Paul G80
Paul G80
Cambridgeshire UK
Steve Webb, Cyborg, Bargee, TBC, Vidane
10665 Registered Users
franko 115
NickL 54
Rohan 51
879,757 mail-order LSR
Topics66,610
Posts668,729
Members10,665
50 registered members (AML), 275 guests, and 604 spiders.
Page 1 of 4 1 2 3 4
My A70 #616744
09/09/15 9:12 pm
09/09/15 9:12 pm
Texas, USA
Ray Elliott Offline OP
Texas, USA
About a year ago I bought an A70 on eBay. I had wanted one for 40+ years. I tried to buy one about '78 from a fellow who rode into the Honda shop where I was working. He had no idea what he had. I guess I was too eager & he figured it out: he rode off & never returned.
This one was in pieces (though the engine not disassembled) & quite a few pieces were missing (no big deal as I have NOS or very good used parts for most).
Frankly I was fearful when I bought it as it was located 1600 miles from me: I had to go by pictures & conversations with the owner. It had a Triumph gas tank & the frame looked 'odd'. The space between the oil filler & rear frame looked like a '74+ T140 not an early OIF. The serial # was confirmed valid & I jumped in. I arranged for a company to pick it up & deliver it to me. I just couldn't bring myself to drive that far.
After it arrived I stuck a pencil in a spark plug hole & 'checked the stroke'. It was longer. The 7 stamp on the cases above the gearbox was there. Then I pulled off the timing covers & could see the thrust washer over the bushing. I finally quit panicking over what I'd bought.
It was the first time I had seen inside an A70. Then I had thoughts: I really don't know anything about the differences in an A70 engine & there was no way to pull the timing side gear without a puller as there is no clearance between the thrust washer, case & gear.
My original 'factory' puller was stolen with all my tools in the late 70s. So it was off to my buddy's mill & we made a gizmo to slide over the gear & fit a puller. It worked fine.
The cylinder base nuts were painted pink. No idea about that story. The oil was burned goo. The bushing clearance with 0.006". I found a NOS 0.010 bush on eBay.
I turned my attention to the frame & stripped it bare. What I found is interesting: someone had grafted a T140 subframe onto the original frame. I do not know the history of this machine so I have no idea who did it or when. But the work is good. And the subframe is straight. I found no cracks.
Pictures of the frame and timing side thrust washer are here. Some may find it interesting. Maybe someone will know the history of this frame.
My painter in Vietnam (where I usually work) painted a tank I had on the shelf for $40. I cannot paint & there's no use torturing myself trying. Since the frame isn't original I've decided not to worry about original colors & all that hysteria.
The frame has been coated with KBS & painted with black top coat. It looks quite nice.
When it cools here in Houston I'll turn back to the engine & will post quite a few questions before reassembly! I don't care if I hose an A65, but this one needs to be right the first time.
Thanks folks!
Ray Elliott
Re: My A70 [Re: Ray Elliott] #616756
09/09/15 10:28 pm
09/09/15 10:28 pm
Santa Barbara, California
KC in S.B. Offline
KC in S.B.  Offline
Very interesting! Thanks for posting. I expect you will get more questions than answers on an A70. I for one have never seen that timing side Thrust Washer you mentioned. Since the timeing side has the inner Thrust Washer between the crank check and the case, having a way the limit travel in the opossite direction on the outer timeing side case makes alot of sense. It certainly has to be better than the stack-up of shim washers !! Please do post more as you get it apart!
Oops,.. add 1 '65 XLCH
Re: My A70 [Re: Ray Elliott] #616785
09/10/15 3:31 am
09/10/15 3:31 am
Mark Parker Offline
Mark Parker  Offline
EdV has A70 pistons.
Re: My A70 [Re: Ray Elliott] #616832
09/10/15 2:04 pm
09/10/15 2:04 pm
Forfar, Scotland
JER.Hill Offline
JER.Hill  Offline
Forfar, Scotland
Hi Ray
Long time no speak. Personally never been inside an A70. But as Mark P said get into touch with Ed Valiket he know the motors. Also as Nick L said having that bearing set-up has benefits over the original.
We'll all be looking forward to seeing your future posts on the rebuild.
Re: My A70 [Re: JER.Hill] #616872
09/10/15 8:17 pm
09/10/15 8:17 pm
Bowral NSW Australia
John Goodwin Offline
There's a good cross section drawing of the crank and cases clearly showing the double thrust washers either side of the timing side bearing in the 1970 A70 parts supplement which is on Kims the CD man BSA manual set.
I'd post a copy of it but not sure if that would be ethically correct?
Doesn't look like it would be a major hassle to incorporate the idea in standard A65's if they didn't change the width of the bearing housing in the crankcase casting. It would need some machining and I suppose if you're going to do that you may as well go the whole hog and do the needle roller conversion while you're at it.
Here's a bit of the cross section, I'll remove it if it's considered bad form
Re: My A70 [Re: Ray Elliott] #718501
12/12/17 8:45 am
12/12/17 8:45 am
UK - Bucks
Steve Wilson Offline
UK - Bucks
Ray - or anyone else who knows...
