Argos parts, Mr. Bean, rudi, Derek, Psychorider
10862 Registered Users
franko 172
DavidP 71
reverb 64
NickL 55
1,015,663 mail-order LSR
Topics67,793
Posts680,316
Members10,862
41 registered members (Al Eckstadt), 385 guests, and 804 spiders.
New project need help with info. #428741 04/09/12 7:39 am
Blapper Offline OP
Hello chaps,
I am helping my oldest brother rebuild a 1960 Dominator 600SS which has been in the family since another brother bought it when it was 1 year old.
The other brother had it in mind to rebuild it when he was retired, but illness and an affair with fast Japanese and Italian bikes meant he never got round to it before he died. He was my mentor and helped me with my first bike build in 1969 so I want to do this right in his memory.
My question is in the title; having a Norton basket case to rebuild is difficult when I never owned one back in the day, so I need to gather as much detailed information as possible to be sure the bike goes back together right.
Can anyone point me to a publication that at least shows the detail like a Triumph manual does? I believe the 600SS was not so common so I hope I don't have to end up guessing!
All help will be appreciated.
TIA.
Re: New project need help with info. [Re: Blapper] #428761 04/09/12 10:10 am
L.A.B. Online Content
This should get you started. There is a manual for the '60-'68 models.
http://www.classicbike.biz/Norton/Repair/NortonRepair.htm
http://www.classicbike.biz/Norton/Parts/NortonParts.htm
Unfortunately the parts lists only go back as far as '61, but you should be able to get an illustrated '59-'60 list plus a '60 unillustrated parts supplement from BMS.
http://www.brucemainsmith.com/index.html
Photocopies>N>Norton>55-64
Haynes manual(187).
http://www.burtonbikebits.net/parts_books.htm
Re: New project need help with info. [Re: Blapper] #428763 04/09/12 10:39 am
Blapper Offline OP
That's brilliant L.A.B., thanks.
Re: New project need help with info. [Re: Blapper] #428826 04/09/12 4:30 pm
norton bob Offline
Hi Blapper, I live in Bromley Kent and have a 60 99dl, you can PM me for contact details, I built mine from Bits. I can help.
Re: New project need help with info. [Re: Blapper] #428909 04/10/12 1:20 am
possm Offline
I am in the final stages of completeing a 650SS restoration and as the 600 and 650 are simular this may be of help-
http://www.accessnorton.com/650ss-rebuild-t9881.html
Re: New project need help with info. [Re: Blapper] #428989 04/10/12 4:47 pm
Blapper Offline OP
Hey thanks for your kindness guys!
The new bike lift arrives for the job on Wednesday so work starts soon after.
Bob: I'm just down the road from you in Rochester now.
Possm: Nice picture story.
Question: My brother says there seems to be something missing from the oil pipe connection hardware (return side) at the oil tank? I haven't been able to get there to look at it but I wondered if it is a take-off to the rockers or summat? Doubtless it will be in the information on those links above, but I thought it worth an ask now.
Re: New project need help with info. [Re: Blapper] #429018 04/10/12 8:10 pm
norton bob Offline
Should be a banjo supplying low pressure feed to head,try to get one from a 250 to improve the flow to the usually dry rockers!!.
Re: New project need help with info. [Re: Blapper] #429029 04/10/12 9:25 pm
possm Offline
Check RGM Motors web site I beleive The fitting etc will be available.
Re: New project need help with info. [Re: possm] #429105 04/11/12 8:17 am
norton bob Offline
The 650ss resto is very impressive,Not sure that the header pipes are the correct shape or diameter,they were usually more angular and small bore (in the UK), the pattern looks more like Atlas, perhaps the AMC factory settled on one style for both, No matter as i much prefer that old style curved pipe (very similar to the very first dommy),That curved shape is also what the 99 should have,but is not always supplied.Don't think pipes are made in the uk now,but bought in. .The slotted headlamp ears are also an AMC part,shared with the commando,not fitted to the early 650's.
Re: New project need help with info. [Re: Blapper] #429106 04/11/12 8:24 am
Towner Offline
Hello,
I can only speak for the Commando where Andover Norton is the best parts supplier. They are a bit more expensive, but the quality is much better than it used to be for e.g. Triumph parts, where you often have to be satisfied with Chinese parts.
Ralf
Triumph Bonneville 650 T120RV 1972
Norton Commando 850 MKII 1973
Re: New project need help with info. [Re: Blapper] #429162 04/11/12 4:46 pm
Blapper Offline OP
Hi Ralf,
Cheers, I know of Andover Norton - expensive but good so that's OK.
Re: New project need help with info. [Re: Blapper] #429175 04/11/12 6:08 pm
Tridentman Offline
Hi Blap---good to see that you are back living in Gods own country.
Wondered how long you would be able to stand living in Frog land.
BTW--what oil supply and filtration system are you going to fit to the Dommie?
Re: New project need help with info. [Re: Blapper] #429266 04/12/12 7:38 am
Towner Offline
Originally Posted by Blapper
Hi Ralf,
Hi Blap,
I am in contact with Joe Seifert and he told me that they are well sorted in mechanical parts for the 600. Sheet metal components (e.g. mudguards) could be a problem.
Ralf
Re: New project need help with info. [Re: Blapper] #429350 04/12/12 9:11 pm
Blapper Offline OP
Hi Richard, hope you're well. I will be rebuilding the Dommie with and for my oldest brother - he wants it standard and with patina in place so minimal refinishing and modifications are the likely outcome. However, if yous guys know of any important mods that will make it more reliable (like the rocker feed off the Jubilee), I'd like to hear of them.
Ralf: Fortunately the original rolled edge deep valance mudguards are in pretty good shape so that's not a problem - I'll bear the rest in mind, thanks for asking.
Moderated by  Dave Comeau
