steve-d
steve-d
Pennsyltucky, USA
Page 4 of 4 1 2 3 4
Re: where do the coil wires go on dual plug heads?
kevin #579947 01/08/15 4:53 pm
are there modifications that one can do to a stock triumph T120 head that can significantly increase swirl? maybe my question includes increasing velocity in general, as it seems to me that one would help the other.
No, the 650 head, or the late 500 for that matter, does not lead itself to having a squish band without a lot of work, and expense. The 750 twin can be worked to have a squish, but requires different pistons and some work.
Increasing air velocity through the ports seems counter intuitive. Because drawing air into the cylinder is a timed event, air velocity is more than a consideration. In a lot of tuner's eys it is where a lot of the magic comes from. The common thought is to increase the port diameter, but in my experience with the 650 it is too big for a street engine to start with. For street work the early 9 bolt head with the small non-unit ports and valves makes for a more useable, easy to tune, and more rideable street bike with a good wide power range suitable for the standard 4 speed gearbox.
The same port as the late 650 works real well with the large bore of the short rod 750. Unless you know exactly what you are doing I would leave the ports alone, but concentrate your time and money to the area around the valve seat.
kevin #579951 01/08/15 5:15 pm
JH,I saw that photo of yours recently and meant to ask...
They are blanks - you chuck them up and machine them to match the squish band in the head. The final shape, after some nibbling away the parts I don't need, is not unlike the ones the factory used in the T100 and Triple racers.
As the area under the dome is also not machined you can vary the top of the dome for improved flame propagation and final compression ratio. You need to put them in a piston vice and go at them in the Bridgeport. This also allows you to vary the piston weight to fine tune balance.
kevin #579985 01/08/15 8:53 pm
No, Nick no misunderstanding here. And they also have sensors to measure dynamic cylinder pressure under no-load and full-load. These can be used to predict abnormal cylinder pressures that can lead to detonation.
kevin #579997 01/08/15 9:48 pm
I worked the squish in a different way. Instead of squishing around the edge of the piston into the centre, I put the squish opposite the spark plug so the charge is pushed around to the plug. No detonation problems with this on pump fuel.
kevin #580012 01/08/15 11:56 pm
Triton Because of the size of the valve cutaway on the intake side of this piston if the rings aren't set a bit lower than normal the valve pocket cuts right into the ring groove. Not ideal, but it seems to work out. Except for the valve pockets the whole dome of the piston above the ring grooves is solid when I get the pistons. The head is machined and measured and the dome cut to match. Then the inside is cut leaving a dome thickness in the range of .125". Do the same with the 750 we ran for years.
David - Nice "another way to skin the cat." KB pistons have been making a piston for sportsters with a similar dome configuration for quite a few years now. It is a whole new world when you find out you can get partially finished pistons and match the pistons dome to the head. SOme people create a trough across the top of the pistons in an effort to improve combustion. Still some small signs of detonation. It seems you exercised the throttle some, or were beginning to loose a valve spring, with that right cylinder exhaust valve kissing the piston - was it worth it? DId you win...
kevin #580013 01/09/15 12:44 am
That was probably when I was following an RG500 with my Wenco framed R3 racer on PCH coming back south from Laguna Seca. He could not out accelerate me coming out of the corners. If the throttle cable doesn't need adjustment periodically you're not turning hard enough, yes?
John Healy #580089 01/09/15 2:17 pm
The T140D head with the parallel ports and the constant velocity carburetor. The T140D port design dramatically increased swirl improving combustion and lowered combustion temperatures to a point where it required running spark plugs 2 ranges hotter to prevent fouling.
hi John, very interesting info as ever.
But I still cannot understand how you can have "improved combustion" and lower temperature at the same time? Is it because they had a very lean carburation and very low CR?
kevin #580111 01/09/15 4:32 pm
Simply stated - the swirl from the incoming mixture seems to mix the air/fuel mixture better than the "splay port" resulting in a better burn or "improved combustion" = little or no detonation.
no-detonation = lower combustion chamber temperatures - and the "explosion" isn't pushing past (blowing away) the protective boundary layer that insulates the head from the heat of combustion.
With lower compression, which they had already done in previous years, you compress the incoming charge less. As a result the fuel air mixture does not heat up as much as it did with a higher compression. It is all a balance of controlling pressure in an effort to control heat. You want the fuel/air charge to burn and not explode.