Can you tell me how thick the thrust washer is? (No 9 in the parts list) looks like about 1/8"
Also - the shims (Number 10) In the picture they look like they are the same diameter as the thrust washer but that doesn't make sense?
I'm in the process of converting my A65 to this arrangement.
SJW
Re: My A70 [Re: Ray Elliott] #718556
12/12/17 9:04 pm
12/12/17 9:04 pm
Farnham, Surrey, UK
gunner Online content
gunner  Online Content
Farnham, Surrey, UK
Nice find and from your description the engine seems to be original so that's a bonus.
Not sure why someone would try and graft a T140 sub-frame onto an OIF A65/A70 frame, I can only guess it was because of previous accident damage.
If it was my bike, I would get the frame checked for alignment, distortion and integrity by a company using a moto-liner type jig. Very often bike frames over 40 years old have suffered all kinds of incidents and although the frame may appear straight some of the critical measurements such as head rake & twist, swinging arm alignment etc. may well be out of spec.
I would also be a bit worried about the large amount of brazing around the frame and oil filler hole. This may well be sound and perfectly usable and I don't know how much strength is needed in this area, others may chime in with advise.
Re: My A70 [Re: Steve Wilson] #718559
12/12/17 9:36 pm
12/12/17 9:36 pm
West Yorkshire
West Yorkshire
Why convert an A65 to this when you can fit a ball end DS, I’ve already got more miles out of my RHP Ball bearing DS than I had out of a RHP roller, also the crank end float is locked. The bike is used for touring and “scratching” and sees some punishment, so a good candidate in my opinion.
Re: My A70 [Re: NickL] #718608
12/13/17 8:34 am
12/13/17 8:34 am
England
F
ferretjuggler Offline
F
England
+1 for the thrust washer conversion on my A65.
I'm not keen on the end feed conversion or that needle roller main bearing.
But I could possibly be persuaded to go for the DS ball race instead.
I'm not sure about it's durability on a lightning spec engine.
The roller appeared shortly after BSA started to tune up these engines.
Were the ball races failing early, or was it just a precaution ?
Re: My A70 [Re: Steve Wilson] #718641
12/13/17 3:32 pm
12/13/17 3:32 pm
Texas, USA
Texas, USA
Steve - I know I wrote this down somewhere because I was so paranoid about losing the one I have. The engine is on my workbench. I only need to pull off the pinion. I'll measure the shim & thrust washer sizes. IIRC I found an appropriate shim @ McMaster but didn't need to buy any.
Ray Elliott
Re: My A70 [Re: JER.Hill] #718642
12/13/17 3:45 pm
12/13/17 3:45 pm
Texas, USA
Texas, USA
John - now that that work project from Hell is done I look forward to having a life again & being able to complete it (as well as any other projects).
Originally Posted by JER.Hill
Hi Ray
Ray Elliott
Re: My A70 [Re: Ray Elliott] #718685
12/13/17 11:15 pm
12/13/17 11:15 pm
Texas, USA
Texas, USA
I ran into an issue. Can't find my pinion puller. It's necessary on the A70 as the pinion is flat against the thrust washer. But I have some measurements that should solve the problem. I measured in mm for some odd reason.
Thrust washer recess is 54.5 mm wide & 3.37 mm deep. The washer is a reasonably tight fit, but I was able to slip in a piece of wire to get the depth.
The bushing is about 2.2 mm shorter than the A65 bush. I bought a 0.010" bush for use but ended up milling a bronze bush to the correct width bec I only wanted to make the crank round instead of taking to -0.010".
I'll make a serious search for my pinion puller so I actually can measure the washer.
The pinion is wider. Some seller on eBay has 10+ so they'll be available for a while.
All things considered, for an A65 I would do a bearing conversion. The right outer case has to be setup on a mill, find center & mill out the washer recess. It is no more work to fit a bearing. The crank has to be turned in either case. It is likely less work to turn to fit a bearing race. That only leaves drilling the end feed hole, fitting a quill, blocking the bush feed hole & fitting which ever type feed you want, internal or external.
Ray Elliott
Re: My A70 [Re: gunner] #718686
12/13/17 11:21 pm
12/13/17 11:21 pm
Texas, USA
Texas, USA
The seller knew nothing of the history. He'd bought it off CL. The fit is excellent & from my measurements is straight. I have thought about sending it & a spare frame to Framecrafters to make it original. But that's too much money.
Ray Elliott
Re: My A70 [Re: NickL] #718687
12/13/17 11:24 pm
12/13/17 11:24 pm
Texas, USA
Texas, USA
I wish I'd read this earlier. This would work exactly right.
Originally Posted by NickL
The shims are the same od as the crank.
I'm also going to have to do this mod to a damaged engine i have in at the moment. (Drive side bearing pushed out through cases.)
I'm going to make the thrust washer 2.4mm thick and have 2.5 machined into the case and 2.4 off the crank, i may have to shim it another thou or 2, we'll see.
