thebevman
thebevman
Redding, CA
Bluing exhaust pipes
#442246 06/28/12 2:30 am
Hello all, I'm sure this might have been gone over several times before, but for the life of me I cannot find anything using the search option....ok that being said, could you guys help me figure out what are the possible causes of bluing on only one exhause pipe on a 67 thunderbolt, as i'm sure you all know its a single carb. 650, thanks guys
Re: Bluing exhaust pipes
PsYcHoBiLLYRocKeR #442247 06/28/12 2:34 am
Thin metal on the pipe,late ignition timing,leaner mixture on one cylinder(harder to fix wih only one carb).
PsYcHoBiLLYRocKeR #442255 06/28/12 3:40 am
How do the spark plugs look? Is one white (lean) on the side with the blue pipe? If one ceramic insulator is white and the other tan or brown, you may have an air leak somewhere. Are the pipes modern replacements? Some of them are thin and, even if bought in a pair, can vary a small amount in wall thickness. If there is no air leak, an old trick (chewing gum and bailing wire, last resort variety) is to coat the interior of the blueing pipe with heat proof paint.
Jeff Connor
1972 Norton Commando Roadster
VT Jeff #442259 06/28/12 6:47 am
Try doing a compression test. A slightly leaking exhaust valve will cause overheating on one side and blue a pipe.
Beezageezauk.
PsYcHoBiLLYRocKeR #442508 06/29/12 11:12 pm
Thanks guys, I think I narrowed it down to a timing issue, I really appreciate the help
PsYcHoBiLLYRocKeR #442509 06/29/12 11:21 pm
blueing and tarnishing.many years ago this said to be because of single nickle plating. double nickle plating and then chroming was the cure. has anything changed?
beezageezauk #442550 06/30/12 11:46 am
Quickest way to fix a slightly leaking exhaust valve is to give the engine a few rev-ups,with no exhaust pipes attached to the head.30 seconds of this treatment will normally show an improvement on the compression gauge.
Make a lot of noise,but you don't need excessive revs.Check valve clearances after the engine cools down.
PsYcHoBiLLYRocKeR #442624 07/01/12 12:21 am
Hi Pete--I have seen you give this advice several times on this forum.
I am intrigued---how did you find out this was a good thing to do?
Hope you dont mind me asking.
Tridentman #442642 07/01/12 3:50 am
Some things are invented,and some things are just discovered.I discovered this a little over 40 years ago,working on a bike that had been run with tight valve clearances.I had the pipe off to look at the exhaust valve.A few blasts without the exhaust pipe improved the compression.
I tried it later on a bike that had been stored about a year,and it was down about 30 psi on one cylinder.It all came back within a minute.
It seems to work,so I've done it on other bikes and got similar results when normal running wouldn't fix it.
PsYcHoBiLLYRocKeR #442711 07/01/12 4:19 pm
Pete--thanks. Very interesting.
Tridentman #442745 07/01/12 7:14 pm
Yes Pete...thanks from me also. I've had that problem a couple of times and taken the long route of a decoke and valve grind. I guess I'll be "annoying the neighbours" next time.
Beezageezauk.
PsYcHoBiLLYRocKeR #443239 07/05/12 3:32 am
I've gone ahead and ordered a Pazon Ignition, if your interested in the results, i'll keep you posted
Pete R - R.I.P. #443292 07/05/12 3:39 pm
pete r can you tell me how running without pipes restores the compression i am at a loss to see how it works.
love life
roadrocket #443350 07/05/12 9:12 pm
I only discovered that it works,and often enough gets a 30 psi improvement.
I haven't discovered exactly why it works.
I can only assume that it's like de-scaling a copper head gasket,when you quench it.The crud/scale doesn't like hot exhaust followed by cold air,and it gets cleaned off.
