iansoady
iansoady
Birmingham UK
BradM, Andrew C., muzza123, Siwy, Troy Walls
11012 Registered Users
franko 134
koan58 69
DavidP 51
1,148,295 mail-order LSR
Topics68,913
Posts690,732
Members11,012
29 registered members (Alan_nc), 1,247 guests, and 963 spiders.
A65 rear swing arm #506404 09/15/13 12:06 pm
oleandreas Offline OP
Hello
Anyone know when BSA A65 with pre oil in frame bikes, changed from swing arm with rubber bushings to swingarm with bronze bushings ?
I have a 1968 bike (more or less) and the rubber bushings in the swingarm dont keep up with the bigger engine, need to improve stability at the swing arm, the nut on the swingarmaxle loosen easily and the bike starts to wobble ..... any other reccomendations ? wants to keep the bike with original look. else I could change to something more modern. anyone tried to turn bronze bushings for the old swingarm ( the one without lubrication nipple, i.e. the one with rubber bushings)
Re: A65 rear swing arm [Re: oleandreas] #506434 09/15/13 2:05 pm
kelvin Offline
these should be silentbloc bushes
Re: A65 rear swing arm [Re: oleandreas] #506461 09/15/13 4:22 pm
Allan Gill Online Happy
Ole, the 1970's definitely had a bearing type setup (whether it be bronze I don't know)
I'm sure something could be done with the standard swing arm. It would certainly last much longer. You may need a new shaft too, one which would work better as a bearing surface. Depending on how much space you have, you could possibly use a thin bush with a bearing sleeve, and the swing arm shaft going through that - That would be a better solution if there is space for it.
Re: A65 rear swing arm [Re: oleandreas] #506509 09/16/13 1:07 am
Pete R - R.I.P. Offline
Burn out the rubber,and leave all the steel parts intact.You won't need the inner sleeves from the silentblocs,but leave the outer sleeves in the swingarm.
Make shouldered bronze bushes to replace the rubber.You need a spacer tube between the bushes,and that spacer will compress slightly (elastically) when you tighten the swingarm bolt.Start with generous end float (about 0.040").Tighten the bolt against the bushes (use some spacers for checking),and see how much end-float you have when it's tight.
You can then trim some off the spacer tube or bushes to reduce side-float,without binding the shoulders of the bushes against the swingarm when everything is tight.
Lastly,face off the outside of the bushes so it all just fits into the frame.
It would be a good idea to fit a grease nipple,probably in the centre underneath the swingarm.
Re: A65 rear swing arm [Re: Pete R - R.I.P.] #506546 09/16/13 9:54 am
Hello guys thanks for answers.
Pete R: where is there place for shoulders ?
maybe a drawing if possible ?
I have removed the swing arm, burned out the silentblock rubber and removed the inner sleeve and rubber of the silentblock bushings, the outer sleeve is still located in the swing arm as you described... was your suggestion to make (turn) bronze bushings that fit between the outer sleeve and the swingarmrod ? crimped on the rod or ?
If you have a drawing, you can post to facebook or email if its easier for you.
[email protected]
ole andreas
Re: A65 rear swing arm [Re: oleandreas] #506578 09/16/13 12:15 pm
Arnstein Offline
Ole Andreas.. The bronze bushes must have a press fit in the swingarm and the tube which the bush shall turn on ought to be hardened and have a accurat fit between the frame plates.There should also be some kind of dust seals as on the original bushed type. The big dia.original type of bush is a thin steel split type with bronze inside.
Arnstein
Arnstein
BSA Spitfire MK3.800cc (also engine 850cc 90degree)
Honda CB450T -71
Laverda RGS 1130cc -85
Ducati 1098 -08
Re: A65 rear swing arm [Re: oleandreas] #506591 09/16/13 12:45 pm
Dave - NV Offline
The conversion from 'silentbloc' to bushing swing arms done by our friend Peter Huber in Germany work nicely on our Goldies.
He pulls out the complete silentbloc and then press in undersize bore bronze bushings on either end of the tube.
He makes 2 steel inserts that will run in the bushings and a spacer that fits in the center. The total length of these pieces allows them to be secured tightly between the frame lugs when the swing arm axle is tightened.
Now here is an important step ... As the swingarm cross tube is always warped during mfg welding, he now reams the undersized bushings to fit the steel inserts. There is a grease zerk in the bottom center of the cross tube.
Dave - NV
Re: A65 rear swing arm [Re: oleandreas] #506602 09/16/13 1:38 pm
kommando Online Content
I put needle rollers in my B44 instead of Silentblocs and lost that wobble you get going over whitelines, bushes would do the same.
Re: A65 rear swing arm [Re: oleandreas] #506605 09/16/13 1:53 pm
pushrod tom Offline
Pretty sure it was the 1969 models that went to 'real' bushings. If you can find a complete assembly from 69 or 70 it will pop right in. You can also get replacement parts for a rebuild. PRT
Re: A65 rear swing arm [Re: oleandreas] #506625 09/16/13 4:27 pm
The needle roller sounds like a good idea Kommando, I for one would like to know more on that.
Re: A65 rear swing arm [Re: Allan Gill] #506635 09/16/13 6:06 pm
is the swing arm changed too, or can I use earlier swingarm with the newer internal from 69 - 70 ?
Re: A65 rear swing arm [Re: oleandreas] #506680 09/16/13 8:26 pm
pushrod tom Offline
Don't remember. Check part # ?
Re: A65 rear swing arm [Re: oleandreas] #506714 09/17/13 3:45 am
Needle roller conversion is covered in this thread,
http://www.britbike.com/forums/ubbt...ictor+special&Search=true#Post213356
Sizes may differ for an A65 but for the B44 the sizes matched closely what Torrington had.
Re: A65 rear swing arm [Re: oleandreas] #506734 09/17/13 7:39 am
been a while since I had my B40 and B25 SwingArms but IF i remember correctly they use the same silent block bush
Re: A65 rear swing arm [Re: oleandreas] #506768 09/17/13 12:35 pm
Gary E Offline
B44 and A65 each have different part numbers.