The constant velocity carb prevents the rider from taking a handful of throttle at low rpm. Doing so, you can drive the dynamic cylinder pressure, and gas temperature with it, to the point that when the spark plug fires the additional pressure created by combustion pushes the end gas (un-burnt gas opposite flame front) to a point where it will self ignite. You have just created a case of severe detonation. In a CV carb the slide responds to manifold vacuum, and not just to throttle position and prevents the rider from causing the carburetor from delivering a big gulp of air when it cannot handle the dramatic increase in cylinder pressure it causes.
A good example of this is checking the cylinder pressure with a gauge. Leave the throttle closed and you get a very low reading - There is no air through the carburetor to compress. Open the throttle and the engine takes that big gulp and the needle jumps up over 100 pound and more. That is dynamic cylinder pressure - it changes with slide position.
John Healy #581391 01/17/15 2:57 pm
I get a great education when I examine some of these discussions. Taking this in a slightly different direction, It seems that most if not all the comments here apply to highly modified machines. I am no stranger to mixing fuels to reach necessary octane levels.My 1969 BSA owners handbook shows a minimum octane requirement of 98 ( I'm thinking RON) for a stock 9:1 A65. HB provided two good links,the Sunoco one I am familiar with. The other brought out something that seems to be lost on some people-that a slightly lower static compression ratio with a factory engineered timing curve is better than a retarded timing curve with high(er) compression ratios and is the better way to get our old -stock- iron to run on 91-93 octane pump premium.The article mentioned a 1 to 2% loss in torque with lowered compression. Didn't the majority of T140's have an advertised compression ratio of 7.9:1 in preparation for lower octane unleaded and the phasing out of super premium leaded fuel? With A65's or T120's I was never satisfied with the performance of retarded timing so as to operate on sub-standard fuel.The engine is so much happier with 100 octane and the factory settings and so am I.SO my question is, would quality forged pistons-not cheap- that provide a lowered 8:1 compression ratio for otherwise stock A65,T120,etc. machines be marketable, and if not why not? Hoping for a lot of feedback.
1969 BSA A65T w/A70 engine
1970 Royal Enfield Interceptor S ll
kevin #581392 01/17/15 3:07 pm
My 76 T140V at 7.9/1 would run on lamp oil
kevin #670447 10/08/16 9:26 am
Transgarp calling John Healy smile
I dismantling the engine of the T120R in May
According to this Web site, the wear of my conn-rod bearing confirms the detonation caused by a gasoline of too low octane or a too high C.R., here 9.5:1 with 750 Morgo kit
http://www.agkits.com/bearing-failure-analysis.aspx
My bearing wear:
http://transgarp.dyndns.org/motorcycle/0800/20160000/20160521_04.JPG
The last year 2015, I ride under this configuration :
750 Morgo kit CR 9.5:1
28° full-advance
21 teeth front sprocket, 46 rear
Detonation
In August 2016 I reassembled the engine with this configuration :
750 Routt kit CR 8.9:1
38° full advance
22 teeth front sprocket, 46 rear
No detonation
All my problems of detonation disappeared, while riding with the same super gasoline of Shell and more power all rpm smile
You surely wonder why I have enlarges the front sprocket.
Not the choice because of the necessary release of the chains to the top of the front of the swingarm considering which I installed the complete back suspension of a Honda XR650L on the frame of the T120R
http://transgarp.dyndns.org/motorcycle/2000/20161001/17.JPG
http://transgarp.dyndns.org/motorcycle/2000/20161001/08.JPG
kevin #673622 11/06/16 2:32 pm
What do you know, I have an A65 that has the primary side rod brgs that look just like that. Spitting image. However, I have no information on the motor or how it ran when it was a complete bike. I know it had under 10,000 miles on it and the throws and bush are factory clearances. I assume it was all stock. It is a 1971 engine and everything else is specking out as should be. Maybe it had some bad spark knock hey? detonation? I don't know, but I have never seen a brg look like that except in books. I have seen automotive engines like a big block Chevy that was ran very hard at high speeds for several miles then shut down right afterwards and had a slight knock in the morning after cool off, when torn apart one rod or rather one rod with the bearings must have been to hot at shut off and stuck to crank, when it was disassembled it looked similar to what you have. No harm to rod or crank, could only figure one defective bearing that lost its integrity and stuck to crank. Reassembled and fine good to go. Sometimes you do even get defective parts from factory, I know this BSA engine has never been apart so maybe a bad one. Ive seen several bearing failures from vandervill in the past 25 years.
