peter Gee #697523 06/05/17 7:58 pm
6T Offline OP
...thanks very much Peter.
T120R '67
6T 1965
T110 1958
6T #697559 06/06/17 2:11 am
...hello 6T I had the same problem with a 67. I had only the frame so was easier. I put all the frame on a bed and after a lot of massage and hit with a hammer and a piece of wood (with plenty of cushioning on the swing arm) the other end plate decided to fit but then with the frame and wheels I needed a jack and a friend to see the hole in the LS to help the spindle find the hole.
