The Bonneville Shop
triton thrasher
triton thrasher
30 registered members (Al Eckstadt), 269 guests, and 412 spiders.
SuzyTice, Steve Funke, JD8, John Rowley, Zoot
10531 Registered Users
franko 96
Lannis 81
NickL 66
789,359 mail-order LSR
Topics69,252
Posts674,577
Members10,531
The Motorcycle Tool Thread! #475850
02/05/13 9:09 pm
02/05/13 9:09 pm
Lyons, NY
Britishtools Offline OP
Lyons, NY
FREE SHIPPING BY USPS Priority Mail to all US addresses. Reasonble flat rates to ROW.
Call us at 1-315-946-9400 or email sales@britishfasteners.com and mention Britbike.com and we'll pick up the shipping on any item in this thread.
Triumph cam gear puller
$53.00 OEM p/n 60-2213
Triumph/Norton Pinion puller
$55.00 Uses OEM Part Number 06-7524
BSA Triumph clutch hub extractor - triples
$24.95 T150, T160, A75, ROCKET 3 CLUTCH HUB EXTRACTOR TRIPLES
USES OEM P/N'S 60-1860 & D1860
BSA Triumph primary chain adjuster
$17.95 OEM P/N's 60-2108 & 61-7012
Re: The Motorcycle Tool Thread! [Re: Britishtools] #475852
02/05/13 9:20 pm
02/05/13 9:20 pm
Lyons, NY
Lyons, NY
BSA clutch hub extractor - 6 spring
$25.95 - USES OEM P/N's 61-1912 & 61-3362
BSA Triumph clutch hub extractor twin - 4 spring
$23.95 - USES OEM P/N's 61-3766 & 61-1912
BSA Triumph clutch extractor
USES OEM P/N's 61-3583
USES INCLUDE:
Timing pinion puller Triumph T20 Cub TR25
Clutch hub extractor Triumph TR25
BSA Clutch Extractor C15, B40, B44, B50
Re: The Motorcycle Tool Thread! [Re: Britishtools] #475854
02/05/13 9:26 pm
02/05/13 9:26 pm
Lyons, NY
Lyons, NY
$25.95 - USES OEM P/N's 61-1861, 61-7014, 61-3766
USES INCLUDE:
Triumph Clutch Hub Extractor T140 Long
Triumph/BSA Clutch Extractor Twin A50, A65, 3T, 5T, 6T, T100, T110, TR5, TR6, TR7, T120, T140 & all BSA 4-spring clutches
Norton AMC AJS clutch extractor
$29.95 - USES:
NORTON, AMC, AJS & MATCHLESS
1956-66
Top Dead Center tool - 14mm
$23.95
Norton exhaust C spanner
$36.50 - USES OEM P/N 06-3968 & 06-1229
Universal clutch adjuster key
$19.99 - FOR USE ON TRIUMPH, BSA & NORTON
USES OEM PART NUMBER REFERENCE 61-3700, 99-3512 & DA70
Re: The Motorcycle Tool Thread! [Re: Britishtools] #475857
02/05/13 9:32 pm
02/05/13 9:32 pm
Lyons, NY
Lyons, NY
Fork nut spanner BSA Triumph
$25.00 BSA A65 A70 R3 TRIUMPH X75 USES
OEM PART NUMBER 60-0779
Front brake nut box spanner
$27.00 - FOR USES ON TRIUMPH T150, T100, T120, BSA R3
FOR USES ON BSA A50, A65, A75, B25, B44 (WITH TWIN LEADING SHOE FRONT BRAKE)
USES INCLUDE OEM PART NUMBERS 60-1815 & 61-6062
Rocker shaft "O" ring compressor
$19.99 - FOR TRIUMPH BSA 500 TWINS, TRIDENT, T100, T120, R3, T150, A75 ETC
