BritBike SponsorBritBike SponsorBritBike SponsorBritBike SponsorBritBike Sponsor SteadfastCyclesBritBike SponsorBritBike SponsorBritBike SponsorBritBike SponsorHepolite Pistons
Velo-Felo
Velo-Felo
Forest of Dean, Gloucestershire UK
a65 counter shaft sprocket
#481031 03/12/13 8:59 pm
maxx77 Offline OP
Is there any one manufacturing/machining a 520 counter shaft sprocket for the unit 71-72 A65's ??.I am not sure of the difference's in the unit A65 transmission's, hence the 71-72.. Thank you in advance for any information.
Re: a65 counter shaft sprocket
maxx77 #481063 03/13/13 1:54 am
As far as I know, the sprockets are the same for all unit A65s, but I don't know of anyone making a 520 sprocket.
maxx77 #481072 03/13/13 2:35 am
A new friend of mine has built an INCREDIBLE unit 650 Triumph Rickman. He asked me if I had any 520 chain parts, which I thought odd, and assumed he was thinking of 530. Nope, he has 520 chain and sprocket on the bike. So, I am thinking since Rickman frames take all kinds of motors, maybe they have a line on a 520 sprocket for an A65.
BTW, why are you doing that again......... ??
KC in S.B. #481148 03/13/13 6:42 pm
maxx77 Offline OP
thanks for the response. I intend on running dirt track wheels and tires on this bike. a proper street tracker w/ 19in wheels at both ends; quick change hubs etc..and from past experience with Triumphs (T120s) Trackmaster & Redline frames, clearance issues with 530 chains was a problem. so we made our own 520 counter shaft sprockets...I was hoping that some one was building 520 counter shaft sprockets for vintage triumph/BSA road race/dirt track bikes. Its a lot of work to make these sprockets; (labor intensive ) to get them right. I didn't think about calling dirt track/ road race frame builders to ask. I will do that today.
thank you for the response.
maxx77 #481149 03/13/13 6:50 pm
Unit single are 520 and fit the A65 but may not go big enough as largest is 19 teeth.
kommando #481155 03/13/13 7:23 pm
maxx77 Offline OP
(kommando) good information; not what I wanted to hear, but good info to be stored away. Information/technical facts like this, is/are what keeps me/us moving in the right direction. Thank you vary much.
maxx77 #481186 03/13/13 11:34 pm
There is hope. I've read here that a few people have converted to 520 in order to use O-ring chain. Somebody knows where to get sprockets.
I know how little clearance there is, even on a stock A65. I've seem some alloy dust on the master link of my Tsubaki QR. Not even O-ring, and it barely clears.
KC in S.B. #481187 03/13/13 11:35 pm
maxx77 Offline OP
Sent Rickman an email, and called several frame builders; it s coming down to this. I am going to end up building the 520 sprockets....again.. I cant believe that someone isn't making a 520 sprocket for these motors. Maybe I can offset some of my cost building this bike by building a basket full of 520 sprockets.
thanks again for the info..
maxx77 #481212 03/14/13 2:51 am
I didn't look, but have you posted on the Competition board here? maybe someone there might have a lead?
maxx77 #481213 03/14/13 2:56 am
The market probably is not big enough. Unless large quantities are made it is cheaper to modify stock engine sprockets because the broaching and heat treat will cost.
Turning the rear sprockets down is easy or you can get some Sprocket Specialties blanks and machine the centre/drill the bolt holes. The easiest way to narrow the engine sprocket is to put a body grinder in the lathe tool post.
I would safety wire the knock-offs. They can come loose.
DP- you should use a riveting master for more clearance.
DMadigan #481235 03/14/13 5:26 am
A what? Do you mean a master link which is riveted as opposed to clipped? I guess that works if I can find one and manage to punch the rivets while on the bike. What do I do to clean the chain?
I'd just as soon relieve the cover where it rubs the chain, 0.01 should be sufficient. Probably already done by the chain. Not as if it's a stressed part. I'm not even sure why they put that flange on the case in the first place.
maxx77 #481236 03/14/13 7:04 am
The tool used to separate the riveted master also stakes the pin and can be done in situ. I clean my chain with WD-40 then spray on Chain Wax. No need to remove the chain until it is worn out.
The case flange over the chain? That is to keep the oil that is flung off from getting on the rest of the motor. The bikes originally came with a drip oiler.
maxx77 #481249 03/14/13 11:47 am
I use 520Xring chain, I just grind the inner side down till it fits. That way it offsets it out a little, I use a rivet link for better clearence. If it skims the back of the chaincase sometimes it doesn't do much. (It doesn't run on it)
maxx77 #481343 03/15/13 3:16 am
Ya gotta LOVE this site !!
DMadigan #481556 03/16/13 6:02 am
Yeah, I plugged that up.
Of course, the crankcase breather still does the job of flinging oil on the engine. laughing
I have seen no more alloy dust on the master link, so I guess it's made its own clearance.
DavidP #481624 03/16/13 7:57 pm
maxx77 Offline OP
I love it; I have a poster on the shop wall that says (One eye on the door,
One eye on the writing on the wall).
yeah....
maxx77 #481903 03/18/13 7:18 pm
yeah....
I stole that line from an Ian Hunter song, "Rain."
