Mike Slater
Mike Slater
NORTH MANCHESTER
Andrew C., muzza123, Siwy, Troy Walls, vmxmike
11011 Registered Users
franko 134
koan58 69
1,148,269 mail-order LSR
Topics68,913
Posts690,728
Members11,011
59 registered members (68triton), 923 guests, and 921 spiders.
Page 2 of 2 1 2
Re: Rim lock or no rim lock? [Re: bonneville15] #552621 07/13/14 4:57 am
they can complicate wheel balancing, which is more critical on the front wheel
Why is wheel balancing more critical on the front wheel?
Re: Rim lock or no rim lock? [Re: bonneville15] #552650 07/13/14 9:50 am
bonneville15 Offline OP
To be honest, I wan't my front tyre to be perfectly balanced. Probably that's why they don't use rim locks in the front.
William
ASE Automotive Master Tech.
Never regret anything in your life because at one point, that was what you wished for.
Always tell the truth, even if your voice shakes.
1977 T140V
Re: Rim lock or no rim lock? [Re: Ger B] #552668 07/13/14 11:24 am
DavidP Online Content
For the same reason a front-tire blowout is more dangerous than a rear-tire blowout.
Re: Rim lock or no rim lock? [Re: bonneville15] #552691 07/13/14 1:14 pm
John Healy Online Content
Having experienced both that's a close call.
Re: Rim lock or no rim lock? [Re: bonneville15] #552696 07/13/14 2:00 pm
norton bob Offline
I have had 4 punctures while riding, all in the rear wheel, all deflated fully before i managed to stop, all were frightening but i stayed on. The bikes were fitted with rim locks.
Re: Rim lock or no rim lock? [Re: bonneville15] #552710 07/13/14 3:40 pm
enigmaT120 Offline
I've used nothing but tubeless tires on my Triumph for a really long time. I've had several flats on the rear with no rim lock, and it didn't even break the bead. I was able to ride on it, those tires are so stiff even without air. I think if I were running the original tube type tires that would be a different story.
Ed
1970 Bonneville
Re: Rim lock or no rim lock? [Re: bonneville15] #552721 07/13/14 4:34 pm
A blow out is a blow out, David, whether the wheel is balanced or not.
The effect of a blow out, front or rear, has nothing to do with the wheel being balanced or not.
So you did not answer my question: Why is wheel balancing more critical on the front wheel?
The only reason might be: There is more mass in the rear suspension than in the front susspension.
So the effects in te rear will be less transmitted to the bike / rider than in the front;
where in the front the effects will be transmitted directly to the steering bar / hands of the rider...
No arguments for or against the use of rim locks,
since balancing is not more or less complicated with or without.
The only difference is you need a bit more weight on the oposite side of the rim lock.
Re: Rim lock or no rim lock? [Re: Ger B] #552723 07/13/14 4:46 pm
kevin roberts Offline
back in the middle ages, i took off the steel rim from the rear of my T120 and replaced it with a shouldered borrani. on the advice of the clymer bonneville manual, i dumped the rim lock and just drilled the borrani for four sheet metal screws on each side.
been okay for a long time, but i can't recall whether i've ever had a flat with it or not. i always run new tubes whenever i change tires, and so far perhaps i've been luckier than some.
Re: Rim lock or no rim lock? [Re: bonneville15] #552724 07/13/14 4:53 pm
Enigma:
I kind of baffled. Can you use tubeless tires on a spoke rim??? How do you do it? Do you have lester wheels?? I have been trying to get some lesters but no luck.
William
1977 T140V
Re: Rim lock or no rim lock? [Re: bonneville15] #552729 07/13/14 5:15 pm
desco Online Happy
Not real complicated. You put a tube in them. Don't forget a new rim strap.
Re: Rim lock or no rim lock? [Re: bonneville15] #552768 07/13/14 9:00 pm
bsatrinor Offline
at 69 i still change my own tires,,,dont use rim locks any more,,,they only throw your tire out of balance,,,dont need them ----if you dont do wheelies and slip the tire on the rim,,,,,if you are using K70 tires,,,they are soft as mush when they deflate on you,,,cant ride them home,,,-----switch to a good firm tire like harly uses,,,,the wont squish and throw you------even K81 are a lot stiffer than K70
Page 2 of 2 1 2
