Servodyne
Servodyne
England
Page 2 of 5 1 2 3 4 5
Re: New 5 speed cluster for BSA A65
JER.Hill #585949 02/16/15 2:29 pm
Hi
Just to let you see the actual cluster here is a photo taken a few days back. http://s1314.photobucket.com/user/ecosse_lynx/media/5speedcluster_zps47bfd416.jpg.html
regards
JER.Hill #585963 02/16/15 3:59 pm
If you have several bikes that shift "one down, three up," for safety reasons it would be good to have the option of the reversed cam plate for the rear-set shift lever, so down-shifting in an emergency can be done without having to think about it.
I have seen pictures of the aftermarket linkage to do this, and all look crude and "tacky."
For what this five-speed gear conversion will cost, It can't be that complicated to engineer a reversed shifter camplate for it. A conventional one has to be made, anyway.
JER.Hill #585982 02/16/15 6:01 pm
Of all the upgrades and newer things a person could buy for their BSA these days, I have to say that to me, this is the most exciting thing I have seen.
While I would have to do some serious saving for one, I am definitely going to put it on my list of parts, etc., that I want or need to buy.
Thank you very much for the effort John !
Originally Posted by JER.Hill
Hi
regards
1971 BSA A65 650 - Project
JER.Hill #586000 02/16/15 7:35 pm
Hi
Thank you for your comments Jon, much appreciated.
Irish. What about going from right to left change as well! There are a number of well made linkages on the market, or you can simple build your own to change it to one up.
I'm trying to keep the costs down, building in a reverse pattern change is not just as simple as you might think and certainly for the time being one down four up is the way it shall be sold.
regards
JER.Hill #586112 02/17/15 4:35 pm
agree with Jon W.H.
and it is on the list and had a refund from his Majesty tax department (nice chap)
however I can't fit my Newby dry belt clutch.
is there a possibility to adapt the clutch or the shaft?.
regards Anne
JER.Hill #648829 04/16/16 4:53 am
https://www.youtube.com/watch?v=K98jg7IoWJ8&feature=autoshare
What it's like. Not the best video. Although its just short shifting into 3rd 4th and 5th, if you keep power on through all the gears the excellent ratios put you right on the power and rocket you forward. 4th to 5th is closer than the old 3rd to 4th, I wondered about that, but its perfect, if 4th is not low enough just below it is 3rd.
The beautifully made cluster:
Assembled into the bearing carrier:
Really adding performance.
Mark Parker #648830 04/16/16 5:13 am
Hells bells
there is not much mest between those slots.
Considering the problems with the early A 65 boxes requiring strengthening to prevent the slots separating I hope they got their metallurgy spot on.
JER.Hill #648831 04/16/16 5:25 am
CCM Britain know their stuff ref heat treatment and materials so I would not be concerned at all.
JER.Hill #648832 04/16/16 5:27 am
Trevor the selector plate is stepped and quite thick where the tracks are, which may be the way strength was added.
JER.Hill #648892 04/16/16 2:41 pm
Hi
In answer to Anne's question. Sorry I missed your post. I'm fairly sure that an adaptor could be made to suite the Newby clutch, it would be a matter of talking to Newby, as this would possibly require new clutch centre, although I'm not to failure with the Newby clutch.
To answer trevor's question. There are a number of differences between the original selector plate and the 5 speed one.
a) thickness
b) heat treated
c) the dogs are back cut, therefore the gears keep themselves engaged, unlike the original which relied on the selectors and selector plate to keep the gears engaged.
hope this is of help
JER.Hill #648903 04/16/16 7:27 pm
In other words, this is a fully syncromesh gearbox?
JER.Hill #648928 04/17/16 12:07 am
No, it's constant mesh, the gears are always in mesh and slide to engage dogs to connect or disconnect them, determining which gears drive the output. On this cluster those engagement dogs are robust and dovetailed so when they are engaged they tend to hold themselves engaged.
