splittie65
splittie65
Surrey, UK.
New BritBike book out!
Hop To
My friend is rebuilding his 1970 T120R Bonnie.
He's using a Morgo 750 kit along with the Morgo oil pump and everything else is brand new.
The cams and followers need replacing, or regrinding.
Any suggestions for improvements over stock parts? It's going to be a road going bike, not looking for super power, but what are some of the better options available while the work has to be done?
Cheers JG for DB in Australia
http://www.megacyclecams.com/
Take your pick.
Great customer service.
There's no one size fits all answer to this question.
Personally, I'd be more than happy with 650 cams in a road bike. They give a sweet running engine that's fun to ride.
If power is your thing or for competition, then I'd swap the intake for a T140 with appropriate followers.
Born To Run
Born To Run
I'd see if I could return the Morgo oil pump or sell it. For a road-going bike, the stock pump is more than adequate. Spend the money on an external oil filter.
What is wrong with a Morgo plunger oil pump ? (or is it a rotary gear version)
...some years ago I bought a rotary from a UK shop, later with all that rap about it I emailed Morgo telling if they can changed me that one for a plunger one with my lose in money (remember that I did not bought it from Morgo) so I sent the pump and they provided with a plunger one and a T shirt and may be the overseas shipping cost; I do not remember right now. Pretty cool.
-I still do not get it the external filter...you always will tear down the motor before the sludge trap be full again.
Getting all super clean in the rebuild, super clean the lines and oil tank; changing oil etc
you do not need any external filter.
You don't have to fit an oil filter, but it's no bad thing if you do. It filters the oil!
There have been entries on this site that say the MORGO gear pump over-produces and causes leaks at the rocker-box area.
It has been some time since I read this, so I hope another correspondent will reply with better information.
My 67 TR6R has the rotary.
It doesn't leak around the rocker boxes - or anywhere else, for that matter.
That's a 100% approval rating from a sample of one (as the small print on the adverts says).
"1967 TR6R"
My friend has a rotary, maybe one of the first sold, installed many years ago. It never gave any problems but was skillfully installed, ie. pressure relief valve correct and I think the return to the sump opened up to prevent backup of oil in the timing cover.
However, like with any gear pump, there can be leakage around the gears and over time the oil tank will empty into the engine. Not a problem if you actually ride them.
I've installed many Morgo plunger pumps myself with 100% satisfaction. Note that the Morgo plunger pumps are essentially 750 pumps and the most benefit is gained through installing these in earlier bikes. And, yes, there are pre unit versions available, too. I've only seen one four valve pump and that was installed in the street tracker I worked on a few months ago. That bike needed the inside of the timing cover relieved a bit to fit the wider pump. It got a bit thin before the timing cover went all the way on....
I believe all the Morgo plunger pumps have the same size bores as stock Triumph pumps. What I don't know if the Morgo plunger pumps flow more oil...Morgo may be manufactured to a higher standard?
I know guys running the fastest land speed record Triumphs using stock pumps...I believe a stock pump that's within specification is all that's needed..
Morgo has bigger plungers than a Pre-unit Triumph pump.
Triumph incrementally increased the bore size. I think there are three sizes.
Putting the 750 sized plungers in an earlier bike makes for peace of mind.
Correct, the Morgo pre unit pump plungers sizes are about the same as a later unit pump..
Service manuals available on line and look like reprints of original Triumph manuals show the same oil pump plunger sizes for Triumph unit 650 from 63 through the early 750's. I have seen pumps with smaller feed plungers on early unit 650's..