The new ts bush will be formed/machined as the opposite thrust.
The od of the thrust looks like about 52mm. You can't go much bigger due to the pump stud. It doesn't need much anyway.
It will be cheaper and easier than end feeding it.
I think Danny at Burtons has the original ts bushes in stock, (well he did 35 years ago anyway.......)
Ray Elliott
Re: My A70 [Re: Ray Elliott] #718690
12/13/17 11:33 pm
12/13/17 11:33 pm
West Yorkshire
West Yorkshire
I can only go by my own experiences as you do Nick, I found a new bearing was a close fit in the outer race when new and was a firm fit on the crank, any slight tilt in the rollers when fitting the complete lot meant that the cases wouldn’t go together. The engine also started to show more vibes after a few thousand miles than when the bearing was new. The ball race was employed (after taking advice from a well respected friend, who has been to many internationals on his A65 and not known for dawdling has had good service out of his DS ball race. I eventually took his advice and been happy with it. To boot the CR of my bike is around 10:1
Not denying that the specs of the roller outweigh the ball, but they were also never designed to assist with end float control. Granted the A70 style bush conversion takes the issue of end float away from the DS side and placed onto the timing side, leaving the issue of the bearing no longer taking side thrust from end float.
Another thing to note is most owners bikes will never see enough miles to wear out any of the original style components.
Re: My A70 [Re: Allan Gill] #718723
12/14/17 7:03 am
12/14/17 7:03 am
BSA_WM20 Offline
BSA_WM20  Offline
Too true.
They were just adequate when the bikes war ridden to wok every day then taken out and thrashed on the weekend oft two up.
Now days when they might get a run 2 hours a month, rusting away is a bigger problem hence all the psts about sticking clutches, Carb stiction & wet sumping, three things I never knew existed till I turned 40
Re: My A70 [Re: Ray Elliott] #718732
12/14/17 10:07 am
12/14/17 10:07 am
UK - Bucks
UK - Bucks
Thanks for that - I don't need to exactly replicate the A70 but would like to be close as someone would have made some effort to get it right back in the day - No sense in ignoring their efforts.
SJW
Re: My A70 [Re: Ray Elliott] #718733
12/14/17 10:08 am
12/14/17 10:08 am
UK - Bucks
UK - Bucks
Thanks. That's useful
SJW
Re: My A70 [Re: Allan Gill] #718735
12/14/17 10:21 am
12/14/17 10:21 am
UK - Bucks
UK - Bucks
Alan - I see your logic but What I am trying to fix Is the oil pressure issue - fixing the end float at the timing side doesn't do that. I'm happy with the Roller bearing. If I use the A70 method it reduces clearance at the edges of the timing side bush and so prevents oil spilling out the sides - Which is claimed to be the reason for oil starvation on the big ends when the bush wears. The Devimead combined roller conversion appears to me to be a lot more work in comparison. (And a lot more cost)
SJW
Re: My A70 [Re: Ray Elliott] #718736
12/14/17 10:23 am
12/14/17 10:23 am
UK - Bucks
UK - Bucks
Ray - Interested in that crank pinion - not sure what would be different - do you have a link to that eBay vendor?
SJW
Re: My A70 [Re: NickL] #718757
12/14/17 4:11 pm
12/14/17 4:11 pm
Texas, USA
Texas, USA
Steve - I agree w NickL. The A70 gear is wider so that it has a flat surface against the thrust washer. It makes removing the gear without a puller that slides into the gear slots impossible. I took a piece of 1/4" x 2" x 1" steel & milled a slot for the gear. Then I use a 2 jaw puller against that gizmo (that I cannot find). If you're making a thrust washer it'd be easy to make it appropriate for the A65 gear.
https://www.eBay.com.au/itm/71-2689-NOS-Crankshaft-Timing-Pinion-Gear-BSA-750-Twin-A70-S192/312017437241?hash=item48a5b04239:g:XMAAAOSwpdpVZmrl
You don't have to use this pinion, it depends on how you do the thrust washer and turn the crank.
Ray Elliott
Re: My A70 [Re: Ray Elliott] #718814
12/15/17 1:11 am
12/15/17 1:11 am
Texas, USA
Texas, USA
I have pictures of the bush side before & after disassembly. PM me & I'll gladly share them.
Ray Elliott
Re: My A70 [Re: Steve Wilson] #718833
12/15/17 1:37 pm
12/15/17 1:37 pm
West Yorkshire
West Yorkshire
Even with the standard bush it should be a long time before you reach any surveer wear on the bush for it to cause pressure problems, a friends bike has covered over 20k with no problems, and Push Rod Tom's Hornet uses (or did use) the bush arrangement on his LSR bike, my 650 race motor will also get trialled with the bush arrangement too. However I completely agree that if your going to use a roller then the end float should be controlled at the timing side, which will limit the side thrust on the DS bearing lip.
Re: My A70 [Re: Ray Elliott] #719058
12/17/17 12:02 am
12/17/17 12:02 am
Texas, USA
Texas, USA
I found my puller, so here's some dims on the machined thrust washer recess, thrust washer & pinion.
