BSA Boy
BSA Boy
Boulder, CO
Phil Andersen, Bud O, knobby, coomo, Chris mannifield
11025 Registered Users
franko 140
DavidP 78
Rohan 59
koan58 59
1,157,537 mail-order LSR
Topics69,027
Posts691,618
Members11,025
65 registered members (Beach), 1,206 guests, and 972 spiders.
GM Module Ignition. #483455 03/28/13 9:11 pm
tomterrific Offline OP
I'm curious if anyone has used the ubiqutious GM module wired to the points to get a transistor controlled ignition? It seems like a simple resistor should do it, then the positive ground points would trigger the module(s) to fire the coil. The module(s) would need to be isolated from the frame. The benefit would be using a lower resistance coil for a powerful spark and less points wear.
Tom
Re: GM Module Ignition. [Re: tomterrific] #483521 03/29/13 6:56 am
Stuart Offline
Hi Tom,
"Lower resistance" means increased current draw. Given that any standard Lucas coil is more than powerful enough at least up to 9.5:1 compression (not tried 'em with higher), where's the "benefit" there? confused
I can see that "less points wear" would be a benefit but, given how many times the 'quality' of today's points has been discussed one here, ...?
Re: GM Module Ignition. [Re: tomterrific] #483532 03/29/13 9:56 am
The best result you could possibly get is the bike running as well as it does without a GM module.
Re: GM Module Ignition. [Re: triton thrasher] #483534 03/29/13 10:16 am
Hillbilly bike Offline
Less wear on the points contacts since they only trigger the current switching module.
There's wire diagram floating around on the internet for use on a Japanese bike....
In the early 70's it was popular to replace the coils on bikes with larger car coils.The "improvement" was outlined in an article in Cycle magazine. I did it on my 650 Triumph,my friend on his 850 Norton.We convinced ourselves it was an improvement grin
Re: GM Module Ignition. [Re: tomterrific] #483538 03/29/13 10:37 am
AngloBike Offline
If you're going that far why not just go EI?
What you're talking about sounds like the electronic boost that is used on distributor based bikes where the points switch a booster box and the coils.
