expresidente
expresidente
Germany North
Replacing rear drum/sprocket
#654466 05/27/16 5:28 am
After having the front final drive sprocket replaced earlier this month, I have purchased the rear drum/sprocket and a new chain from Baxter's. I also purchased a bearing to go in the drum per the parts book illustration. It looks like the steps necessary to get the old parts off the worn drum/sprocket and installed on the new one are a little bit involved.
If any of you has done this before, please advise any suggestions, pitfalls, tricks etc.
Thanks.
Stubb
Re: Replacing rear drum/sprocket
stubbicatt R.I.P. #654505 05/27/16 11:32 am
Any B.S.A. workshop.manual for the Gold Star like the Bruce Main.Smith or Haynes manual explains how to take out the bearings.Not too difficult.
Goldie John.
stubbicatt R.I.P. #654509 05/27/16 11:46 am
Do pay attention to the fit (interference)of the bearing/hub.
stubbicatt R.I.P. #654582 05/28/16 7:23 am
Wow. Well, good thing I have the books.
stubbicatt R.I.P. #654703 05/29/16 11:30 am
The brake drum bearing is totally enclosed in the drum. Is this the bearing you want to replace. The bearing is secured by a dished washer and circlip which can be removed with a screwdriver.If this is the bearing you want to replace in the hub, this is the way to do it.
Goldie John.
stubbicatt R.I.P. #654756 05/29/16 11:15 pm
Check the new drum/sprocket for runout on the sprocket...have seen some (even original) with far too much runout when you spin them.
Oliver Wendell Holmes
Kerry W #654769 05/30/16 3:37 am
My original basket case came with a I presume Taiwan rear drum/sprocket.
Had 2.5mm run out!!
Converted a A65/B44 rear drum with alloy brake to fit with bolt on sprocket.
Rear sprocket has 47 teeth, so made pulling away a little easier with my RRT (not T2) box that I have fitted...
stubbicatt R.I.P. #654775 05/30/16 7:07 am
Thanks fellas. I'll check the runout first thing. I hadn't thought of that.
stubbicatt R.I.P. #654792 05/30/16 10:51 am
Stubbicat, the light that shines twice as bright lives half as long, so keep the revs down, or conversely,''life is a bitch, then you die''. make sure you don't hit anything.
The philosopher.