Recess
OD = 2.144" or 54.55mm
Depth = 0.124" or 3.11mm
Thrust Washer
OD = 2.123" or 53.97mm
ID = 0.75" or 19.05mm
Thickness = 0.096" or 2.45mm
Thrust Washer Shims
I didn't measure, but they're slightly larger on ID than the washer and fit only over the end of the crank, not crank & crankcase. So they're much smaller than drive side shims.
Pinion
A65 - Side to side at highest point = 0.678" or 17.23mm
A70 - Side to side at highest point = 0.684" or 17.37mm
The A70 pinion as flat on the thrust washer side unlike the A65.
Ray Elliott
Re: My A70 [Re: Ray Elliott] #719090
12/17/17 12:58 pm
12/17/17 12:58 pm
West Yorkshire
West Yorkshire
Great information Ray! What are the chances that you have any photos to accompany this? All I have seen is the data sheet/diagram showing what parts are different and a set of crank cases.
Re: My A70 [Re: Ray Elliott] #719156
12/17/17 9:31 pm
12/17/17 9:31 pm
Texas, USA
Texas, USA
I have assembled pictures on Google of the crankcase recess, thrust washer, shims, crank, bushing, pinion, some before & after disassembly.
Anyone wanting me to share them please PM with an email address & I'll share them. All in all it's rather simple. Another of those "why didn't they do this earlier?" issues.
Before I assemble again I'm going to turn a spacer the width of the pinion. Not having to install, remove the pinion a few times will making shimming a quick, simple job.
Ray Elliott
Re: My A70 [Re: Ray Elliott] #719158
12/17/17 9:38 pm
12/17/17 9:38 pm
Texas, USA
Texas, USA
Or just click this link. Login with any Google account & request a share. I'll approve right away.
https://drive.google.com/drive/folders/1bOUpStLgNLkD1AFkDuF89NuM6zjBR68l?usp=sharing
Ray Elliott
Re: My A70 [Re: Ray Elliott] #719166
12/17/17 10:28 pm
12/17/17 10:28 pm
West Yorkshire
West Yorkshire
Sent a request Ray.
Re: My A70 [Re: Steve Wilson] #719225
12/18/17 1:20 pm
12/18/17 1:20 pm
UK - Bucks
UK - Bucks
OK - Think I found it and ordered one. Should be a late christmas present :-)
SJW
Re: My A70 [Re: Steve Wilson] #719232
12/18/17 1:45 pm
12/18/17 1:45 pm
Texas, USA
Texas, USA
Pinion, thrust washer or both? I'd like a spare thrust washer should you find a stock!
Ray Elliott
Re: My A70 [Re: Ray Elliott] #719310
12/18/17 11:22 pm
12/18/17 11:22 pm
UK - Bucks
UK - Bucks
Just the Pinion. I'm having a thrust washer made - could get a price for another but I think it was about 50 quid to make harden and grind.
SJW
Re: My A70 [Re: Ray Elliott] #719313
12/18/17 11:31 pm
12/18/17 11:31 pm
West Yorkshire
West Yorkshire
Thanks for the viewing of the photos, the shims look interesting, as though they are bigger than the OD of the shaft and also smaller than the ID of the bush, so I’m assuming these self centre? Or is it an optical illusion?
Re: My A70 [Re: Allan Gill] #719325
12/19/17 1:21 am
12/19/17 1:21 am
Texas, USA
Texas, USA
Allan, you're right, it's not an optical illusion. The shim ID is about 20.5mm, larger than the washer ID. The OD 36.5mm so smaller than the the diameter of the crankshaft bush journal. I assume that the shims turn with the crank as the inside of the washer shines brightly in the shape of the shim. The inner of the washer has a ground finish where the outside has machining marks. If accidentally reversed the shims would likely disappear quickly.
Ray Elliott
Re: My A70 [Re: Ray Elliott] #723725
01/30/18 9:44 am
01/30/18 9:44 am
UK - Bucks
UK - Bucks
That looks like about the same size as Classic Mini balljoint shims
SJW
Re: My A70 [Re: ferretjuggler] #723812
01/31/18 3:43 am
01/31/18 3:43 am
Mark Z Online content
Mark Z  Online Content
Just one man's half-educated opinion: I think much of the engine development at that time was largely driven by the competition market. In the States, the predominance of competition for A65s centered around flattrack racing, where you would take an A65, stroke it to 750cc, install a racing cam and hardened or aftermarket crank, port and polish the head, install high-comp pistons and 32mm carbs, etc. etc. and then take it out on the track and beat the bejesus out of it.
Like Alan, I'm of the opinion that the DS ball bearing main is adequate for "normal road use".
