Ducknaldo
Ducknaldo
Denmark
Soupdragon, Gabby, LostMarfbles, Bill Davis, DGreear
10735 Registered Users
franko 121
DavidP 60
Rohan 56
reverb 53
922,009 mail-order LSR
Topics67,140
Posts672,916
Members10,735
30 registered members (Allan Gill), 278 guests, and 755 spiders.
Ticking sound on LH side exhaust area #667850
09/16/16 8:46 pm
09/16/16 8:46 pm
Connecticut, USA
Bob E Offline OP
Bob E  Offline OP
Connecticut, USA
Howdy people. got a question, have not had the 67 BSA Thunderbolt out in a while, but rode it last weekend and had a ticking sound coming from left exhaust area sounds like. I think the sound was there last year when I rode it also. could it be a valve adjustment needed? any other ides? Thanks Bob
Re: Ticking sound on LH side exhaust area [Re: Bob E] #667854
09/16/16 10:12 pm
09/16/16 10:12 pm
Possible exhaust leak between the exhaust port and pipe.
Re: Ticking sound on LH side exhaust area [Re: Boomer] #668183
09/19/16 8:50 pm
09/19/16 8:50 pm
Connecticut, USA
Bob E Offline OP
Bob E  Offline OP
Connecticut, USA
Thanks Bill, will have to take a close look at it and try and seal up any leaks in that area
Re: Ticking sound on LH side exhaust area [Re: Bob E] #668188
09/19/16 10:03 pm
09/19/16 10:03 pm
Mark Z Offline
Mark Z  Offline
Exhaust leakage around the header pipes is a common problem on BSA unit twins, as the pipes are just a push fit in the head, and they tend to loosen over time due to vibration and such. There are various ways to fix this, some more elaborate than others. For a quick but somewhat temporary fix, and to find out if that is indeed the problem, you can shove some goop in behind the heat sink. There's a product called Motoseal, but I haven't tried to source that in a long time. I use fingertip caulk, the stuff that you use to seal around screen door frames. You roll it into a string, wrap it around the header pipe, push the heat sink up against it, and tighten it down. It does deteriorate after a while; I find I have to reapply it about once a year.
Re: Ticking sound on LH side exhaust area [Re: Bob E] #668245
09/20/16 11:55 am
09/20/16 11:55 am
Lancaster, California
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
@Mark Z +1 I agree
Do you have the original BSA exhaust pipes or reproduction? I have found that the original exhaust pipes have a better fit into the head as compared to the reproduction types, but they both work. If you look at your exhaust fins on the clamp and the head, sometimes you will see signs of exhaust carbon that has been escaping around your exhaust pipe. On all "push-in" exhaust pipes, I use a red sealer... similar to this http://ttiexhaust.com/Category-MiscComponents/PermatexSealer.jpg Clean all surfaces, apply, and allow 24 hours to seal. This will solve your "ticking" problems. I hope this helps
Re: Ticking sound on LH side exhaust area [Re: C.B.S] #668438
09/21/16 7:56 pm
09/21/16 7:56 pm
Connecticut, USA
Bob E Offline OP
Bob E  Offline OP
Connecticut, USA
C.B.S
I have repo pipes on it and the fit is a little off. I have some red RTV that I will try and seal up any gaps where the pipes go in the head and see how that works. Thanks for the help.
Re: Ticking sound on LH side exhaust area [Re: Bob E] #668448
09/21/16 9:45 pm
09/21/16 9:45 pm
kevin roberts Offline
check the valve adjustment, like you suspected.
if that's what it is, your problem is solved.
super easy on a BSA
Re: Ticking sound on LH side exhaust area [Re: kevin roberts] #668664
09/23/16 8:43 pm
09/23/16 8:43 pm
Connecticut, USA
Bob E Offline OP
Bob E  Offline OP
Connecticut, USA
Thanks Kevin, I will check the valve adjustments also.
Re: Ticking sound on LH side exhaust area [Re: Bob E] #668775
09/24/16 8:49 pm
09/24/16 8:49 pm
gavin eisler Offline
Ive tried all sorts of stuff on the head to pipes seal, what works best for me is Silicone sealer, bath type stuff. Everything must be cleaned back to bare metal before application, this means pipes off, a small wire decoke brush in a drill is best for doing the ports, stuff a rag in first in case a valve is open. This is a permanent fix, unlike the proprietary exhaust pastes which tend to crack and fall out. Smear some goop round the headers, then push home,wipe off excess, job done.
if the ticking is still there after this and checking tappets then start worrying, could be piston slap, maybe head gasket or small ends, take the easy ones first.
Re: Ticking sound on LH side exhaust area [Re: Bob E] #668836
09/25/16 11:12 am
09/25/16 11:12 am
florida
LeonGustus Offline
LeonGustus  Offline
florida
My left ear hears better than the right, so all my noises come from that side. I cured one tick by rolling aluminum foil into a string and packing it into the exhaust until its flush with the heat sink. Not entirely a "fix" but cheap and easy. Fixed another tick - by tightening the head steady rod. That was a boo-boo left over from a valve job that required replacing the valve guides - one of which was quite ticky. My timing gears are a little ticky too, but they're on the right. Now I dont hold with the expression "a tappy tappet is a happy tappet" but as hard as I try, I still get a little ticky. Maybe the tach cable is ticky. I'll pull that and check. I wonder if I have any anti-tick lube?
October of 69-A50R
Re: Ticking sound on LH side exhaust area [Re: Bob E] #669316
09/28/16 6:13 pm
09/28/16 6:13 pm
Disconnect the cable and see if that cures it, the primary chain gets noisy when worn.
