Steve in Ohio
Steve in Ohio
Central Ohio
97 registered members (actriumph), 563 guests, and 557 spiders.
John Billerbeck, JMOnTwoWheels, SteveCompton, LanceH, 911speedster
10570 Registered Users
franko 95
NickL 71
809,467 mail-order LSR
Topics67,463
Posts668,965
Members10,570
John should sell these special carb cleaning tools #589829
03/12/15 7:54 am
03/12/15 7:54 am
Springfield Nebraska
Richrd Online content OP
Richrd  Online Content OP
gotta give them credit for trying
http://www.eBay.com/itm/Motorcycle-ATV-Carburetor-Carbon-Deposit-Eliminate-Cleaning-Tool-For-Kawasaki-/351175115762?pt=Motorcycles_Parts_Accessories&fits=Make%3AKawasaki|Model%3AF7&hash=item51c3ab03f2&vxp=mtr
75 commando interstate
06 Suzu..Suzu.. uh appliance
couple of beesas a ducati
and the Snake Bike
and a Honda?
Re: John should sell these special carb cleaning tools [Re: Richrd] #589875
03/12/15 2:25 pm
03/12/15 2:25 pm
John Healy Online content
John Healy  Online Content
We have these. They are on the shelf next to the hand grenades. beerchug
Re: John should sell these special carb cleaning tools [Re: John Healy] #589885
03/12/15 3:31 pm
03/12/15 3:31 pm
Orlando fla/ shady valley Tn
bill50cal Online content
bill50cal  Online Content
looks to me to be an wending/cutting torch tip cleaning set. it is absolutely the LAST thing I would get near a carb jet.
windy
72 combat
switchbackcreek.com
Re: John should sell these special carb cleaning tools [Re: Richrd] #589891
03/12/15 4:32 pm
03/12/15 4:32 pm
Irish Swede Offline
Irish Swede  Offline
That's what they are, welding torch tip cleaners.
I have a set of these I've used for years.
How many suckers have 'bit' on this?
Re: John should sell these special carb cleaning tools [Re: Irish Swede] #589895
03/12/15 4:47 pm
03/12/15 4:47 pm
I don't know, but you'll be able to tell if you ride behind them from the raw gasoline smell from a carburetor running really rich .... !
You should have to pass a drug test to receive a welfare check... because I had to pass one to earn it for you.
Re: John should sell these special carb cleaning tools [Re: Lannis] #589925
03/12/15 8:23 pm
03/12/15 8:23 pm
Running from demons in WNY
Hillbilly bike Online content
Ok.. I have use oxy welding tip cleaners to clear AMAL Contentric pilot jets a few times.. The engine ran fine afterwards with normal carb settings...
You have to be smarter than the tool. You must have a good sense of feel and mechanical sympathy. All your energy is focused on the tool in your fingers, your mind's eye sees the tool enter the jet and you can feel it in your fingers... you also have to be sober...If you measure the smallest probe you find it's exactly .016 on the knurled area. If it ain't try another set. Then take a piece of fine abrasive paper and just a touch of polishing...Then gently push the probe into the carb till you feel it hit the restriction.Usually take a slight wiggle to slip in the orfice and it will slip in like it's found some long lost home. cool .. Then pull it out, you're done. Don't jack the tool in and out like you're slotting a drilled hole with a file.
Some use a pin drill, that's no better in careless hands... You can also use a length of plain rod or if you're JH, you have the special tool made by AMAL. grin
I take off bike parts until it doesn't function, then put on just enough so it functions
Re: John should sell these special carb cleaning tools [Re: Richrd] #589930
03/12/15 8:38 pm
03/12/15 8:38 pm
JubeePrince Offline
Born To Run
JubeePrince  Offline
Born To Run
I think JH has a special tool made by JH. grin
Re: John should sell these special carb cleaning tools [Re: Irish Swede] #589931
03/12/15 8:40 pm
03/12/15 8:40 pm
SW Pa
Ben Strain R.I.P. Offline
SW Pa
I use the unwound portion of used Martin guitar strings to clean a variety of small orifices.
Ben
Re: John should sell these special carb cleaning tools [Re: Ben Strain R.I.P.] #589937
03/12/15 9:46 pm
03/12/15 9:46 pm
wadeschields Offline
Ben
Do Tell !!!!!!!!
Re: John should sell these special carb cleaning tools [Re: Richrd] #589949
03/12/15 11:15 pm
03/12/15 11:15 pm
Santa Barbara, California
KC in S.B. Offline
KC in S.B.  Offline
You might not believe this, and I'm showing my compulsive side I guess, but I "sent the seller a msg", months ago. I said it would ruin carbs to use a welding tip cleaner in the Jets. He replied with a polite response, and said Yes, that would be bad, but that he had these made special, and they are SMOOTH wire. Recently, when I saw them again, I enlarged the photo, and By Gum,....... they DO look smooth. I still think sticking things in a jet is a bad Idea, but I have to admit, he isn't selling different size files. FWIW..............
Oops,.. add 1 '65 XLCH
Re: John should sell these special carb cleaning tools [Re: Richrd] #589952
03/13/15 3:15 am
03/13/15 3:15 am
Royal Berkshire.
Kev. Offline
Kev.  Offline
Royal Berkshire.
At my local shop, if the ultrasonic bath won't clean a venturi, then as a last resort, out come the very fine and delicate root canal files...
1952 Norton Special
1970 BSA A65 Lightning
1973 Moto Guzzi Eldorado
1981 Harley FLH
2006 BMW R1200GS
Re: John should sell these special carb cleaning tools [Re: Richrd] #589982
03/13/15 8:20 am
03/13/15 8:20 am
Jordan, NY
Al Eckstadt Offline
Al Eckstadt  Offline
Jordan, NY
Regarding KC's message response about the smooth finish: I have in my work tool box a set of Honda Power Equipment special tool (read expensive) jet cleaners. They are smooth - not torch tip cleaners - they have a sort of finish like they were bead blasted. They work well on all the small engines we have here at the rental store. Still - as Hillbilly suggested - even the right tool in the wrong hands can cause damage. These little Honda power equipment engines run so lean that if you reamed the jet a little you would only make the engine run better.
That being said - I think most of the hundreds of these being sold on eBay are actually torch tip cleaners. At least many of them are. If you "mouse over" the image sometimes you can see the ridges.
Al Eckstadt
Re: John should sell these special carb cleaning tools [Re: JubeePrince] #590127
03/14/15 2:23 am
03/14/15 2:23 am
Only marginally dumber than using a drill bit to clean a pilot jet, eh? Or designing a carb whose pilot jet cannot be cleaned otherwise.
I do have a set of these welding-tip cleaners. I miced the entire set to get exact sizes. I would never use them on a fuel jet, but I have used them to enlarge Mikuni air-correction jets.
Re: John should sell these special carb cleaning tools [Re: Richrd] #590130
03/14/15 3:03 am
03/14/15 3:03 am
Midwest, United States
kyrbz Offline
kyrbz  Offline
I never use them on my carbs, but I do use them occasionally cleaning my spray guns, welder, and other misc. things. You can get USA made sets from Harry J. Epstein (A really great tool store in Kansas City, MO) for $2.25
Harry J. Epstein
BZ
58' Panther M75
http://bzisettas.blogspot.com/