Re: My A70 [Re: Ray Elliott] #725544
02/14/18 10:44 am
02/14/18 10:44 am
UK - Bucks
UK - Bucks
Ray. Do you have any idea what the thrust washer is made of? I'm wondering if it is Hardened or if a plain steel would do the job. If it didn't need hardening and subsequent grinding flat it would be a lot cheaper to make
SJW
Re: My A70 [Re: Steve Wilson] #725545
02/14/18 10:45 am
02/14/18 10:45 am
UK - Bucks
UK - Bucks
Unfortunately I've checked and Mini Balljoint shims are just too big - about 38mm OD
SJW
Re: My A70 [Re: Ray Elliott] #725546
02/14/18 10:47 am
02/14/18 10:47 am
UK - Bucks
UK - Bucks
Crank and Crankcases are back with the machinist for the A70 conversion mods. Likely to be a couple of weeks before he can get onto it but looking forward to the results.
SJW
Re: My A70 [Re: Ray Elliott] #725554
02/14/18 1:28 pm
02/14/18 1:28 pm
UK - Bucks
UK - Bucks
Trial post - The BSA before open heart surgery!
SJW
Re: My A70 [Re: NickL] #725696
02/15/18 3:02 pm
02/15/18 3:02 pm
UK - Bucks
UK - Bucks
Well the front tyre is stock size I think - probably just the photo perspective. If I can get away with a non hardened washer that's good - will be cheaper (Or I can make it myself) shims not sure about making them neatly Just bought some online at huge expense! (£6 for a thin washer!!)
SJW
Re: My A70 [Re: Ray Elliott] #725712
02/15/18 5:20 pm
02/15/18 5:20 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
You can probably find a needle thrust race the right size. Already hardened and ground.
Re: My A70 [Re: Ray Elliott] #725811
02/16/18 3:47 pm
02/16/18 3:47 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
Torrington has just thrust washers. What dimensions are needed? From above, I.D. > 20.5mm, O.D. < 36.5mm. The TR(A/B/C/D)-1423 are 22.22mm I.D., 36.5mm O.D., A: 0.031", B:0.062", C:0.093", D:0.125" thick.
Re: My A70 [Re: Ray Elliott] #725884
02/17/18 5:16 am
02/17/18 5:16 am
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
There is also valve seat shims, come in 0.005" increments from 0.010". I am not familiar with the setup so advice might be wildly off the mark.
Re: My A70 [Re: Ray Elliott] #725924
02/17/18 6:49 pm
02/17/18 6:49 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
The whole arrangement looks a bit out of wack. I would not put the shims between the thrust washer and crank because the thrust washer should take the thrust, not the shim. The A65 arrangement has the shims clamped between the crank and inner roller race. I would put the shim between the pinion gear and thrust washer or thrust washer and crank as appropriate.
Then, I would make two half bushes with flange thrust faces inserted from each side with an appropriate gap in between to feed the oil into the bushes and crank. The current arrangement has the shim wearing against the edge of the timing bush and a plain steel shim will wear quicker. A thin shim is more prone to tearing than a thrust washer.
Re: My A70 [Re: Ray Elliott] #725938
02/17/18 10:41 pm
02/17/18 10:41 pm
UK - Bucks
UK - Bucks
OK There seems to be some misunderstanding of what's going on here.
Talking specifically about the A70 arrangement. The shim(s) are trapped between the thrust washer and crank and do not touch the timing side bush.
Crank, shims and thrust washer all revolve together. The shims just adjust the gap/float available across the timing side bush
Did that make sense?
The shims NickL is showing are very similar to the ones I have purchased. In my case I am aiming to make the crank 0.25mm shorter than the Bush and use a 0.3mm shim to give 0.05mm float
I've drawn the stuff up in 3D cad When I have reassembled the engine and proved it works I can publish the 'recipe' for others to follow as they see fit.
SJW
Re: My A70 [Re: Ray Elliott] #725940
02/17/18 10:50 pm
02/17/18 10:50 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
Yes, except it appears that there is no thrust face on the outside other than the end of the steel backed bronze bush, correct?
Re: My A70 [Re: Ray Elliott] #725945
02/17/18 11:05 pm
02/17/18 11:05 pm
England
Servodyne Offline
Servodyne  Offline
England
Interesting thread.
I'm current in the process of having an A10 crank modified to fit into my A70 cases, (unless someone out there has got a spare A70 crank). I want to retain the timing side bush as I feel that the combination of having an outboard thrust washer helping to maintain oil pressure coupled with a cartridge oil filter, I should get decent longevity out of the engine. Also it's one of the defining differences to the A65.
I'm using the inner race of a needle roller bearing (IRB2014 Imperial Inner Race 1-1/4x1-1/2x22.475) as a sleeve to bring the A10 timing side journal up to the 1.5" dia of the A70 bush. Due to the A10 journal being longer than the A70, my thrust washer will fit over the end of the the journal and effectively clamp the new sleeve bearing onto the crankshaft by the worm drive pinion nut. I don't envisage using any shims if I can get the machining of the bang on, or I'll make a bespoke inner thrust bearing to accommodate the difference.
The question is what is the factory recommend end float for the A70 configuration? I would have thought it may be covered in a service bulletin, but I have yet to find it mentioned anywhere.