USES OEM PART NUMBERS 60-2221 & 61-7019
Re: The Motorcycle Tool Thread! [Re: Britishtools] #475892
02/06/13 2:57 am
02/06/13 2:57 am
Lyons, NY
Lyons, NY
Triumph BSA cam wheel extractor
$27.95 - OEM PART NUMBER 61-6132
FOR LATE MODEL TWINS AND TRIPLES WITH TWO 1/4" HOLES
Norton engine sprocket & clutch hub puller
$28.95 - USES OEM PART NUMBERS 06-4297 & 06-0941
Ignition timing tool Pre 1969 Triumph
$9.00 -TDC PLUNGER - IGNITION TIMING TOOL FOR PRE 1969 MODELS
USES OEM PART NUMBERS 60-0571 & 60-0572
Re: The Motorcycle Tool Thread! [Re: Britishtools] #475894
02/06/13 3:02 am
02/06/13 3:02 am
Lyons, NY
Lyons, NY
Triumph BSA engine sprocket extractor
$37.00 - UNIVERSAL SPROCKET EXTRACTOR BSA & TRIUMPH - CAM PINION PULLER
USES INCLUDE T100, T120, T140
OEM PART NUMBER REFERENCES INCLUDE: 60-6014, 61-3276, 61-6046
Triumph BSA shock absorber hub extractor
$20.99 - BSA - TRIUMPH SHOCK ABSORBER HUB EXTRACTOR
BSA R3, TRIUMPH X75
CLUTCH HUB - TRIPLES, A75, T150, T160
USES OEM PART NUMBER REFERENCE 60-1862
Re: The Motorcycle Tool Thread! [Re: Britishtools] #475895
02/06/13 3:03 am
02/06/13 3:03 am
Lyons, NY
Lyons, NY
Tappet adjuster key
$13.99 - USES OEM PART NUMBER REFERENCE 60-2020
Timing Disc - plastic
$12.50
Re: The Motorcycle Tool Thread! [Re: Britishtools] #489507
05/09/13 6:05 pm
05/09/13 6:05 pm
Lyons, NY
Lyons, NY
Fork top/gland nut spanner
$25.00
OEM p/n 65-9243
Re: The Motorcycle Tool Thread! [Re: Britishtools] #489510
05/09/13 6:12 pm
05/09/13 6:12 pm
Lyons, NY
Lyons, NY
Points oil seal guide - UNF
$12.95
USES OEM P/N'S:
61-7013 - TRIUMPH/BSA
06-1359 - NORTON
60-1810 - TRIUMPH/BSA
Z168 - TRIUMPH
Points oil seal guide - BSF
$12.95
USES OEM P/N'S: 60-0486
Z143
TRIUMPH T100, T120, TR25 ETC
B25, B44 ETC
Advance/Retard extractor tool BSA/TRI
$15.99
USES OEM P/N'S: 61-7023 & 60-0782
FOR BSA AND TRIUMPH
Re: The Motorcycle Tool Thread! [Re: Britishtools] #489511
05/09/13 6:17 pm
05/09/13 6:17 pm
Lyons, NY
Lyons, NY
Clutch compressor BSA Bantam
$34.95
USES OEM P/N 61-3191
BSA BANTAM
B175
D1 D3 D5 D7 D10 AND D14
Fork damper removal tool
$37.99
USES OEM P/N: 61-6113
BSA A65 OIL IN FRAME MODELS
TRIUMPH T120 71-73
Clutch locking tool
$19.95
USES OEM P/N: 61-3774
Re: The Motorcycle Tool Thread! [Re: Britishtools] #489513
05/09/13 6:24 pm
05/09/13 6:24 pm
Lyons, NY
Lyons, NY
Clutch locking tool TRI/BSA
$26.95
USES OEM P/N: 61-3760
Norton clutch hub lock tool
$28.95
USES OEM P/N: NM23441
VARIOUS MODELS
Norton Commando clutch lock tool
$24.99
USES OEM P/N: 06-1015
NORTON COMMANDO CLUTCH LOCK TOOL
Moderated by  Morgan Moderator
