zambu
zambu
Switzerland
AMAL MK2 odd setting
#494398 06/17/13 2:28 pm
Pacha Offline OP
I have finally put my T140E back on the road. New suspension, brakes, and engine.
But the bike has a rough idle and miss when I open the throttle fast (not that fast) at about 1/8 throttle.
The spark plugs are new, the electronic ignition is set as the manual indicates and using fresh gas.
The bike has stock everything but the mufflers (Dunstalls replicas).
I have disassembled the carbs to have them cleaned and noticed that I donĀ“t have a factory setting.
Needle is 2c3 set in the middle groove
Needle jet is .105"
Slide is #3 (with some play)
Main jet is 200
Pilot jet and choke are both 35
I know I have a USA EPA carb setting but with different pilot an choke jets. Could that be the cause for the engine bad idle and miss?
Any ideas?
Bonneville 1979 T140E
Re: AMAL MK2 odd setting
Pacha #494414 06/17/13 4:49 pm
The pilot jet is too large, the enrichener jet is fine. Install the stock #25 pilot jet or maybe a leaner #20. There is a Euro jetting spec that I don't know off hand. The pilot/idle jet is # 15 but with the Dunstalls, I suggest the #20 with the Euro specs. It has been talked about many times so you should be able to search and find the specs. Use #5 heat range Champion spark plugs too.
Tom
tomterrific #495048 06/22/13 5:56 pm
Pacha Offline OP
I can find #20 jets locally I will try them. since I will buy new slides, does any one have a recomendee jeting for a stock T140E with donstall replicas?