With a standard late A65, the 1.5 to 3 thou float would increase as the engine gets up to temp and the crankcases expand. With an A70 set up, I would envisage that the end float would actually decrease and the material around the timing side bush expands, therefore 1.5 thou might not be enough.
1957 BSA A10 Spitfire
1971 BSA A65 Firebird
1971 BSA A70 Lightning
1975 Norton Commando
1961 Norton 99
Re: My A70 [Re: Ray Elliott] #725974
02/18/18 5:02 am
02/18/18 5:02 am
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
I got that the timing bush is shorter and recessed into the case. So the outer thrust washer is running on the aluminum case (and maybe the end of the timing bush)? That was what I objected to. If two flanged bushes were used for the crank (with the outer flange in the case recess), all the shimming would be on the outer thrust washer and it would run against a proper bearing (meaning replaceable if needed).
I am not clear on why the drive side shimming is needed. That controls the crank movement to the left and the thrust flange of the timing bush controls the right.
Re: My A70 [Re: NickL] #726007
02/18/18 10:11 am
02/18/18 10:11 am
England
Servodyne Offline
Servodyne  Offline
England
3-4 thou on the timing side 1.5-3 drive side. (if you are using a roller drive side.
I'm with you on the 3 - 4 thou on the timing side, but what's the point of shimming the drive side also to 1.5 - 3 thou? The sectional view in the parts catalogue doesn't show any shims on the drive side.
1961 Norton 99
Re: My A70 [Re: Ray Elliott] #726060
02/18/18 7:33 pm
02/18/18 7:33 pm
UK - Bucks
UK - Bucks
DMadigan
Yes you are correct and that's what BSA did. In my case I am having a solid bronze bush made up so the thrust washer will bear against that - Its quite thick so I'm OK with that. I know it will touch the Aluminium casing as well but I don't think that will cause a problem. It's certainly better than using the main roller bearing as the end stop in that direction which is what happens normally :-)
SJW
Re: My A70 [Re: Servodyne] #726092
02/18/18 11:39 pm
02/18/18 11:39 pm
UK - Bucks
UK - Bucks
To my mind the shimming on the drive side becomes redundant EXCEPT to align the two halves of the roller bearing SKF bearings claim they can be up to 1.5mm out (in one direction obviously!) But I'm aiming to stay the right side of 0.25mm. With my setup I can do that with just the shim bucket between the inner bearing race and the crank
SJW
Re: My A70 [Re: Ray Elliott] #726192
02/19/18 11:11 pm
02/19/18 11:11 pm
Mark Parker Offline
Mark Parker  Offline
I don't know why the factory didn't just put a heavy series needle roller in there, with a bearing plate outside the alternator to control end float. And the bonus is it also prevents shaft deflection and primary misalignment.
This bearing carrier is one piece, rather than using spacers into the alternator.
The dimples are to clear the inspection plate screw lugs on the chain case. The hole is for timing, with a drilled dimple into the alternator rotor.
Re: My A70 [Re: Mark Parker] #726194
02/19/18 11:33 pm
02/19/18 11:33 pm
OZ
Triless Offline
Triless  Offline
OZ
What a simple, yet elegant solution ! It is a wonder why BSA didn't do this. After all, it is a sort of extrapolation of what was done with their B31, 33, etc singles. Using the outer ball bearing drive side main to locate the crank.
That bearing carrier is a neat job, Mark.
Re: My A70 [Re: Mark Parker] #726291
02/20/18 11:48 pm
02/20/18 11:48 pm
UK - Bucks
UK - Bucks
Hi. Is that another bearing you have fitted to the plate behind the clutch as well?
Steve.
SJW
Re: My A70 [Re: Ray Elliott] #726298
02/21/18 2:35 am
02/21/18 2:35 am
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
I made a gearbox outrigger this way:
The nut was an extension shaft into a ball bearing in the primary cover. A three arm lifter in the shaft and triple lift plate in the cover pulled out the pressure plate. Talk about light lever force, I had to add a spring to return the lift plate because the friction in the lifter bearing was adding so much torque the lifter would not return.
The bearing in the sprocket door is less noticeable.
Re: My A70 [Re: Ray Elliott] #726303
02/21/18 6:13 am
02/21/18 6:13 am
Mark Parker Offline
Mark Parker  Offline
The other thing the bearing outside the alternator does is make it much more difficult for the crank to flex in the middle. If you get a plastic ruler and sit it on a couple of blocks with an overhang on one end, when you push it between the blocks the end of the overhang flexes up. If you secure the end of it, its harder to flex the middle.
What a wild looking mod Nick. I got the longest alloy bar lever I could find to get some mechanical advantage on the clutch. I was thinking of extending the lift lever in the case but it's not that bad, even with the heavy 4 spring unit I use.
Re: My A70 [Re: Ray Elliott] #726325
02/21/18 1:21 pm
02/21/18 1:21 pm
UK - Bucks
UK - Bucks
Too many interesting ideas!! I need to put mine back together before I get carried away!