JER.Hill #649020 04/17/16 3:56 pm
Hi John,
not to press you but when are you taking new orders for the 5-speed gearbox?.
regards Anne
JER.Hill #649063 04/18/16 6:19 am
Hi Anne
I'll take names of those interested now. The earlier I have enough names to run a batch the earlier I can get a production slot with PES, who are always very busy. Its would probably be towards the end of the year before they would be ready, but I'd have a better Idea once I have some interest and can make a commitment.
I can send anyone wanting more information on the cluster if they email me on [email protected]
regards
JER.Hill #649065 04/18/16 6:58 am
okay, one for me.
gearbox can be exchanged with the engine in frame, smile
I'll send you a set of newby clutch pictures as soon as possible
regards Anne
JER.Hill #649070 04/18/16 8:03 am
Hi Anne
Your name goes to the top of the list. Yes you can swap the clusters out with the engine in the frame. Look forward to seeing how the clutch centre works on the Newby clutch.
I know the Hayward clutch system uses the standard BSA centre, so that would just be a straight swap.
regards
JER.Hill #649202 04/19/16 8:56 am
So I presume you are going to try it out on the way to the ABR this year ?
We are riding down from Walla Walla Friday morning if you are interested.
JER.Hill #649205 04/19/16 9:21 am
My brother Paul sometimes goes on his A65. It would be fun to go some time.
Mark Parker #649377 04/20/16 8:15 am
40th anniversary this year and a Rick Strange memorial.
Could not think of a better reason to go.
So the A65 I have been seeing there in the same frame you are using is not you ?
Did you do this a coupe of times or are there other great minds out there ?
JER.Hill #649526 04/21/16 3:00 am
Hi
There is now two names on the list of those who have shown an interest in me making another batch of 5 speed gear clusters. You can either post your interest on here or email me on [email protected]
Shall update the numbers on here to keep everyone informed.
JER.Hill #649699 04/22/16 4:53 am
Hello all, I was reading Classic Racer issue 179 and came across this company:
http://novaracing.com/index.html
They are advertising an A65 gearbox and show an image of it in their advert, it`s a cassette type box and had me interested enough to give them a ring.
Turns out it`s a 5 speed unit that uses a selector drum instead of the old style selector cam plate design with it`s inherent weaknesses.
Apparently they have some prototypes out there being tested, interesting stuff they do if you take some time looking through their website. wink
Get out and ride it
JER.Hill #649705 04/22/16 6:45 am
Hi Skorpion
Yes, I'm aware of the Nova gear cluster. Would you care to enlighten us on the original cam plate design's "Inherent weaknesses". Perhaps some of these have been addressed in my cluster!
regards
JER.Hill #649847 04/23/16 4:14 am
I have the std primary with 21 front and 36 rear sprockets for final drive. So the gearing is very tall. The thing probably sounds a lot slower than it actually is. I think this illustrates just how nice these ratios are. Definitely made my BSA much more effective.
https://www.youtube.com/watch?v=Dz2YhbLMVdc&feature=youtu.be
JER.Hill #649887 04/23/16 1:07 pm
Simply put it was ALWAYS weak because of the design, there wasn`t much meat on it in places and hardening `may` mean it`ll be embrittled too and more prone to stress fractures.
I had both a Lightning and a MkIV Spitfire, 66 model with twin GP carbs. The Spitfire broke it`s cam plate but I was pretty hard on it back then to be honest, it didn`t get an easy life. wink
Get out and ride it
JER.Hill #649890 04/23/16 1:46 pm
I could not find any reference to a five speed cluster for the A65 on the Nova site. I would be really interested in how they fit a drum in place of the camplate. Even if the drum were offset from the fork guide rod it could only be about 1/2" diameter which would make for extremely steep and narrow tracks. Then the selection mechanism would have to completely change.
The stock camplate was too soft which wore the points of the tracks and they had to add the stiffener plate on the backside to keep the tracks from spreading. They could have fixed that by making the camplate thicker and making the tracks blind if they had the tooling.
