furymalc
furymalc
northern B.C.Canada
DaveG., stretch7, S Trotter, Psychopasta, Dave Shotz
10787 Registered Users
franko 136
NickL 72
DavidP 63
952,311 mail-order LSR
Topics67,561
Posts676,202
Members10,787
75 registered members (1958superrocket), 419 guests, and 767 spiders.
Amal MK1 Premier #500522 08/05/13 1:23 am
coloradobob Offline OP
I have a new AMAL Premier 932. It has a unknown size removable pilot jet that requires the air screw to be 3 turns out. I want a leaner jet. What sizes are recommended? I assume the jet needs to be screwed all the way in, not like it came from Burlen. Bob
Re: Amal MK1 Premier [Re: coloradobob] #500532 08/05/13 7:06 am
DoubleDiamond Offline
You are best to speak with Burlen (or email them) directly.
They do a variety of screw in pilot jets, although I have only ever used the standard (which worked just fine) and the leaner one, which turned out to be too lean.
3 turns out does sound very wrong. Are you sure the existing jet is seating correctly?
Triumph: '87 T140; '72 T150v
Re: Amal MK1 Premier [Re: DoubleDiamond] #500540 08/05/13 11:49 am
what happens when you adjust the pilot screw either way?
3 full turns is a lot, and most of my bikes run best with the screw closer to the 1 1/4 turn out mark. It sounds to me that either the choke is on?? or the slides are not seating properly to the carb floor.
Im really curious how you arrive at the 3 turns out? is this what the colour tune is telling you it is best at?
what year is the bike? is it a 67 or 68? did you order a carb for a 67 or 68? did you specify anything other than a #20 pilot jet?
Re: Amal MK1 Premier [Re: DoubleDiamond] #500552 08/05/13 3:34 pm
I will order a 622/502-15 pilot jet. The box that the AMAL Premier came in lists the pilot as "BUSH". My usual guitar string fit the pilot Burlen sent. The removable pilot jet was 1/2 turn out when delivered. I have tightened it snug. My 73 TR7 had open Bud Ekins style pipes until I recently installed short mufflers. We'll see how the smaller pilot jet works. There's not much tuning info on these. None of my other Amals is much outside 1 1/4 turns out. Bob
Re: Amal MK1 Premier [Re: coloradobob] #500555 08/05/13 4:19 pm
This is interesting, typically a bush pilot jet is equal to #20
http://amalcarb.co.uk/mk-i-Concentric-series/900-series/jets/premier-pilot-jet.html
according to this there is 19 or 21, wonder what they used??
one thing I do know is 15 will be wayyy too small. I tried going from 20 to 25 on a jet once, trying to get the pilot screw closer to the magic 1/5 turns out. It was just way to rich. My personal suguestion would be no lower than #17, and if it is 2 turns out (IF) then leave it at that.
I think the straighter pipe with limited baffel would require a leaner mixture, I think the tuning guide suguests to start with a number 4 slide.
If you don't have this article, you can download it from here
http://www.britbike.com/forums/ubbthreads.php?ubb=showflat&Number=42112#Post42112
read a couple of pages of the thread first though, as one portion of the guide is incorrect.
Re: Amal MK1 Premier [Re: Allan Gill] #500560 08/05/13 4:57 pm
RF Whatley Offline
And here I was thinking that a bush pilot was one of those guys with a 50 year old de Havilland float plane that took you hunting or fishing in the wilds of Alaska!
Silly me. laughing
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: Amal MK1 Premier [Re: RF Whatley] #500565 08/05/13 5:27 pm
I got the following reply from Burlen:
Dear Mr Bowser,
The brass headed screw in the position opposite to the Pilot Air Screw is the new design of pilot jet which replaces the pilot bush. It is identifiable by the crossed slots in the head. The attached photo shows it in position. The jet is is intended to be screwed firmly into the carburetter. The method of adjusting the idle is unchanged from the standard Mark 1. (The Standard (non–Premier) carburetters now have a plated threaded plug with a single slot screwed into the same position to improve access to the bush for cleaning.)
The ID of the standard jet is 0.017” This is the same as the nominal ID of the former pilot bush which was rated at approximately 23cc. The new jets are also available in 15, 19, 21 and 23 sizes which again are measured in thousandths of an inch. The graduations between the jets are smaller than the 124/026 range of pilot jets, one jet size being equivalent to approximately ¾ of a turn on the Pilot Air Screw. The most popular alternative size so far is the 19. Identification is by rings engraved around the nose of the jet, as listed below.
Premier ID Grooves
1
622/502-15
2
622/502-17
3
622/502-19
4
622/502-21
5
622/502-23
Kind regards,
Phil Beresford
Technical Sales Co-ordinator
Burlen Fuel Systems Limited - The SU and AMAL Carburetter Companies
Spitfire House, Castle Road, Salisbury, Wiltshire. SP1 3SA
Tel: +44 (0)1722 412500 Fax: +44 (0)1722 334221 Email: [email protected] Website: http://www.burlen.co.uk
Re: Amal MK1 Premier [Re: coloradobob] #500572 08/05/13 8:36 pm
British Cycle Supply had the 622/502-15 removable pilot jet in stock for $20.99. It has the single line around the nose. There's no marking on the one that came with the Premier carb. They started with only one size; maybe that's the reason. I'll wait to see how the pilot jet works before going to a #4 slide, which is easy to get. New and Improved can mean not in the supply chain yet. The numbering system was unfamiliar to several major suppliers, but all were helpful. Small throttle opening performance is critical on this bike. I intend to ride a lot of forest service roads. It's got a big rear sprocket and I want stump puller low end torque. Bob
Re: Amal MK1 Premier [Re: RF Whatley] #500574 08/05/13 9:01 pm
Silly me. laughing
laughing You got me RF' grin
Phil at AMAL is a really good guy, helped me out a lot over different issues and getting my retailer account.
I would have thought the jet flowed as much as the original #20 screw in pilot jet, as opposed to 23cc, I also guess that the 17 in the number is the same as 017", which is why we use a 016" guitar string for cleaning.
The removable pilot jet that Brit Cycle are selling for $20.99 if that is each, and you don't mind waiting a couple days longer to receive it, drop me a PM and we can discuss it.
Re: Amal MK1 Premier [Re: coloradobob] #500594 08/06/13 12:52 am
The 15 thou pilot jet is on the way, but I;m always interested in a good source. This bike is built for dirt roads and trails in the Colorado Rocky Mountains betwen 6000ft (my House) and 12,000 ft. It must pull smoothly at small throttle openings and not soot the plugs on 5000ft descents. Bob
Re: Amal MK1 Premier [Re: coloradobob] #500623 08/06/13 8:39 am
Just let me know if you need anything, the only killer might be the shipping.
Your height above sea level will explain the need for leaner jets, AFAIK carbs are normally jetted between sea level and 3000 ft. Some of the Aircraft guys here will be far more aware of jetting at altitude than I will ever be.