SJW
Re: My A70 [Re: Ray Elliott] #726333
02/21/18 3:35 pm
02/21/18 3:35 pm
gavin eisler Offline
https://www.ccm-britain.co.uk/?xhtm...m.html&category=&xsl=diagram.xsl
item 5 on the diagram, Mark Cook of PES makes a bearing / clutch back plate for B50s, fits A65s too, although the one I got was a slack fit, my motor was not typical.
Re: My A70 [Re: Ray Elliott] #726367
02/21/18 11:50 pm
02/21/18 11:50 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
This is another way that I did it:
The bell housing sits over the clutch basket and the short spud on the outside runs on rollers (same as the clutch hub). A boss was welded into the primary cover and a steel race was pressed into it. Unlike the other one this used the stock lifter.
Re: My A70 [Re: NickL] #726644
02/24/18 10:34 am
02/24/18 10:34 am
OZ
Triless Offline
Triless  Offline
OZ
Nick, this is impressive stuff ! Why do you tell me not to believe all you say ? Is a weird mental anomoly why you were transported to Botany Bay ?
Incidentally, will you be going to the International BSA Rally this year at HallsGap. It is near where I live !
Re: My A70 [Re: NickL] #726696
02/24/18 10:05 pm
02/24/18 10:05 pm
UK - Bucks
UK - Bucks
Nick. Thanx for that - There appears to be an extra step in the crankshaft I wouldn't expect - The A70 uses a thrust washer with a 3/4" ID - are you using something bigger?
SJW
Re: My A70 [Re: Ray Elliott] #726847
02/26/18 11:47 am
02/26/18 11:47 am
UK - Bucks
UK - Bucks
Nick - My locating lugs are trashed as well and I had also aimed to do without the thrust ring - I think its better without anyway. Mine works out about 4.4mm thick. (Whats left of the locating lugs is 3.9m deep on mine) I'm going to change to your design for the step in the crank as it locates the shims properly.
Incidently I have both types of Cam gear pinions and mine are almost Identical width - the ones measured earlier in this thread were about 0.5mm different.
SJW
Re: My A70 [Re: Ray Elliott] #729038
03/18/18 4:33 pm
03/18/18 4:33 pm
UK - Bucks
UK - Bucks
OK - Parts are machined now and crank balanced so its all back in the shed awaiting rebuild. Spent this afternoon fitting Helicoils to all the barrel stud positions.
Crankcase was line bored and Bush was specially made. They also re-cut the anti rotation flats a bit deeper as they had been trashed.
Rebate for the thrust washer is about 50mm x 3mm a bit smaller diameter than the actual A70 version.
I'm quite pleased so far - What does the panel think?
SJW
Re: My A70 [Re: Ray Elliott] #729206
03/19/18 8:37 pm
03/19/18 8:37 pm
Texas, USA
Texas, USA
Looks might fine to me. Turning that crank must have been tedious.
Ray Elliott
Re: My A70 [Re: NickL] #729213
03/19/18 9:15 pm
03/19/18 9:15 pm
UK - Bucks
UK - Bucks
Its just a small step - I left the job to the professionals - they definitely turn not grind. I guess with the right tip tool and a big lathe its no problem
SJW
Re: My A70 [Re: NickL] #729215
03/19/18 9:18 pm
03/19/18 9:18 pm
UK - Bucks
UK - Bucks
All looks tickety boo to me. Bloody copy cat!!!!!! smile
Imitation is the sincerest form of flattery :-)
SJW
Re: My A70 [Re: Ray Elliott] #729625
03/22/18 10:16 pm
03/22/18 10:16 pm
derby england
wak Offline
wak  Offline
derby england
Is there a reason you lot are replacing composite VP3 bearings with lumps of brass, sorry "bronze" ,it seems crazy , would you consider making big ends out of bronze ??? I guess the answer would be no , so why do in to the main bearing?????
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA Gold Star Daytona
BSA Gold Star Scrambler
BSA Rocket Gold Star
BSA C15S
BSA Cyclone
Triumph T120
Triumph T100 Daytona
Triumph 5TA Trials
Triumph T100 Scrambles
Cheney 560 TT
Re: My A70 [Re: Ray Elliott] #729660
03/23/18 9:13 am
03/23/18 9:13 am
England
Servodyne Offline
Servodyne  Offline
England
Hi there.
On a similar subject of bearing material, SRM have informed me that the only difference between the A70 big end shells and ones for the A65 is a higher spec of material.
Could anybody out there please confirm this as pictorially the A70 shells appear slightly wider in the sectional view in the parts catalogue and A65 shells do appear to be too narrow for the A70 rods.
1961 Norton 99
Re: My A70 [Re: NickL] #729968
03/26/18 8:50 am
03/26/18 8:50 am
UK - Bucks
UK - Bucks
I agree with Nick - and its really a heck of a lot cheaper and less complicated in comparison with the roller bearing conversion.