kevin #675272 11/22/16 10:42 pm
Not sure if the original post and original questions are still relevant. But to respond, my AHRMA road racer T140 engine has 11.5:1 pistons, has a twin plug head done many years ago at John Healy's suggestion by Dana Johnson at Import Machine Service in Mass., and uses a crank-driven twin plug ignition I got from Rex Caunt (modified PVL with little twin lead coils). When I first did this, I used a Boyer Powerbox, and John Healy suggested to me to place each of the two wires from each coil on opposite cylinders to get better spark, and I have continued to do that, it seems to work the best that way. To answer the other questions I saw above, I use 32 degree fork lead, and 110 race gas. The effect has been to make the engine run cooler and smoother and make more torque--the combustion chamber shape and flame front were obviously issues with a single plug and this very high compression. Runs great! Doubt twin-plugging is necessary on the street with 9:1 or so, though.
kevin #678816 12/24/16 3:29 pm
kevin Offline OP
i twin-plugged my old street bike when all i could get was 89 unleaded. these days i use 110 leaded premium and run the timing back to 30 BTDC.
i'm running 11.75:1 now on another machine that is single-plugged at the moment, because i'm using an old ARD. but i'm using VP 108 C12 in it
http://www.racefuel.com/vp-c12-racing-fuel-108-octane/
kevin #796019 01/19/20 6:05 pm
Getting this old thread going again-
The 650 Triumph race bike will be wearing a new 4 plug head this season. I'm going to use the Boyer race ignition that it has been using. I have a selection of dual output coils, all of them 3 ohm that I was going to try. I know that's a bit over the total 5 ohm recommended but we'll see how it goes. Right now, my issue is real estate. Kind of running out of room for 2. I can get a coil for a HD 1200 S. 1 coil, 4 plug wires. Any thoughts about if this would work? Not sure if Sportsters of this flavor were wasted spark ignitions like the ones with single plug heads.
Comments from those who have a better understanding of electrics appreciated
kevin #796024 01/19/20 6:29 pm
Those 3 ohm coils in series will work just fine. Just make sure the two coils leads from a single coil go to different cylinders.
You can get as exotic as your wallet supports, but I have used the same set-up on a Triumph short rod 750 (running 12:1 plus compression), and a 500 twin (with similar compression and a 9,000 rpm limit. Had no ignition related issues with either set-up. Ran the standard MKIV black box first and ended up with a blue box Micro-Power units (it was a test unit Ernie Bransden gave to us for testing). With the 750 we ended up with the timing in the low 20° range. With race gas we started at 32° and kept moving it back. It just kept running better as we did. Modified Aries pistons with a improved squish band!!
John Healy #796035 01/19/20 9:31 pm
Originally Posted by Mike Baker
... I'm going to use the Boyer race ignition that it has been
using.
which race ignition ? ... i think Boyer
has marketed both analog and digital ignitions as race ignitions .
what color or model is the box ?
kevin #796055 01/20/20 2:38 am
It's an alternator powered ignition. # 00066 I think.
Thanks, John. I'm a little nervous about getting this set up right, especially when I first start it. Spent a good amount of time checking piston/ valve clearances, squish , etc. Done that before. New to me is the 4 plugs. Am I right to assume that starting it at 38* BTDC on all 4 will not hurt anything? Or better to start it on the 2 main plugs and work into the second set? There's a lot of work in this head that I'm reluctant to mess up.
kevin #796088 01/20/20 5:05 pm
Could anybody do a simple wiring diagram for this dual coil set up ? say for a total loss battery powered race bike please .
Mike Baker #796102 01/20/20 7:41 pm
wow , that is a vintage design .
looks like the ignition box
also houses ... a voltage rectifier regulator ... but no capacitor...
so still need a battery ?
kevin #796185 01/21/20 12:00 pm
No battery. Out of the box, firing it for the first time, the instructions say to connect a battery to the positive side of the coil for a "jump" I suppose. After that, it's always started without fuss. Haven't looked but I'd say that there probably is some sort of capacitor in there somewhere.
kevin #796199 01/21/20 2:55 pm
Some dual plug H*rley coils are actually two coils in one package, they just made the one side common internally. There are three primary terminals, coil1, coil2 and common.
[Linked Image from wheelhorseforum.com]
Dual plugs start the burn in two places so has faster pressure rise than a single plug. The timing has to be retarded to prevent the peak pressure being too close to TDC.
kevin #796276 01/22/20 11:21 am
Thanks, Dave. Do you reckon 30* btdc is a safe place to start?
Page 4 of 4 1 2 3 4
Moderated by  Allan G
