SReppel
SReppel
Abbeville, Louisiana
Bigmac, Dexter67, jimmiejag, LAGONAS, TJohn
10995 Registered Users
franko 106
DavidP 61
koan58 54
1,126,297 mail-order LSR
Topics68,717
Posts689,007
Members10,995
36 registered members (Allan Gill), 3,868 guests, and 768 spiders.
62 A10 pistons #638633 02/05/16 12:12 pm
joe a. Offline OP
hi ....i have a set of .020" over AE11412 solid skirt pistons which i found where 9:1 cr.. once the engine is assembled it is a bear to start as you can hardly rotate the engine with the kick starter...bike does start and run ok (good) but it is just to hard to kick and not sure the next owner will be able to start it! plus it is probably tough on crankshaft and other parts! looking to put lower compression piston in and i am leaning to the lowest cr 7.25:1 since i am not sure( but think) the head , cylinder were milled/decked...can some one refer me to a good non split skit .020" over piston and part number and where to find them? is 67-1417 std bore? 67-1418 .020 over? any help comment would be helpful...thanks,joe
Re: 62 A10 pistons [Re: joe a.] #638646 02/05/16 1:34 pm
chaterlea25 Offline
On a recent A10 build, where the head had previously been skimmed 0.030 off square and then had to be refaced back to correct the issue
I came up with a solution of an 80 thou thick head gasket
I got this from "copper gaskets unlimited" in Arizona
http://www.coppergaskets.us/contactpage.html
9:1 should not be that hard to kick over?
Do you know how many teeth engine sprockett is fitted ?
I find the original gearing to be very low for todays roads
The A10 will easily pull a 22 or 23 tooth engine sprocket
This also has the advantage of making the engine easier to kick start
Re: 62 A10 pistons [Re: joe a.] #638680 02/05/16 4:57 pm
joe a. Offline OP
hi john,
it is unbelievably hard to spin the engine, if it did not start easily it would be impossible to start it..i have started and worked on many A10's but this one's difficult to kick over...figured it was time to address it and change all the rubber pieces that deteriorated while in storage last several years..
.....i have a 62 spitfire scrambler that i have been gathering pieces for so i will have to check it's cylinder and head to see what has been changed...i rode it on the highway several years ago and i do not remember it being geared too low..
joe.
Re: 62 A10 pistons [Re: joe a.] #638694 02/05/16 5:57 pm
Red Lapierre Offline
How easy does it turn over with plugs out?
57 A10 GF
61 A7
61 A10 GF
63 A10 SR
76 CB 125 Honda
76 FLH
2012 FLHTP
Re: 62 A10 pistons [Re: joe a.] #639068 02/07/16 10:52 pm
joe a. Offline OP
spins ok ......again bike runs,idles fine.
looks like head and cylinder may have had several thousands max material removed (resurface- lap to clean up )..
joe
Re: 62 A10 pistons [Re: joe a.] #639268 02/09/16 12:52 am
joe a. Offline OP
hi,
i checked and engine has a 17 tooth front primary engine sprocket....so a 17 vs 20 tooth makes that big of a difference in kick resistance.....joe
Re: 62 A10 pistons [Re: joe a.] #639427 02/09/16 6:45 pm
chaterlea25 Offline
Hi Joe,
Its good to find the cause of the problem,
17tooth is either trials or B31 road
Next question is what kind of use the bike is going to get?
For street use 20 will be very low, go for 22/23
Re: 62 A10 pistons [Re: joe a.] #639442 02/09/16 8:44 pm
joe a. Offline OP
hi john...
i will see what i can find as i have a 17,19 and 20 now....anyone want to trade for a 22 or 23? haha... i can not find part number for a 22 or 23 , any chance that some one has part numbers? ....hope they are not to difficult to find....it will be interesting to see how much it helps in kicking over.
joe
Re: 62 A10 pistons [Re: joe a.] #639448 02/09/16 9:29 pm
Tridentman Offline
18T was standard A7 and sidecar A10.
Standard A10 was 21T.
I always found the 21T on the A10 as a pretty good ratio for side roads etc.
Just my two centsworth.
Re: 62 A10 pistons [Re: joe a.] #639467 02/10/16 12:43 am
Dr. Z Offline
The part number for the 23T sprocket is 65-2541. Baxter's and Raber's have them on their parts list. I have been looking because my A10 is geared low for state highways here.
Craig Zaspel
T100R
BSA A10
Re: 62 A10 pistons [Re: joe a.] #639521 02/10/16 1:25 pm
joe a. Offline OP
i found this number for a 22 t,45-2774...
thanks for all the help guys...appreciate it.
joe
Re: 62 A10 pistons [Re: joe a.] #706512 08/28/17 4:36 pm
PhilBSA Offline
New poster
New poster
Hi I came too this forum through searching the internet for BSA part number 67-1417 , the only reference to this piston on the whole WWW is this thread?
I'm searching for this part after My Dad found His pistons to be 67-1417 and the other coincidence is a 17 tooth primary sprocket was fitted making the bike
hard to kick.
The only bike we believe fitted with this sprocket were trials bikes.
Any one have a clue where these piston originate?
no
Re: 62 A10 pistons [Re: PhilBSA] #706583 08/29/17 10:20 am
BSA_WM20 Online Content
67-1417 is a number found cast into the underside of the piston, it is the raw casting number, for BSA's internal use only, not the finished machined piston number which is usually 1 or 2 numbers lower.
BSA typically machined 3 different sizes from each casting
The standard A 10 piston in your fathers engine is part # 67-1416 and the + 20 is 67-1418 and the + 40 is 67-1420
These are all 7.25:1
The Part number of the finished piston will be stamped into the top of the piston and generally will not be able to be read being scrapped or polished off over the years.
Re: 62 A10 pistons [Re: BSA_WM20] #706853 08/31/17 4:58 pm
PhilBSA Offline
New poster
New poster
Hi Thanks for Your reply, 67-1417 is the number stamped on the top of the piston which is why we thought that was the actual part number, there is no other numbers to be seen.
no
Re: 62 A10 pistons [Re: PhilBSA] #706880 08/31/17 8:38 pm
V
VicCyclone Offline
V
67-1417 is the bare piston number for a STD 7.25:1 piston The Part No for the same finished piston is 67-1416 , 67-1418 is +20 and 67-1420 is +40 Not all BSA pistons have a cast in number on the inside but virtually all have a stamped number on the crown which is the number of the bare casting. Almost always, the part number of the finished piston with rings etc is one digit lower and will not be marked on the piston, only on the box if NOS.
VicCyclone
1965 A50 Cyclone Clubman
1966 Victor GP
1967 Victor Special
1968 Victor Special
1968 A65L
2009 HD FXDC