For what its worth I can recommend T&L engineering in Bedford for the work if you are in the UK
SJW
Re: My A70 [Re: NickL] #730002
03/26/18 6:08 pm
03/26/18 6:08 pm
derby england
wak Offline
wak  Offline
derby england
well I'm not sure how the 2 compare , VP3 is listed as"being suitable for racing applications" were 660 is listed as "being suitable for valve and pump bodies and medium load and medium speed bearings". The fact SRM use it says it all , I'm surprised they don't anodize them blue for good measure lol. Anyway I guess if the housing and crank are worn its a way out.
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA C15S
BSA Cyclone
Triumph T120
Triumph 5TA Trials
Cheney 560 TT
Re: My A70 [Re: NickL] #730497
03/31/18 10:54 pm
03/31/18 10:54 pm
UK - Bucks
UK - Bucks
Just an idiot grade question but - the shells are narrower than the conrod big end right? May be obvious to seasoned rebuilders but I'm used to cars where the shell is the same width as the conrod !!
SJW
Re: My A70 [Re: Ray Elliott] #734889
05/11/18 1:51 pm
05/11/18 1:51 pm
UK - Bucks
UK - Bucks
Bikes now back together and running. so the conversion works - at least short term. Time will tell. I should be able to produce a drawing and memo detailing the specifics if anyone's interested. The basic principal is simple but there's some subtleties in the fine tuning.
SJW
Re: My A70 [Re: NickL] #735044
05/12/18 8:57 pm
05/12/18 8:57 pm
UK - Bucks
UK - Bucks
Haven't hooked up a pressure gauge - I'm busy with a charging problem at the moment. I had one about somewhere - will see if I can find it
SJW
Re: My A70 [Re: Ray Elliott] #743238
07/26/18 3:19 pm
07/26/18 3:19 pm
UK - Bucks
UK - Bucks
Still haven't checked the oil pressure but its done about 2000 miles now and is still in one piece:-)
SJW
Re: My A70 [Re: Steve Wilson] #757216
11/26/18 8:33 pm
11/26/18 8:33 pm
England
Servodyne Offline
Servodyne  Offline
England
Hello again.
After finishing my A10 crank conversion for my A70, which turned out rather better than expected, Typically I've now found a modified A70 crank less flywheel. The timing side journal appears to have been machined down to fit the A10 bush (1.375") and the end of the timing side shaft reduced to just under 12mm presumably to fit an end feed oil seal. The trouble is, the timing side left hand thread is now no longer long enough for the lock nut and washer. As I want to return the crank to something like standard the two options I've come up with, involve either welding up the reduced shaft and restoring the left hand thread or drill and tap the end of the crank with a left hand thread to provide a locking bolt. I would then sleeve the timing side journal using a needle roller inner sleeve 1.5" x 1.25" x 1" long as I did with the A10 crank. This would enable the use of a standard bush which I prefer to the needle roller conversion.
Two questions spring to mind;
Does anyone know why the section of the timing side shaft with the left hand thread is 1/4" longer on the A70 compared with an A65 or A10?
Is it possible to modify a late A65 flywheel with the big end cutaways to fit an A70?
1961 Norton 99
Re: My A70 [Re: Ray Elliott] #757310
11/27/18 4:19 pm
11/27/18 4:19 pm
West Yorkshire
West Yorkshire
Some A65's had the same cutaways on the flywheel so I would say yes, providing it fits on the crank, it can be machined.
I'd be interested to see your photos of the A10 crank conversion, Im going to fit an A10 crank to one of the A65 motors (79mm pistons for 830cc) I'd like to see how you worked around being able to fit the alternator, Im also looking at using another Bob Newby Belt drive (which in turn pushes the alternator outboard a little)
Re: My A70 [Re: Ray Elliott] #757404
11/28/18 11:42 am
11/28/18 11:42 am
England
Servodyne Offline
Servodyne  Offline
England
The late A65 flywheel cutaways or 40mm whereas the A70 is guesstimated at around 33mm looking at various pictures I've seen of them. My A10 flywheel was slimmed down to 35mm to get me in the right ball park when I had the crank balanced at SRM. They 'only' drilled two holes in it so it couldn't have been far out.
My latest problem with fitting a late A65 flywheel to an A70 crank is that the A65 ID is around 122mm and the A70 OD is around 131mm. I don't really want to start machining only to make it unusable for both cranks. I would imagine the relief on the flywheel to allow it to slip over the big ends will require deepening as well.
Cutting the annulus groove on the bearing sleeve required a bit of lateral thinking as my local machine shops wouldn't do it. I simply attached two jubilee clamps leaving the desired gap in the correct position and rotated it slowly while attacking it with a high speed disc cutter with two discs fitted in stead of one. I then punched through the wall of the sleeve using a carbide burr.
I'll post some photos of the A10/A70 crank conversion is a new thread
1961 Norton 99
Re: My A70 [Re: Ray Elliott] #757433
11/28/18 5:10 pm
11/28/18 5:10 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
A body grinder in the tool post works well also. I used it to cut a needle bearing inner sleeve to size. Handy for removing the chrome from discs, especially ones with holes in them.
EDM works very well for drilling holes in hardened steel.
Page 1 of 4 1 2 3 4
