locO leoN
locO leoN
Toronto
10987 Registered Users
franko 92
DavidP 57
NickL 53
1,117,088 mail-order LSR
Topics68,678
Posts688,744
Members10,987
42 registered members (a330us), 4,082 guests, and 887 spiders.
Camshaft end play #366006 04/01/11 11:33 am
Towner Offline OP
sadly it turns out, that the exhaust thread repair does not hold (see Post http://www.britbike.com/forums/ubbthreads.php?ubb=showflat&Number=364273#Post364273).
It comes out of the head more and more, so that the exhaust pipe can't be fastened anymore. So I stripped down head and barrels again and noticed, that the
new JP piston had already a seizure and has to be renewed as well. The cams look good. I measured the endplay of the camshaft. It is about 0.15" (0.4mm).
Is that still in limit ?
Ralf
Triumph Bonneville 650 T120RV 1972
Norton Commando 850 MKII 1973
Re: Camshaft end play [Re: Towner] #366036 04/01/11 3:28 pm
L.A.B. Offline
I hope you mean 0.015" (15 thou' = .381mm)? As 0.15" is 3.81mm.
If so, then that sounds OK.
Previous JP piston thread: http://www.britbike.com/forums/ubbthreads.php?ubb=showflat&Number=314083
Re: Camshaft end play [Re: Towner] #366042 04/01/11 3:59 pm
kommando Offline
JP uses a low number of base castings to cover a wide range of final applications, hence for most applications they start with a large casting and machine off the required amount. Except for a few applications at the lower end of the sizes the base casting covers they are always heavier than the original piston, that together with the small batch sizes they work with which seems to result in missed machining operations means they should only be considered as a last resort. I would be looking for some Hepolites or using the Cyclecraft (if they do 850 pistons) with a good ring brand.
I also had an 850 with a bronze insert for the exhaust thread repair which came loose, I sent the head to Mick Hemmings who welded a new aluminium insert. He charged the same as for a normal repair on stripped threads but there was extra work involved.
Re: Camshaft end play [Re: kommando] #366074 04/01/11 7:28 pm
Towner Offline OP
@LAB: 0,015" of course (0,40mm).
I sent head and barrels to an experienced mechanic, who will weld new aluminium inserts. He has also good experiences with GPM pistons which are sold by Andover Norton . It may be possible that he can still use the first oversize.
Ralf
Re: Camshaft end play [Re: Towner] #366215 04/02/11 3:09 pm
Alan Prudhomme Offline
Do yourself a big favor and buy some brass exhaust nuts. Alloy expands twice as much as steel which makes keeping steel nuts almost impossible to keep tight. I suspect the crack in your head was caused by the alloy not being able to shrink fully on the steel nut (possible)???
I bought chrome plated brass nuts and they loosened up like the iron ones do....think I got the brass ones from NORVIL. The brass nuts stay put so you can toss all the tab washers wire and springs. Brass expands at the same rate aluminum does.
Re: Camshaft end play [Re: Towner] #366235 04/02/11 4:50 pm
Towner Offline OP
the thread repair problem very likely comes from using a steel insert.
Ralf
Re: Camshaft end play [Re: L.A.B.] #367420 04/09/11 5:14 pm
Towner Offline OP
I am not really sure that I got the correct reading, because it is not easy to measure. So I tried it again today. May be more than 0.015" but defintety less than 0,04" (1mm). Where is the limit and can it be adjusted without splitting the cases ?
edit: I just managed it to measure it more exactly with a feeler gauge at the thrust washer. It is 0.027" (0,7mm).
Ralf
Re: Camshaft end play [Re: Towner] #367430 04/09/11 6:42 pm
Towner Offline OP
I recognized that only one thrust washer can be seen on the timing side. But in the manual is stated that after engine number 200000 2 washer are required....
The left conical washer (06-1086) is on my camshaft:
http://www.oldbritts.com/cam_bush.html
Re: Camshaft end play [Re: Towner] #367443 04/09/11 8:08 pm
L.A.B. Offline
My factory manual copy gives the following information:
"On engines between numbers 200000 and 300000, a flat thrust washer is fitted between this chamfered washer and the crankcase."
As your Commando is a 1973 850 model, it should have an engine number higher than 300000? So, no second washer.
Also, check what it says in the Old Britts info:
"06-2601 -- NORTON, Washer, Thrust, Camshaft, Some 1972( $5.62 each). This tabbed thrust washer is only used when fitting the 06-2600 bushing and there is a locating hole for the tab in the crank case."
Re: Camshaft end play [Re: L.A.B.] #367503 04/10/11 7:44 am
Towner Offline OP
Yes, my Commndo has number 312091. So one washer is right. Thanks for the information. In my manual and also in the Haynes they only talk about later than 200000.
I found this post from Dave Comeau which confirms my reading of 0.030". In this post they also say, that the tabbed washers should be avoided.
http://www.britbike.com/forums/ubbthreads.php?ubb=showflat&Number=69240#Post69240
Originally Posted by Dave Comeau
..... and the cases and thrust washers are normally 1.105" total giving .030" end float/clearance.
Ralf
Re: Camshaft end play [Re: Towner] #373391 05/15/11 10:53 am
Towner Offline OP
the parts are back and my Commando is ready again. I also mounted new exhaust pipes and lock rings. The reason for the piston seizure were not the JP pistons but a wrong clearance of only 0.0035" (0.09mm ).
Ralf
Moderated by  Dave Comeau
