awesomebsa
awesomebsa
vancouver, b.c.
Payne, Mysticbus, T140v, BradM, Andrew C.
11015 Registered Users
franko 136
koan58 73
DavidP 56
1,148,858 mail-order LSR
Topics68,936
Posts690,891
Members11,015
33 registered members (Andytheflyer), 1,816 guests, and 929 spiders.
Total Loss? #665654 08/29/16 6:31 pm
HawaiianTiger Offline OP
I'm working on an old Triumph motor built for dirt track racing. It was made up from replacement cases and stamped with 0120, the same numbers that appear on the frame, which is a purpose made dirt track nickel plated frame of unknown manufacture(as of yet, anyway. Pics of that to follow later)
This whole bike was gifted to a local man while he was in Costa Rica.
Who could have guessed a dirt track Triumph would be living there? He also scored a '68 TR6, also in pieces.
I'm bugged by the fact that there are fine thread case screws in the timing side, and coarse thread screws in the primary. If that means what I think, then this really is a bastard motor. The primary side case has the multiple little Triumph stamps from the late sixties.
But, horrors upon horrors, this is what I found when I popped off the gearbox covers.
I've seen rust on gears and such before, but nothing this bad. In your opinion, is this gearbox a total write-off?
Quite frankly, I was lucky to get this apart without breaking anything.
Re: Total Loss? [Re: HawaiianTiger] #665660 08/29/16 6:54 pm
tiumphdave Offline
Yep, total loss, in my experience. I've drug home several just like this.I just took a 500 unit apart that looked the same, I think it's from sitting outside and water runs down the clutch cable (I'm guessing). I've had primaries equally ruined.Sucks.
Re: Total Loss? [Re: HawaiianTiger] #665710 08/30/16 5:33 am
Stuart Online Content
Hi Bill,
Recent rust removal thread. Try one or more of the suggestions? Nothing to lose but a bit of time but maybe save the bits after all?
Re: Total Loss? [Re: HawaiianTiger] #665721 08/30/16 8:18 am
ken sak Offline
rust removed, pits in hardened parts seen, I've done that recently and
will use all the parts -it didn't look nearly as bad as that thou
Re: Total Loss? [Re: Stuart] #665722 08/30/16 8:30 am
Jon W. Whitley Offline
Yeah Bill,
Like Stuart said, try the rust removal. Throw the entire transmission and all rusty parts into a bucket filled with white distilled vinegar for a week or so. Take them out hose them off and disassemble and put them back in for another 3 or 4 days or a week and take them out, clean them off, neutralize the acid, then oil them up and take stock from there. You will be surprised at the outcome if you haven't done this before.
1971 BSA A65 650 - Project
Re: Total Loss? [Re: Jon W. Whitley] #665733 08/30/16 10:37 am
tiumphdave Offline
I'm sure the rust can be removed in a variety of ways, I think the issue is the condition of the gears and shafts after de-rusting. Do badly pitted gear teeth still shift and work as they should? Seems they would wear rapidly. I know saving a questionable piece is part of the fun, but aren't transmissions around a hundred bucks or less?
Re: Total Loss? [Re: HawaiianTiger] #665771 08/30/16 2:52 pm
R Moulding Online Content
Depends who I'm doing the job for. If it was my bike I would clean it all up, replace any broken bits and consumables then suck it and see. If I'm doing the job for a punter then the options need to be explained so they can make an educated choice that suits their pocket.
Rod
New, Genuine Lucas Motorcycle parts!
Insist on something else.
Re: Total Loss? [Re: HawaiianTiger] #665774 08/30/16 2:58 pm
We're looking at complete gear clusters and shafts including shift forks for under 200$ right now.
I used to be able to source complete NOS gear clusters for 500$ and did quite a few pre unit boxes that way. It makes for a like-new gear box.
What I'm most concerned about is, like mentioned above, does it weaken the gear significantly, cause a lot of noise, or give problems with shifting? I'm not sure I want to take that chance and then have to rip it all apart all over again.
I have a reverse electrolysis kit in the garage. I use it on old rusty fan parts. Really saves on labor. I'll probably toss a gear or two in there just to see how bad they are.
Re: Total Loss? [Re: HawaiianTiger] #665782 08/30/16 3:26 pm
leon bee Online Content
I saved this one, it was hours and hours of work. Pressing gears off shafts, etc. Now I'm way too old to mess with one like you got there.
