Hillbilly bike
Hillbilly bike
Finger Lakes
67 frame question
#690464 04/04/17 4:44 pm
I have owned a few 67 A65's this frame does not have the shroud around neck for key is there one made without this or maybe a bit of a wreck caused previos owner to remove
http://www.britbike.com/forums/tmp/2304.jpg
Re: 67 frame question
Mike Carter R.I.P. #690483 04/04/17 7:51 pm
The down tube end looks crudely formed, was it "chopped" at some point?
Mike Carter R.I.P. #690497 04/04/17 10:43 pm
Parts Dealer
Parts Dealer
Looks like it has been removed?
Mike Carter R.I.P. #690515 04/05/17 3:50 am
Mike the gusseting is more than just for the key switch; it serves to strengthen the frame. No I've never seen a dry-frame A65 without it unless it was removed for whatever reason, usually to modify the frame length or steering angle.
Mike Carter R.I.P. #690552 04/05/17 2:01 pm
All the angles seem to be correct and without shroud no place for the fork lock to go into....looks like I will be metal forming and welding.. I thought it may be an early A50 frame as the number boss is not the same as my other A65's and numbers although matching don't look factory...aurrggh
Thanks all
Mike Carter
Mike Carter R.I.P. #690639 04/06/17 12:40 am
My quess it survived the torch/sawsall !! I have a #'s matching engine& frame 69 T-100C. But it's was raked and stretched, hardtailed and hac\s a 16' HD drop center r/rim with a large hole rubber side valve tube. Durfee girder 65" wheel base!! fun brutal riding 70's chopper.
Mike Carter R.I.P. #690858 04/07/17 8:04 pm
Thanks For the photo mike, it's very interesting and useful for
My A50 Daytona project that has some frame changes around the neck and this photo add explanation as to why those changes were made.
Allan Gill #691443 04/12/17 6:07 pm
I've got a Hornet that came sans the neck shroud. I'm fairly sure this bike was campaigned back in the day and the support tube just under the backbone shows signs (welded area) of having been modified (I theorize) to tighten up the steering angle.
Mark may be correct that this extra gusseting adds some strength to the frame, I dunno but one thing is for sure, it certainly serves to cosmetically clean up the area of the tube welds at the neck. If I ever manage to get this bike back on the road I'll probably run it as is to better monitor that welded area. That being said, I actually acquired a shroud long ago that remains uninstalled. It appears to be from an early version A65 near as I can determine. It's available if you're interested.
The arrow in the first photo indicates the weld on the support tube of the Hornet:
[Linked Image] [Linked Image]
Mike Carter R.I.P. #691446 04/12/17 6:28 pm
As the gusset is only attached to the downtubes the amount of strength it will impart is about 50% of nothing.
My gut feeling is it's just cosmetic
Mike Carter R.I.P. #691450 04/12/17 6:41 pm
The gusset is also welded to the steering head, so yes it is meant as reinforcement.
Mike Carter R.I.P. #691465 04/12/17 8:20 pm
That sure looks like a raking out as opposed to just a repair, the head steady mount on the frame also looks like it's been moved forward too.
Phil R #691597 04/13/17 6:58 pm
Phil I sent you an email ...thanks
Mike Carter
Mike Carter R.I.P. #692092 04/17/17 7:53 pm
Thank you for the shroud Phil, I am in your debt
Mike Carter
